By buying this product you get 89 loyalty points
The Denafrips Enyo DAC is an R2R digital-to-analog converter supporting high-resolution audio streams up to PCM 24bit 1536kHz and DSD1024. R2R technology enables Enyo to deliver a natural, faithful and musical sound reproduction.
To obtain a high-performance R2R DAC, Denafrips Enyo uses a network of ultra-precise resistors. Each resistor is rigorously measured and matched by a machine and validated by human intervention.
Denafrips Enyo uses a fully symmetrical R2R design. Each channel is decoded by 4 sets of R2R networks. This design features very low linear error, high decoding speed and low digital noise, guaranteeing not only low distortion of the audio signal, but also very low background noise, enabling the listener to fully enjoy his or her music. The DAC also provides the user with NOS or OS and Slow or Sharp filters.
Key features:
Product type | Balanced R2R DAC |
Inputs | 2x Coaxial 2x Optical Toslink 1x USB-B |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
Supported sampling rates | USB : PCM up to 1536kHz, DSD up to DSD1024 Optical / Coaxial : PCM up to 24bit 192kHz, DSD up to DSD64 (DoP) |
Sampling rate modes | Non onversampling (NOS) Oversampling (OS) |
Output impedances / levels | RCA : 625Ω @ 2Vrms XLR : 1250Ω @ 4Vrms |
Filters | Slow Sharp |
Frequency response | 20Hz - 70Hz (-3dB) |
THD+N | 0.004% |
SNR | 115dB |
Dynamic range | > 119dB |
Crosstalk | -124dB |
Supply voltage | 100-240VAC 50/60Hz (selectable voltage) |
Consumption | ≤ 20W |
Color | Black |
Dimensions | 230 x 215 x 45mm |
Weight | 3.5kg |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | RCA |
Output | XLR |
Max sampling rate | DSD1024 |
Max sampling rate | 1536kHz |
Color | Black |
Networking | No |
Remote Control | N/A |
