By buying this product you get 980 loyalty points
The Denafrips Terminator PLUS 12Th is a high-performance, balanced R2R NOS DAC capable of delivering incredibly pure, rich sound. It benefits from an uncompromising design, conceived to offer the best possible musical experience!
Key features :
The Denafrips Terminator PLUS digital/analog conversion module and its R2R ladder networks are perfectly isolated. The two boards are physically linked by the OCXO clock module. Physical isolation reduces background noise and improves the signal-to-noise ratio.
The Terminator PLUS is equipped with two OCXO clocks operating at 45.1584MHz and 49.152MHz. Encapsulated in a metal housing located in the center of the DAC, these OCXOs are specially designed for high-end audio applications with ultra-low phase noise and very high precision. Both OCXOs are powered by the completely redesigned power supply circuit, providing constant current to the clocks. Adequate power reserves guarantee the linearity and stability of the clock signal.
Jitter is also reduced by reclocking the FIFO buffer. The adaptive FIFO buffer stores digital audio data. These are read directly using the ultra-low phase noise OCXO located directly in the DAC.
The Terminator PLUS also features an OCXO clock output for perfect synchronization of multiple audio devices.
The Denafrips Terminator PLUS 12Th incorporates its own linear power supply stage, located beneath the DAC board and separated from it by a steel partition to avoid any interference. The power supply itself uses two large O-Core toroidal transformers for the digital and analog sections, and low ESR capacitors to provide an electrical signal to all the audio circuits.
To ensure the shortest possible signal path, I2S and SPDIF signals are processed by an FPGA chip, without any additional conversion chips.
In addition to the subtle changes made to the front panel of their legendary DAC, Denafrips here offers us an evolution of the Terminator, not only through design improvements such as the redesign of the OCXO clock power supply circuit, but also through the extreme care taken in the choice of each and every component. Indeed, the various elements that make up the Terminator PLUS, from the OCXO clocks to the R2R ladder networks, have been hand-selected to guarantee a level of craftsmanship unmatched to date. These evolutions result in a lower rate of total harmonic distortion, enabling a faithful reproduction of the signal without compromise.
The Denafrips Terminator PLUS 12Th also boasts comprehensive connectivity, enabling easy integration into the vast majority of audio systems. Inputs include USB-B, I2S RJ45 LVCMOS, I2S RJ45 LVDS, I2S HDMI LVDS, AES/EBU, Toslink optical and coaxial. Outputs include unbalanced stereo RCA and balanced stereo XLR. Two clock outputs enable the Terminator PLUS and another audio device to be perfectly synchronized for optimum system performance.
1 | Balanced XLR output |
2 | Single-ended RCA output |
3 / 4 | Clock output |
5 | Coaxial input |
6 | Toslink optical input |
7 / 8 | AES/EBU input |
9 | I2S HDMI LVDS input |
10 / 11 | I2S RJ45 LVDS / LVCMOS input |
12 | USB-B input |
13 | Power connector |
Product type | NOS balanced R2R DAC |
Inputs | 1x USB-B 1x I2S via HDMI LVDS 1x I2S via RJ45 LVDS 1x I2S via RJ45 LVCMOS 2x AES/EBU 1x Optical Toslink 1x Coaxial |
Outputs | 1x Balanced stereo XLR 1x Single-ended stereo RCA |
Supported sampling rates | USB / I2S : PCM up to 1536kHz, DSD up to DSD1024 Optical / Coaxial / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64 |
Output level/impedance | RCA : 2.2Vrms @ 625Ω XLR : 4.Vrms @ 1250Ω |
Sampling modes | Non-oversampling (NOS) Oversampling (OS) |
Filters | Slow Sharp |
Frequency response | 20Hz - 40kHz -0.2dB |
THD+N | 0.0010% |
SNR | 127dB |
Dynamic range | > 132dB |
Crosstalk | -110dB |
Supply oltage | 100-240VAC 50/60Hz |
Consumption | ≤ 20W |
Color | Silver |
Dimensions | 430 x 380 x 105mm |
Weight | 19kg |
Package | 1x Denafrips Terminator PLUS 12TH |
Input | SPDIF |
Input | I2S via HDMI |
Input | AES/EBU |
Input | USB |
Input | Optical |
Input | I2S via RJ45 |
Output | RCA |
Output | XLR |
Max sampling rate | DSD1024 |
Max sampling rate | 1536kHz |
Color | Silver |
Networking | No |
Remote Control | N/A |
