ERATO DAC100 V1 Balanced DAC XLR 24bit / 192Khz 2x AK4497 DSD128 XMOS U208
The DAC 100 uses two 32-bit AKM AK4497 AKM chips to provide very accurate stereo digital decoding while maintaining a minimum noise level (128dB signal-to-noise ratio and -166 dB THD+N).
4.0 / 5
By buying this product you get 159 loyalty points
Reference : 12607
1 590,00 €tax incl.
1 325,00 € tax excl.
ERATO DAC100 V1
DAC Double AKM AK4497 Full balanced JFET
DAC 100 ERATO
Both decoding chips DAC DAC 100 ERATO
Duo AKM AK4497
The DAC 100 uses two chips AKM AK4497 32-bit stereo digital to ensure decoding of high accuracy while maintaining a minimal noise level (S / N ratio of 128dB and THD + N of -166 dB).
This architecture allows it to decode finesse the high resolution audio files. It thus supports the PCM to 192KHz / 16/24 bits, the  as well as the DOP 64
These chips also can refine the decoding through technology Velvet Sound that promotes the deployment of the sound stage for extended listening space. This helps to create a stereo effect rich in detail.
6 digital filters are available to choose from to accommodate the peculiarities and preferences of the user and its audio system.
High precision analog output
The analog part is extremely neat.
outputs and analog buffers filters use a scheme based on discrete JFET transistors.
This type of system allows a high supply voltage and a high buffering power class A.
Thus the bandwidth is very high, while maintaining a level of crossover distortion and minimal noise.
The result is a listening its relaxing, natural and rich in detail.
analog output stage ERATO DAC 100
XMOS chip U208 DAC 100 ERATO
XMOS USB U208
The USB interface is based on a chip XMOS U208. An ideal choice for a high quality since the DAC U208 is equipped with two separate clocks femtosecond (asynchronous communication).
This construction also keeps the jitter and phase noise to a considerably low level (-160 dBc / Hz @ 1 KHz)
Driver XMOS available in the "Downloads" tab on this page.
A complete and efficient DAC
Digital Input DAC 100 ERATO
With its chips duo AKM AK4497, his (many) connectors high quality and a symmetrical design, the DAC 100 is a piece of choice for ambitious Hi-Fi facilities.
It is equipped with a wide range of digital inputs that allow it to operate with drives or digital sources varied while providing an extremely clear conversion. USB input We thus find :
  • USB (XMOS U208)
  • BNC
  • Optical
  • Coaxial
  • XLR balanced (AES/EBU)
symmetrical and asymmetrical output
DAC100 erato balanced output Lundhal and asymmetrical
Two unbalanced RCA output are available. The rear pannel offers two balanced XLR outputs as well.
Large OLED display
3.12 inch OLED DAC 100 ERATO
An OLED generous size (8.5cm diagonal) displays real-time information about the conversion.
Two lateral buttons to navigate between the inputs to select the active source and the filter type natively available in chip AK4497
The sampling frequency and the mode (PCM / DOP) are detected automatically.
Detail of the screen
  • A: Input signal source
  • B: Selected filter
  • Source C: Button.
    • Short press : changer source
    • Long press: ON / OFF
  • D: PCM / DOP format
  • E: Frequency sampling of the source
  • F: Filter button
    • Short press: Next filter
    • Long press: Mute / cancel mute
DAC with Trigger
Rear of the DAC 100 with power / ground and trigger
The rear facade of the 100 Erato DAC has a trigger input that allows another device to turn the system on.
TypeDAC
Chip decoder2x AKM AK4497
USB ModuleXMOS U208
Inputs
2x S / PDIF RCA & BNC 75Ω
1x AES / EBU 110Ω symmetrical
1x Toslink1x USB-B 2.0 (XMOS)
Outputs
1x stereo RCA unbalanced
1x balanced XLR
Distortion<% @ 0.0002 -2dbBFS
SNR> 120 dB
THD + N> 113dB @ 0 dBFS
Channel separation> 110 dB
Frequency response10Hz-20kHz (+ / - 0.1dB)
Maximum output+8dBu (1.95V RMS)
Power consumption25W
Supported sampling frequencies
PCM 192kHz / 16/24-bit
DoP64
Phase Noiseless than -160dBc / Hz @ 1 KHz
DisplayOLED display 8.5 cm
Volume ControlNo
Digital Filters- Short Delay Sharp Roll-Off
- Short Delay Slow Roll-Off
- Sharp Roll-Off
- Slow Roll-Off
- Low-dispersion Short Delay Filter
- Super Slow Roll-Off
Power supplyIncluded
Dimensions430 x 89 x 324 mm
Weight9.1 kg
Frequency response Erato DAC 100
InputXLR
DAC / ADC ChipAK4497EQ
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Très bien, mais...
Très bon DAC et bonne surprise au regard des filtres qui se révèlent simples et efficaces. Le son est comparable et souvent meilleur que celui de mon streamer 3D Lab beaucoup plus couteux.
Deux bémol néanmoins: la présentation qui est vraiment basique au regard des qualités de l'appareil et la livraison de la poste (COLISSIMO) catastrophique. (carton déchiré et cabossé, à demi ouvert..). AUDIOPHONICS affirme laisser le choix dans le cadre du transporteur mais en réalité, lors de la commande, COLISSIMO est imposé. Pour ma part, je suis résolu à ne plus valider aucune commande de produits à risques avec COLISSIMO.
This review has been posted for ERATO DAC100 V1 Balanced DAC XLR 24bit / 192Khz 2x AK4497 DSD128 XMOS U208
The DAC 100 uses two 32-bit AKM AK4497 AKM chips to provide very accurate stereo digital decoding while maintaining a minimum noise level (128dB...
