FX-AUDIO DAC-SQ5 DAC PCM1794 24bit / 192kHz + SA9027 Noir
The DAC FX AUDIO SQ5 offers 3 digital inputs including a USB, a PCM1794 DAC and a quality analog output on an AOP OPA2604 and 2 LME 49720. This DAC for an accessible budget will greatly improve any old High Fidelity channel.
Strengths:
  •  High quality passive components
  •  DAC PCM1794
  •  PCM AK4113 Digital Receiver
  •  X1 OPA 2604 and X2 LME49720 on DIP 8 support
4.5 / 5
Reference : 12577
99,00 €tax incl.
82,50 € tax excl.
- DAC FX AUDIO DAC-SQ5 -
The DAC FX AUDIO DAC-SQ5 features quality components in a compact format. Offering a quality of electronics rarely encountered in this range, the SQ5 provides a warm and dynamic sound, typical of the CHIPS DAC PCM1794. Thanks to its SA9027 USB input, it can decode any High Definition format coming from a Windows, Linux or Mac OS PC.
These coaxial and optical digital jacks are ideal for connecting a CD player with digital outputs or a TV with a toslink output. Dyers and music lovers will be able to change the 3 PDOs on DIP 8 support. Originally it has an OPA 2604 and two LME49720.
The OPA 2604 can be changed by the better OPA1622.
FX-Audio DAC-SQ5 review by Qobuz
" This DAC-SQ5 FX-Audio is a device to recommend to all those who do not want to complicate their lives to listen to dematerialized music from a computer, and who also want it to be particularly pleasant to their ears, knowing that they can also use this DAC with their old CD player. "
Test Qobuz
Features:
  • DAC: PCM1794
  • Inputs: USB-B / Coaxial / Optical
  • Sampling rate: USB (16Bit/192kHz & 24bit/96kHz) / Coaxial & Optical (24bit/192kHz)
  • Chips: USB SA9027 BRAVO
  • Outputs: Gold plated RCA line
  • Distortion by harmonqiue: 0.05%.
  • Noise Signal Ratio: 92dB
  • Frequency response: 20hz to 20Khz
  • Package:
  • Power supply: 12V 1A
  • Black brushed aluminium frame
Dimensions :
  • 105x95x32mm
  • Colour: black
  • Weight: 700g
DAC / ADC ChipPCM1794
Max sampling rate192kHz
4 reviews
polyvalent et excellent rapport qualité-prix
je cherchais un DAC peu onéreux à entrées diverses et alimenté en 12v (projet de le faire fonctionner sur batterie). Effectivement très souple d'emploi et je suis très agréablement surpris par la qualité d'écoute (après rodage d'une cinquantaine d'heures) très agréable. Semble très sensible aux cables employés (je préfère les plus neutres). Grand plaisir pour petit prix!
This review has been posted for FX-AUDIO DAC-SQ5 DAC PCM1794 24bit / 192kHz + SA9027 Noir
Un DAC universel
Bonjour,
J'utilise ce DAC pour mes tests, il fait très bien son boulot et le résultat sonore est excellent avec toutes les entrées.
Comparé au RaspiDAC ou au Allo BOSS, il est peut être un peu moins dynamique, mais pour celui qui écoute la musique au lieu d'écouter le matériel, le résultat est musical.
Il est dommage qu'il ne redémarre pas sur la dernière configuration utilisée à la mise sous tension, il faut appuyer sur le bouton pour choisir la source, c'est le seul défaut que j'ai constaté.
Pour le prix, il n'y a pas à hésiter, c'est un très bon produit.
Dac de qualité et compacte...
Comme dans l'énoncé, il est plutôt compacte et sa qualité de fabrication à l'air bonne tout comme le son. Je trouve aussi qu'il chauffe un peu, je possède d'autre Dac (CambridgeAudio) et ils ne chauffe pas autant. A part cela il ne lui manque qu'une sorti casque pour avoir un sans faute.
depannage par mail
le produit fonctionne ,rien d etonnant mais ai eu un problème de branchement rapidement résolu grace à la réactivité du sav par mail .
Encore bravo et merci
The DAC FX AUDIO SQ5 offers 3 digital inputs including a USB, a PCM1794 DAC and a quality analog output on an AOP OPA2604 and 2 LME 49720. This DAC...
