DAC Headphone Amplifier ES9023 CS8416 24bit 192kHz
The FX-Audio DAC-X3PRO is a particularly compact and affordable DAC and headphone amplifier combo. However, it offers good audio performance, using an ESS ES9023 DAC chip for its digital/analog conversion stage. The reception of digital SPDIF signals is entrusted to a CS8416 receiver. The combination of these components allows a clean and accurate reproduction.
The DAC-X3PRO has USB-B as its input, supporting files up to 24bit 96kHz PCM, as well as Optical and Coaxial, accepting sample rates up to 24bit 192kHz PCM. The output is on a stereo RCA and an amplified 3.5mm jack headphone output. A volume control allows to adjust the sound level of the latter. All the components are integrated in a sturdy brushed aluminium case.
Both outputs operate at the same time. The volume knob only controls the level of the 3.5mm headphone output.
Product type | DAC Headphone amplifier |
DAC chip | ES9023 |
SPDIF interface | CS8416 |
Inputs | 1x USB-B 1x Coaxial 1x Optical |
Outputs | 1x Stereo RCA 1x Jack 3.5mm headphone output |
Supported sampling rates | USB : PCM up to 24bit 96kHz Optical / Coaxial : PCM up to 24bit 192kHz |
RCA output level | 2Vrms |
RCA impedance | ≥ 100Ω |
Headphone output power | 45mW @ 16Ω 85mW @ 32Ω 160mW @ 64Ω 150mW @ 120Ω 65mW @ 300Ω |
USB transmission mode | ASRC |
THD+N | 0.04% |
SNR | 105dB |
Dynamic range | 105dB |
Frequency response | 20Hz - 20kHz |
Headphone output background noise | -110dBm |
Headphone output amplitude level | 4Vrms |
Recommended headphone impedance | 16Ω - 300Ω |
Housing material | Aluminum |
Dimensions | 99.2 x 98 x 33mm |
Weight | 560g |
Color | Black |
Package | 1x FX-Audio DACX3PRO 1x Power supply 1x USB cable |
Input | SPDIF |
Input | Optical |
Output | RCA |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9023 |
Max sampling rate | 192kHz |
Color | Black |
Class | Class D / T |
Networking | No |
Remote Control | No |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe J.
thierry V.
Aurélien B.
