HIBIKI SDS Balanced DAC R2R DSD1024
The Hibiki SDS is a dual-mono R2R DAC with the almost unique function of being able to upscale the sampling rate of any DSD1024 source in order to offer a signal with the highest possible resolution when converted by the resistor network. In short, the very best in digital signal processing at the service of pure analogue conversion.
By buying this product you get 399 loyalty points
Reference : 19253
3 990,00 €tax incl.
3 325,00 € tax excl.
HIBIKI SDSBalanced DAC R2R DSD1024
HIBIKI SDS Symmetrical DAC R2R DSD1024 : Front view
The Hibiki SDS is a dual-mono R2R DAC with the almost unique function of being able to upscale the sampling rate of any source in DSD1024 in order to offer a signal with the highest possible resolution when converted by the resistor network. In short, the very best in digital signal processing at the service of pure analogue conversion.
Ibiki SDS : An upscale sampling rate
As we said earlier, the Hibiki SDS is capable of upscaling the sampling rate of any source in DSD1024. To achieve this, a Delta-sigma modulator is used to apply 5-bit modulation to the incoming signal (a DSD signal is conventionally processed at 1bit) in order to obtain a signal quantization worthy of a much higher sampling rate. This, combined with reverse-engineering of the way the DSD format works, means that any sampling rate can be converted directly into DSD1024. For example, the Hibiki SDS can directly upscale a DSD128 file to DSD1024 without first undergoing PCM conversion and without any loss of information.
HIBIKI SDS: R2R macro view
Ibiki SDS : A ladder network of 36 resistances
Once the signal has been upscaled to DSD1024, it is converted to an analogue signal using a ladder network of 36 resistors. Although a network of 32 resistors would technically have been sufficient for the conversion, Hibiki decided to add 4 extra resistors to produce 10% more information to compensate for any potential desynchronisation coming from other resistors. The result is a precise reproduction with a transparent, airy soundstage.
Ibiki SDS : Pure sound reproduction
Although the technological heart of the Hibeki SDS DAC is DSD1024 signal upscale, it has also been designed for those who wish for a signal with as little digital processing as possible. With this in mind, a NOS (Non-oversampling) mode is available to produce the most faithful reproduction of the base file possible; this mode is used by default when the PLL diode on the front panel is not lit. Furthermore, the analogue part of the Hibiki SDS uses an architecture without feedback loops for the most natural sound possible.
HIBIKI SDS : View of facade buttons
Ibiki SDS : A silent power supply
To provide the best possible power supply for their DAC, Hibiki has adopted a power supply architecture that allows total isolation of the power supply from the conversion circuit. The result is an ultra-quiet -150dB power supply. Finally, although the Hibiki SDS has its own internal custom clock, it is compatible with external WCK and MCK clocks if you wish for it to be synchronised with other equipment.
HIBIKI SDS : LEDs explained
Product typeDAC
Inputs1x AES XLR 3-pin
1x Coaxial
1x Optical Toslink
1x BNC
1x Input for external clock
1x USB-B
1x HDMI I2S
Outputs1x XLR 3-pin stereo
1x RCA stereo
Supported sampling ratesUSB : up to PCM384/DSD512
I2S : up to PCM768/DSD1024
AES/Coax/Toslink/BNC : up to PCM192/DOP64
Output levelXLR : 4.6Vrms
RCA : 2.3Vrms
Power supply250V
Weight8kg
Package1x Hibiki SDS
InputI2S via HDMI
InputAES/EBU
InputBNC
InputClock (BNC)
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
The Hibiki SDS is a dual-mono R2R DAC with the almost unique function of being able to upscale the sampling rate of any DSD1024 source in order to...
