HOLO AUDIO CYAN 2 Balanced DAC
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete resistor networks. In addition, it operates in NOS (Non-Over-Sampling) mode for very pure, authentic signal reproduction.
4.9 / 5
By buying this product you get 136 loyalty points
Reference : 18584
1 369,00 €tax incl.
1 140,83 € tax excl.
Garantie 3 mois
HOLO AUDIO CYAN 2Balanced DAC R2R NOS 32bit 1536kHz DSD1024
Photo of HOLO AUDIO CYAN 2
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete resistor networks. In addition, it operates in NOS (Non-Over-Sampling) mode for very pure, authentic signal restitution. Here are the main improvements on version 2 of the CYAN DAC:
  • It is equipped with two independent R2R networks, the first of which handles the primary DA conversion of PCM streams, while the second (with vector stepping) handles the DA conversion of DSD streams.
  • A new, more efficient deglitching technology is integrated. It doesn't generate any unwanted noise or effects.
  • The CYAN 2 has better measurements, with a SINAD of over 106dB and a dynamic range of over 127dB.
  • It now supports sampling rates up to PCM 32bit 1536Mhz and native DSD up to DSD1024 via its USB port.
  • The USB interface uses proprietary software with ultra-low latency and a data transmission reliability rate 2 to 4 times higher than usual interfaces on the market.
Native DSD support
Holo Audio's CYAN 2 DAC is one of the first to support native DSD via its R2R ladder architecture. The CYAN 2 module has been specially optimized for this application, and runs on MAC (DOP), Linux (DOP), and Windows/PC (Direct Native and DOP).
Holo Audio CYAN 2: an Altera MAX II CPLD
The CYAN 2's Altera MAX II CPLD is used to process the clock signal and optimize the quality of the digital sound signal by considerably reducing the jitter rate.
Photo of CPLD Altera Max II
Holo Audio CYAN 2 DAC: I2S input via HDMI
Equipped with an I2S port via HDMI connector, the CYAN 2 lets you enjoy the very best in audio transmission. Please note that the pinout is proprietary to Holo Audio, although it is similar to the PS Audio standard. Left and right channels are inverted for DSD streams.
Please note that I2S is not the same as HDMI Audio/Video signals. Never connect an HDMI device to the CYAN 2's I2S port. Make sure your source device is I2S-compatible and has a similar pinout configuration.
HOLO AUDIO CYAN 2 I2S pinout diagram
R2R DAC Holo Audio CYAN 2 connectors
HOLO AUDIO CYAN 2 connector overview
1RCA analog output
2Balanced XLR analog output
3SPDIF Coaxial input
4I2S input via HDMI
5Toslink optical input
6USB-B input
7AES/EBU input
8Power socket / Fuse slot / Power switch
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typeBalanced DAC R2R
Inputs1x USB-B
1x AES/EBU
1x Optical Toslink
1x SPDIF Coaxial
1x I2S via HDMI
Outputs1x RCA
1x Balanced XLR
Supported sample ratesUSB (Galvanic isolation) : PCM 32Bit 1536MHz, DSD DOP64-512, DSD Native up to DSD1024
I2S: PCM 32Bit 1536MHz, DSD Native up to DSD1024
AES/EBU, Optical Toslink, SPDIF Coaxial: PCM 24bit 192kHz, DSD DOP64
Input selectionAutomatic
MEASUREMENT OF ANALOG OUTPUTS
PCM 48K NOSTHD +N : 0.0005% @ 1kHz (-106dB)
DNR : -127dB
Output voltages : 2.5Vrms (RCA), 5Vrms (XLR)
DSD128XTHD +N : 0.0002% @ 1kHz (-114dB)
DNR : -115dB
Output voltages : 1.25Vrms (RCA), 2.5Vrms (XLR)
general
Adjustable power supply220-230V 50/60Hz (fusible : 2A SB 5x20mm)
110-115 V 50/60 Hz (fusible : 4A SB 5x20 mm)
(power cable not included)
Energy consumption20W
Dimensions300 x 200 x 48mm
Weight3.5kg
Package1x DAC R2R Holo Audio CYAN 2
1x USB-A to USB-B cable
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
15 reviews
Holo Cyan 2 - wysyłka do Polski
Na początku kilka słów o samym zakupie. DAC został bardzo szybko wysłany, był dobrze zabezpieczony i dotarł bez żadnych problemów. Kontakt ze sklepem oceniam bardzo dobrze, wszystko przebiegło sprawnie i zgodnie z ustaleniami.
Jedyna uwaga dotyczy firmy UPS. W moim przypadku dostawa przebiegała dość chaotycznie, a informacje o przesyłce były mało precyzyjne. Sam sklep nie ponosi za to odpowiedzialności, ale gdybym miał wybór, następnym razem wybrałbym innego przewoźnika.
Holo Audio Cyan 2 – pierwsze wrażenia po około 110 godzinach wygrzewania
System:
* Lumin U2 Mini (transport)
* Holo Audio Cyan 2
* Moonriver 404
* ProAc D18
* Hijiri HCI-10 RCA
* Hijiri HCS-25
Po około 110 godzinach wygrzewania mogę już napisać kilka słów o Cyanie 2.
Na początku największe wrażenie zrobiły na mnie przestrzeń, oddech i frazowanie. Instrumenty dostały więcej powietrza wokół siebie, łatwiej było śledzić poszczególne linie melodyczne i relacje między muzykami. Nie był to efekt spektakularnej analityczności czy wyostrzenia konturów, ale raczej większej swobody i naturalności przekazu.
Im więcej godzin przybywało, tym bardziej dźwięk się uspokajał. Wokale stawały się gładsze, bardziej płynne i naturalne. Z czasem zaczęła pojawiać się również większa muzykalność oraz nasycenie harmoniczne.
Najbardziej podoba mi się to, że Cyan nie próbuje imponować detalem dla samego detalu. Zamiast tego skupia uwagę na muzyce. Łatwiej śledzić frazowanie wykonawców, wybrzmienia instrumentów i przebieg melodii. Szczególnie dobrze słychać to na wokalach, fortepianie i muzyce akustycznej.
USB czy AES?
Przed zakupem Cyana zakładałem, że najlepszym rozwiązaniem będzie połączenie AES/EBU. Przez lata używałem różnych kabli cyfrowych i zawsze uważałem AES za rozwiązanie bardziej audiofilskie niż USB.
Po zakupie Cyana moje spojrzenie nieco się zmieniło.
W moim systemie połączenie USB daje większe poczucie swobody, lepsze frazowanie i więcej informacji o samym wykonaniu muzyków. AES nadal potrafi imponować rytmem, dynamiką i precyzją, ale USB pozwala głębiej wejść w muzykę i łatwiej śledzić muzyczną narrację.
Nie twierdzę, że tak będzie w każdym systemie, ale u mnie USB okazało się zdecydowanie ciekawszym kierunkiem.
Fabryczny kabel USB Holo
Warto wspomnieć również o fabrycznym kablu USB Holo.
Przynosi on więcej masy, większe dociążenie i bardziej nasycony środek pasma. Początkowo robi to bardzo dobre pierwsze wrażenie.
Po dłuższych odsłuchach zauważyłem jednak, że część tej dodatkowej masy odbywa się kosztem oddechu, przestrzeni między muzykami oraz frazowania. Dźwięk staje się bardziej pełny, ale jednocześnie mniej swobodny.
Ostatecznie wróciłem do prostego kabla USB, ponieważ bardziej zależało mi na zachowaniu frazowania, naturalnego przepływu muzyki i poczucia obecności muzyków w pomieszczeniu.
Wygrzewanie
W moim egzemplarzu zmiany podczas wygrzewania są wyraźnie słyszalne.
Pierwszy etap przyniósł:
* przestrzeń,
* oddech,
* separację,
* frazowanie.
Dopiero później pojawiły się:
* większa płynność,
* gładsze wokale,
* większa muzykalność,
* lepsze wypełnienie harmoniczne.
Dlatego osobom kupującym Cyana polecałbym cierpliwość. W moim przypadku po ponad 100 godzinach urządzenie nadal wyraźnie się rozwija i mam wrażenie, że jeszcze nie powiedziało ostatniego słowa.
Na dziś Holo Audio Cyan 2 jawi mi się jako DAC dla osób, które bardziej interesują się muzyką i wykonawcami niż samym sprzętem. Jego największym atutem nie jest detal czy spektakularność, lecz umiejętność budowania muzycznej opowieści, naturalnego frazowania i poczucia obecności muzyków w pokoju odsłuchowym.
Pozdrawiam miłośników audio z Francji!
This review has been posted for HOLO AUDIO CYAN 2 Balanced DAC R2R NOS 32bit 1536kHz DSD1024
Marvelous DAC
Ma configuration : Denon PMA 3000NE, streamer dmp a6 master edition gen 2 + dac holo cyan 2 (connection en USB : câble Black Rhodium) et enceintes AE 320 1ere génération (Câble Black Rhodium minuet collection) .
Mon avis : exceptionnel, beaucoup d'émotion, la musique vous prend aux tripes, Jazz, electro, voix, tout est propre, aéré, précis, tridimensionnel, sans fatigue... Seulement la musique.
Les artistes sont là devant vous, votre corps tremble d'émotion, emporté par les notes, vous avez envie de danser, la musique fait partie de vous....Merci Kitsune et audiophonics.
Un autre monde
Pour essayer le R2R dont j'entendais parler. Dac précédent smls do200pro avec ses 12 puces Cirus Logic qui, jusqu'ici, avait mis à l'amende un paquet de dac bien bien plus chers à base de Sabre ou AKM. Après 200h de rodage H24 c'est vraiment un autre monde ! Scène sonore dépassant largement les enceintes et d'une profondeur stupéfiante avec certaines prises de son (par exemple chez Chesky Records ou encore Reference Recordings, captation avec micro unique) pureté transparente du son, énormément de matière, de micro-informations, voix ultra réalistes. Le bonheur !!!
Sur Cabasse Clipper reconditionnées full Mundorf et câbles HP argent.
Un "défaut" quand même. Comme signalé précédemment Led très (trop) puissantes. Mais avec un écran fumé foncé devant c'est réglé. D'ailleurs pour info car pas de notice fournie les Led clignotent quand le dac se synchronise avec la source puis passe au fixe quand tout est ok. Quand la synchro est excellente la Led est très puissante.
Una maravilla comparada.
Está funcionando con HQplayer - Roon- , lo escucho fundamentalmente con un sistema de auriculares Stax.
Tengo un X Sabre 3, un Chord Qutest buenos Dacs, pero el Cyan 2 los pasa por la derecha.
La magía la hace HqPlayer sin lugar a dudas, pero este dac lo permite. HqPlayer y Cyan 2 NOS alcanzan un nivel que le iguala a sus hermanos mayores, incluso a otros dacs que le triplican en precio.
Requiere eso sí un buen preamplificador y un streamer serio, en mi caso un Matrix Audio TT-1.
Enhorabuena a Holo, Audiophonics siempre una empresa europea fiable.
Satisfaction totale
J’ai eu pas mal de DACs dans des gammes de prix très différentes, purs FPGA, Sabre, AKM, et R2R.
Je trouve que le Cyan2 propose un produit plus que convaincant par son côté naturel et très équilibré du grave à l’aigu. Certains DAC iront probablement plus loin dans l’ouverture et la définition mais la musicalité du Cyan2 au prix proposé est particulièrement captivante. Une écoute fluide, naturelle, douce et très subtile. J’adore!
Holo Audio presents the big brother of its CYAN DAC, the CYAN 2. Like its predecessor, this is a balanced R2R DAC, based on discrete...
