Maverick Audio TubeMagic D2 DAC TE7022 / AD1955 Coaxial / Optical / USB
By buying this product you get 27 loyalty points
Reference : 8050
279,00 €tax incl.
232,50 € tax excl.
Rare converter equipped with a tube output stage is able to revive the most emaciated digital music.
Equipped with high quality components, Aop BB 2604, Audio Capacitors, AD1955 DAC it represents the high-end brand.
Characteristics :
  • Inputs: Optical (Toslink), Coaxial (RCA), Coaxial (BNC), USB, Analog (RCA) and Line-in Jack 3.5 mm
  • Outputs: stereo RCA (variable volume output), stereo RCA with tube preamp (variable volume output)
  • Sample rates Digital inputs: 32khz, 44.1Khz, 48Khz, 88.2Khz, 96Khz
  • Sample rates USB input: 32khz, 44.1Khz, 48Khz, 96Khz
  • Converter (DAC): AD1955
  • Audio Formats: 16, 20, or 24-bit linear PCM
  • Amplifier Headphone: 16/600 ohms (1000mW ~ 300mW) output on 3.5 mm jack
  • Harmonic distortion:> 0.001% conventional output, 0.1% tube preamp output
  • Linear regulators: on converter and line outputs
  • Signal / Noise Ratio: RCA outputs (117db); Output RCA Tube (> 100db)
  • Output Impedance: 5K ohms
  • Volume control: on all outputs
  • Linear Transformer: R-Core
  • Case: Brushed Aluminum Black
  • Dimensions: 260 x 55 x 167 mm
Contents of the box:
  • Maverick Audio TubeMagic D2 DAC
  • Getting Started Guide
  • 3.5 mm jack / jack cable (sources Android, Apple, PC etc.)
  • Power cable
PDF Manufacturer
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_1.jpg
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_2.jpg
From a computer (Mac, Windows, Linux etc.)
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_3.jpg
From a digital source (Console, DVD player, Squeezebox, etc. ..)/ P>
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_4.jpg
Comparisons between TubeMagic D1, D1 + and D2:
https://www.audiophonics.fr/images2/8050/8050_MAVERICK_AUDIO_D2_5.jpg
