MiniDSP U-DAC8 Asynchronus USB DAC AKM4440 8 channel 24bit 192kHz XMOS
By buying this product you get 35 loyalty points
Reference : 9732
359,00 €tax incl.
299,17 € tax excl.
The U-DAC8 is an 8-channel Asynchronous USB DAC for music lovers wishing to own a home cinema system worthy of the name.
By combining the efficiency of an XMOS USB interface with an AKM converter, the U-DAC8 achieves excellent audio performance.
From the basic audio surround format (5.1 / 7.1) to the latest audio standards, miniDSP now makes multichannel easy and affordable.
The U-DAC8 is Plug & Play on Mac OSX, the WDM / ASIO drivers are compatible for Windows and Alsa 2.0 for Linux.
The interface supports a wide sampling frequency range (from 44.1 to 192 kHz).
The U-DAC8 has 8 unbalanced channels via RCA connectors up to 2Vrms output level.
Its rugged black metal housing with brackets fits ideally on a rack or next to your computer.
Characteristics :
  • Asynchronous USB interface XMOS
  • DAC AKM4440
  • 8 RCA Unbalanced Outputs 2Vrms
  • USB 2.0 port
  • Dynamic range: 103dB
  • THD: 0.006%
  • Output Impedance: 560 Ohms
  • Supports files up to 24bit 192kHz (including 88.2)
  • Power Supply 5V DC Supplied
  • USB-A to USB-B 2.0 Cable
  • Dimensions: 31x161x108mm
  • Weight: 500g
  • Driver / Driver XMOS downloadable directly from the MiniDSP site (requires registration)
OutputCoaxial SPDIF
DAC / ADC ChipAK4440
Max sampling rate192kHz
