MUSICIAN AQUARIUS Balanced R2R DAC NOS I2S 32bit 1536kHz DSD1024 Black
The Musician Aquarius is a massive high-end DAC with a remarkable design, capable of delivering incredibly pure and rich sound. Taking advantage of a symmetrical R2R architecture, each channel is equipped with an independent high-speed FPGA to control the decoding, with four 0.005% R2R networks. Thus, linear errors are very low and decoding speed is high, with extremely low digital noise. It also ensures very low distortion and noise.
By buying this product you get 349 loyalty points
Reference : 15524
3 499,00 €tax incl.
2 915,83 € tax excl.
Shipping date: 22-04-2025.
Mu0sician Aquarius
Musician Aquarius DAC R2R Symétrique NOS I2S 32bit 1536kHz DSD1024 Noir
Proprietary technology
The Aquarius uses Musician's specially developed digital filters, operating in 16x Over Sampling mode. Each filter level has a 32bit input resolution, which allows for a considerable increase in dynamics while promoting a natural and delicate reproduction.
A particularly complete connectivity
The Musician Aquarius is equipped with a wide range of connectors to meet all needs and all types of integrations. On the digital input side, we find I2S via HDMI, USB-B, balanced AES, Coaxial and Toslink Optical. The output is made, with the choice, in asymmetrical RCA or balanced XLR.
It is not recommended to connect the XLR and RCA outputs simultaneously. This could degrade the sound quality as the outputs are shared.
It is recommended to use the XLR output to take full advantage of the balanced structure of the DAC.
High-end components
The powerful Aquarius is capable of fast and efficient processing of digital data, thanks to an Altera Cyclone IV FPGA and a high-performance ARM STM32F446 CPU. Two oscillators allow the restoration of audio signals with different sampling rates, to significantly reduce jitter while improving stability.
Optimized linear power supply
The Musician Aquarius linear power supply stage features an O-Core transformer. The linear regulator effectively isolates the digital and analog parts to ensure low noise and stable voltage for the DAC.
1Input selection
2ON/OFF Switch
3Mute mode
4Phase selector
5NOS Button
6Mode button
7Balanced XLR output
8Single-ended RCA output
9I2S input
10I2S input
11Coaxial input
12Optical input
13AES input
14USB-B Input
15Power connector
Pinout I2S
The Musician Aquarius has been designed to offer broad compatibility via its I2S input, with phase adjustment accessible as follows:
  1. Select the I2S-A1 or I2S-A2 input.
  2. Press and hold the NOS button for 3 seconds until the I2S indicator light flashes.
  3. Press the PHASE button to navigate through the 8 phase modes.
  4. The Aquarius will automatically exit this setup menu after 5 seconds of inactivity.
Product typeDAC R2R
Inputs1x USB-B
2x I2S LVDS via HDMI
1x AES/EBU
1x Optical Toslink
1x Coaxial
1x Balanced stereo XLR
USB InterfaceSTM32F446
Supported sampling rateUSB / I2S : PCM up to 32bit 1536kHz, DSD up to DSD1024, DSD DoP up to DSD64
Coaxial / Optical / AES : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Sampling modesNOS (Non OverSampling)
OS (OverSampling)
PCM Analog output level @ 0dB, 1kHzXLR : 3.59V
RCA : 1.79V
DSD Analog output level @ 0dB, 1kHzXLR : 2.66V
RCA : 1.33V
THD @ A-WeightingXLR : 0.002%
RCA : 0.01%
SNR @ A-WeightingXLR : 128dB
RCA : 123dB%
Freuency responseXLR : 10Hz-58kHz
RCA : 10Hz-58kHz
PhaseXLR : 0.001°
RCA : 0.001°
Output noiseXLR : 1.3µVrms
RCA : 1.2µVrms
Dynamic rangeXLR : > 121dB
RCA : > 121dB
CrosstalkXLR : -110dB
RCA : -110dB
Power cable115-230V 50/60Hz
Dimensions330 x 300 x 75mm
Weight5.6kg
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD1024
Max sampling rate1536kHz
The Musician Aquarius is a massive high-end DAC with a remarkable design, capable of delivering incredibly pure and rich sound. Taking advantage of...
