SINGXER SDA-6 PRO Balanced DAC AK4499 AK4118 FPGA XMOS I2S LVDS 32bit 384kHz DSD512
The Singxer SDA-6 symmetrical DAC benefits from a high-end architecture for high-fidelity sound reproduction. Here nothing is left to chance, each component has been carefully selected for its audio performance.
By buying this product you get 124 loyalty points
Reference : 14715
1 249,00 €tax incl.
1 040,83 € tax excl.
This is the "Advanced" (high-end) model of the Singxer SDA-6. Discover the SDA-6 PRO2 version here.
SINGXER SDA-6 PRO
Singxer SDA-6 DAC Symétrique AK4499 AK4118 FPGA XMOS I2S LVDS 32bit 384kHz DSD512
The DAC's digital-to-analogue conversion stage is based on a 32bit AKM AK4499 chip, ensuring extremely low levels of distortion and noise. In addition, it supports high sample rates for accurate, rich and dynamic playback. The SDA-6 will allow you to play PCM files up to 32bit 384kHz and DSD files up to DSD512. The DSD stream works in NOS (Non Over Sampling) mode to match the original signal as closely as possible.
The USB input is entrusted to a latest-generation XMOS XU208 interface and SPDIF reception has its own dedicated AK4118 chip.
At the heart of the device, an STM32 microcontroller is in charge of efficiently processing all the data and a Xilinx FPGA manages the clocks and the processing of digital audio streams.
The discrete Class A output circuit of the SDA-6 adopts a non-loop negative feedback balanced DC architecture. The oscillator of the USB input uses a femtosecond clock CCHD-957 for minimum jitter, combined with 4 independent ultra-low jitter oscillators for the rest of the circuit. The analog stage integrates Mundorf film capacitors to reveal a beautiful musicality.
A particularly extensive range of connectors
The Singxer SDA-6 has a full range of inputs and outputs, allowing integration into the vast majority of audio systems. Inputs include USB-B (XMOS), I2S LVDS via HDMI, Toslink Optical, Coaxial, AES/EBU and BNC. The unit also offers a CLK input on the BNC connector to connect an external clock. The outputs include unbalanced stereo RCA and balanced stereo XLR.
Product typeBalanced DAC
DAC chipAKM AK4499
Inputs1x I2S LVDS HDMI (Pin out standard PS Audio)
1x USB-B
1x Optical Toslink
1x Coaxial
1x AES/EBU
1x BNC
1x CLK (via BNC connector)
Outputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Supported sampling ratesUSB, I2S : PCM up to 32bit 384kHz, Native DSD up to DSD512, DSD DoP up to DSD256
SPDIF, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
SPDIF Input impedance75Ω
AES/EBU Input impedance110Ω
Output levels (0dBFS)PCM : RCA 2.25V RMS, XLR 4.5V RMS
DSD : RCA 1.8V RMS, XLR 3.6V RMS
Output impedanceRCA : 22Ω
XLR : 45Ω
Frequency response20Hz - 20kHz ±0.1dB
SNR131dB (20Hz-22kHz, A-Weighting)
THD+N (1kHz, 0dBFS)0.00012% (-118dB) @ fs=44.1kHz, PCM, 20Hz-22kHz, A-Weighting
Dynamic response (1kHz, -60dBFS)131dB @ 20Hz-22kHz, A-Weighting
Channel separation> 130dB @ 1kHz
Supply voltage115V-230V AC (switchable via internal cable connector)
Dimensions (excluding feet and connectors)262 x 220 x 46mm
Weight2.7kg
Package1x Singxer SDA-6
1x USB cable
1x IR Remote control
1x Power cable
InputBNC
InputI2S via HDMI
InputAES/EBU
DAC / ADC ChipAK4499
Max sampling rate384kHz
Max sampling rateDSD512
Remote ControlYes
5 reviews
Excellent DAC mais...
Je suis d'accord avec les autres avis posté avant le mien. Ce Dac est formidable pour le prix et même dans l'absolu ! J'ai l'impression d'avoir changé tout mon système. Ce que je viens d'écouter avec des CD lus par mon drive ATTOL DR 200 SE SIGNATURE relié en AES/EBU sur le SINGXER dépasse vraiment toutes mes attentes. C 'est une grosse claque que je viens de prendre en pleine figure et j'ai l'impression d'écouter un système vraiment très haut de gamme comme je n'en n'ai que très rarement entendu dans ma vie et je n'exagère pas. Je suis peut-être tombé par hasard sur l'accord parfait entre chacun de mes éléments. Autrement dit, je crois que j'ai eu le nez fin en choisissant ce DAC qui révèle enfin tout le potentiel de mon système. Je trouvais que la lecture de mes vinyles me procurais des résultats d'écoute bien supérieurs à ceux obtenus en lecture numérique avec mon ancien DAC AUDIO GD R2R 2 et je m'aperçois maintenant que c'était justement ce DAC qui était responsable de ce constat. En effet, l'AUDIO GD est très agressif dans le haut médium et dans l'aigü aussi bizarre que cela puisse paraître et ce quelque soit le réglage des jumpers (pas pratique du tout) NOS ou pas NOS. Soi-disant que les DAC R2R procure une restitution plus douces que les autres et bien en ce qui me concerne, c'est complètement faux. Peut-être que cela reste valable pour les DAC haut de gamme équipés de puces PCM 1704 je ne sais pas mais avec le R2R 2 c'est pas du tout ça. Impossible d'écouter quoi que ce soit à un niveau réaliste sans que cela me pète les tympans et que je n'éprouve le besoin de baisser le volume. Avec le SINGXER, c'est tout le contraire. Je mets un CD et j'augmente le volume une première fois, puis une seconde puis une troisième fois et ça le fait vraiment! Je n'en reviens pas moi même ! Inversement, en écoute à faible niveau j'entends des détails qui passaient totalement inaperçu avec l'AUDIO GD. Le son paraît totalement libéré. Les musiciens et les chanteurs me semblent présent dans la pièce, la scène sonore est large et profonde restituant parfaitement l'ambiance de l'endroit dans lequel la musique est jouée. Tout est juste. Les timbres, la dynamique, les extinctions de notes et l'absence de bruit de fond est impressionnante. Enfin bref, vous l'aurez compris, c'est sublime. Peut-être et sûrement que l'on peut obtenir encore quelque chose de meilleurs mais en ce qui me concerne je n'en n'éprouve pas le besoin et je suis comblé par ce que j'obtiens avec ce DAC dans mon système. Cependant, il y a un gros problème. Je n'arrive pas à faire fonctionner le pilote à télécharger recommandé par SINGXER. J'utilise le lecteur FOOBAR 2000 et je n'arrive pas à activer le pilote dans ce lecteur. C'est le pilote intégré dans le DAC qui fonctionne actuellement et qui s'est installé automatiquement lors du branchement du DAC sur mon système. Sur mon PC s'affiche comme sortie : Haut-parleurs (Singxer USB Audio 2.0). J'ai une icône qui est apparue en bas à droite dans la barre des râches avec la lettre T en blanc dans un carré rouge et lorsque je clique dessus la dernière version du pilote s'affiche : v5.50.0 mais me signale par l'écriture en gris clair que le pilote n'est pas actif. la résolution est en 44100 Hz - 24 Bits et les fichiers DSD ne sont pas lus par FOOBAR. La configuration requise pour le DSD est pourtant installée correctement puisque cela fonctionnait avec mon ancien DAC AUDIO GD et le pilote pour l'interface AMANERO. J'ai d'ailleurs supprimé ce pilote et tous ces composants avec Revo uninstal. Je me demande si je ne dois pas désactiver le pilote installé automatiquement. Toujours est-il que j'ai tout essayé ce que j'étais capable de faire pour faire fonctionner ce pilote et je n'y arrive pas. Je suis dégoûté. Pas de tutos en français sur YouTube ni ailleurs et je ne trouve personne qui parle du sujet dans les forums. J'appelle donc à l'aide. Si quelqu'un pouvait m'aider à régler ce gros problème ce serait sympa. Il serait souhaitable que j'entre en contact avec quelqu'un de ma région (Chalon Sur Saône) pour éventuellement travailler sur mon PC car ce n'est pas du tout évident de régler le problème par mail ou même par téléphone sauf si quelqu'un me guide en direct. Je ne sais pas si c'est le bon endroit pour demander de l'aide mais tant pis je tente le coup. Merci à celui ou celle qui pourra me venir en aide. Voici mes coordonnées : 06 46 38 44 06. fpawhite@laposte.net
 (3)
This review has been posted for SINGXER SDA-6 PRO Balanced DAC AK4499 AK4118 FPGA XMOS I2S LVDS 32bit 384kHz DSD512
Je suis d'accord avec les autres avis posté avant le mien. Ce Dac est formidable pour le prix et même dans l'absolu ! J'ai l'impression d'avoir changé tout mon système. Ce que je viens d'écouter avec des CD lus par mon drive ATTOL DR 200 SE SIGNATURE relié en AES/EBU sur le SINGXER dépasse vraiment toutes mes attentes. C 'est une grosse claque que je viens de prendre en pleine figure et j'ai l'impression d'écouter un système vraiment très haut de gamme comme je n'en n'ai que très rarement entendu dans ma vie et je n'exagère pas. Je suis peut-être tombé par hasard sur l'accord parfait entre chacun de mes éléments. Autrement dit, je crois que j'ai eu le nez fin en choisissant ce DAC qui révèle enfin tout le potentiel de mon système. Je trouvais que la lecture de mes vinyles me procurais des résultats d'écoute bien supérieurs à ceux obtenus en lecture numérique avec mon ancien DAC AUDIO GD R2R 2 et je m'aperçois maintenant que c'était justement ce DAC qui était responsable de ce constat. En effet, l'AUDIO GD est très agressif dans le haut médium et dans l'aigü aussi bizarre que cela puisse paraître et ce quelque soit le réglage des jumpers (pas pratique du tout) NOS ou pas NOS. Soi-disant que les DAC R2R procure une restitution plus douces que les autres et bien en ce qui me concerne, c'est complètement faux. Peut-être que cela reste valable pour les DAC haut de gamme équipés de puces PCM 1704 je ne sais pas mais avec le R2R 2 c'est pas du tout ça. Impossible d'écouter quoi que ce soit à un niveau réaliste sans que cela me pète les tympans et que je n'éprouve le besoin de baisser le volume. Avec le SINGXER, c'est tout le contraire. Je mets un CD et j'augmente le volume une première fois, puis une seconde puis une troisième fois et ça le fait vraiment! Je n'en reviens pas moi même ! Inversement, en écoute à faible niveau j'entends des détails qui passaient totalement inaperçu avec l'AUDIO GD. Le son paraît totalement libéré. Les musiciens et les chanteurs me semblent présent dans la pièce, la scène sonore est large et profonde restituant parfaitement l'ambiance de l'endroit dans lequel la musique est jouée. Tout est juste. Les timbres, la dynamique, les extinctions de notes et l'absence de bruit de fond est impressionnante. Enfin bref, vous l'aurez compris, c'est sublime. Peut-être et sûrement que l'on peut obtenir encore quelque chose de meilleurs mais en ce qui me concerne je n'en n'éprouve pas le besoin et je suis comblé par ce que j'obtiens avec ce DAC dans mon système. Cependant, il y a un gros problème. Je n'arrive pas à faire fonctionner le pilote à télécharger recommandé par SINGXER. J'utilise le lecteur FOOBAR 2000 et je n'arrive pas à activer le pilote dans ce lecteur. C'est le pilote intégré dans le DAC qui fonctionne actuellement et qui s'est installé automatiquement lors du branchement du DAC sur mon système. Sur mon PC s'affiche comme sortie : Haut-parleurs (Singxer USB Audio 2.0). J'ai une icône qui est apparue en bas à droite dans la barre des tâches avec la lettre T en blanc dans un carré rouge et lorsque je clique dessus la dernière version du pilote s'affiche : v5.50.0 mais me signale par l'écriture en gris clair que le pilote n'est pas actif. la résolution est en 44100 Hz - 24 Bits et les fichiers DSD ne sont pas lus par FOOBAR. La configuration requise pour le DSD est pourtant installée correctement puisque cela fonctionnait avec mon ancien DAC AUDIO GD et le pilote pour l'interface AMANERO. J'ai d'ailleurs supprimé ce pilote et tous ces composants avec Revo uninstal. Je me demande si je ne dois pas désactiver le pilote installé automatiquement. Toujours est-il que j'ai tout essayé ce que j'étais capable de faire pour faire fonctionner ce pilote et je n'y arrive pas. Je suis dégoûté. Pas de tutos en français sur YouTube ni ailleurs et je ne trouve personne qui parle du sujet dans les forums. J'appelle donc à l'aide. Si quelqu'un pouvait m'aider à régler ce gros problème ce serait sympa. Il serait souhaitable que j'entre en contact avec quelqu'un de ma région (Chalon Sur Saône) pour éventuellement travailler sur mon PC car ce n'est pas du tout évident de régler le problème par mail ou même par téléphone sauf si quelqu'un me guide en direct. Je ne sais pas si c'est le bon endroit pour demander de l'aide mais tant pis je tente le coup. Merci à celui ou celle qui pourra me venir en aide. Voici mes coordonnées : 06 46 38 44 06. fpawhite@laposte.net
Tout d'un (très) haut de gamme
Je ne vais pas contredire les avis précédents, tout y est.
Reproduction tendance neutre ( pas typée)
En fonction des enregistrements: grande transparence, image large et profonde, excellente macro et micro dynamique, grande fidélité des timbres, etc.
Par contre, ne pardonnera rien.
L'appareil chauffe et les aérations sont dessous, donc n'hésitez pas à rajouter des pieds plus hauts et ne rien poser dessus.
Sensible au cordon et à la phase secteur.
Excellent !
J'ai commandé ce produit me basant juste sur sa bonne réputation. Les premiers résultats d'écoute (seulement 10 h 00 de rodage !) dépassent toutes me attentes. Extrêmement précis tout en étant naturel et très musical (fluidité et legato). Bref ! quoi de mieux à ce prix et bien au delà?
Exceptionnel
Voici un DAC exceptionnel, je l'ai comparé à des concurrents 6 au fois plus chers et il fait jeu égal. Par contre il demande bien 200 à 300 heures de rodage pour que les composants Mundorf de l'étagère sortie analogique se rôdent, une fois ce cap passé on ne peut rien reprocher ace convertisseur tout y est: timbres, dynamique, résolution.
 (6)
The Singxer SDA-6 symmetrical DAC benefits from a high-end architecture for high-fidelity sound reproduction. Here nothing is left to chance, each...
