SMSL M300 DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Black
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a digital-to-analog converter capable of reproducing your audio files with both a beautiful transparency and an astonishing sound richness.
Reference : 13719
249,00 €tax incl.
207,50 € tax excl.
This product has been replaced by the new version, the SMSL M300 MKII AK4497.
SMSL M300
SMSL M300 DAC AKM AK4497 XMOS Double Horloge NDK 32bit 768kHz DSD512 Noir
AK4497 DAC & High-end components
The M300 is equipped with an AK4497EQ high-end DAC chip from AKM. The latter supports high sampling rates, in PCM up to 32bit 768kHz and in DSD up to DSD512. In addition, the chip uses the proprietary Velvet Sound architecture allowing it to provide a high SNR (128dB) and very low distortion (THD+N -116dB) for neutral and accurate reproduction, with a beautiful sound image.
This chip is combined with many quality components such as a second-generation XMOS USB interface, two ultra-low phase noise Japanese NDK clocks to significantly limit jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use.
Design, Screen & Connectivity
All components are integrated into a beautiful CNC machined Aluminium housing, both robust and allowing to limit interference that could degrade the audio signal. The front panel is covered with a tempered glass plate of the most beautiful effect and a 1.54" IPS screen, allowing you to display all the information related to the reading of your files (input, filter, sampling rate, read format...). The control is done simply with the two buttons on the front panel, allowing you to turn the device on/off, select an input, change the display color or choose an audio filter.
The back of the device contains all the connections. Toslink Optics, Micro USB (XMOS) and Coaxial are at the input. On the output side, the M300 offers either symmetrical XLR or asymmetrical RCA.
1Balanced XLR output
2Single ended RCA output
3S/PDIF Coaxial input
4Optical Toslink input
5Micro USB input
6Screen
7Sampling rate
8Power ON/OFF
Color selection
9Input selection
Filter selection
Product typeDAC
Inputs1x Micro USB XMOS
1x Optical Toslink
1x S/PDIF Coaxial
Outputs1x Single ended RCA
1x Balanced XLR
Output levelRCA : 2Vrms
XLR : 4Vrms
THD+N0.0004%
Dynamic rangeRCA : 120dB
XLR : 123dB
SNR116dB
USB compatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 or more
Linux
Sampling rate/ Bit depthUSB : Up to 32bit 768kHz / DSD512
Optique / Coaxial : Up to 24bit 192kHz
Consumption1.8W
Standby consumption< 0.1W
Dimensions (WxHxD)70 x 70 x 160mm
Weight500g
Power supply sold separately5V 3A with micro-USB
DAC / ADC ChipAK4497EQ
Max sampling rate768kHz
Max sampling rateDSD512
3 reviews
Excellent DAC
Bonjour,
Je cherchais depuis quelque temps un DAC avec la puce AKM. Ayant possédé une puce AKM depuis 2012 je trouvais son son particulièrement riche et très détaillé chose que j'avais perdu depuis le changement de mon lecteur réseau qui avait son propre Dac intégré. J'ai voulu tester la dernière version de cette puce l' AK4497 en commandant ce dac et j'ai attendu un bon mois avant de le recevoir mais cela en valait la peine c'est une merveille couplé à lecteur reseau bluenode 2i + ampli Musicalfidelity msi5 et paire de triangle c'est du bonheur. J'ai pu tester sur QUOBUZ jusqu'à 192 khz.
Je le recommande difficile de trouver mieux je pense.
Un détail dans tous les spectres une stéréo envoûtante c'est très musical. Mes quartets chantent à chaque morceau....
Bien sincèrement
This review has been posted for SMSL M300 DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Black
Super dac Akm
L attente à été un peu longue a cause d une rupture de stock une fois branché sur mon bluenode 2i c est une merveille supérieur à mon ancien dac et celui du blue node2i couple à mon m5si et triangle une merveille de précision et de dynamisme j ai écoute des sons j’usqu a 192 kHz je conseille ce produit
Question : l'alimentation ?
" Alimentation vendue séparément " Mais encore ? Aucune prise visible pour brancher une alimentation ... Par la prise microUSB ? Merci d'apporter quelques précisions .
Cordialement
Oui c'est en effet via la prise micro USB que vous alimentez cet appareil.
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi...
