SMSL M300 DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Red
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a digital-to-analog converter capable of reproducing your audio files with both a beautiful transparency and an astonishing sound richness.
Reference : 13975
249,00 €tax incl.
207,50 € tax excl.
This product has been replaced by the new version, the SMSL M300 MKII AK4497.
SMSL M300
SMSL M300 DAC AKM AK4497 XMOS Double Horloge NDK 32bit 768kHz DSD512 Rouge
AK4497 DAC & High-end components
The M300 is equipped with an AK4497EQ high-end DAC chip from AKM. The latter supports high sampling rates, in PCM up to 32bit 768kHz and in DSD up to DSD512. In addition, the chip uses the proprietary Velvet Sound architecture allowing it to provide a high SNR (128dB) and very low distortion (THD+N -116dB) for neutral and accurate reproduction, with a beautiful sound image.
This chip is combined with many quality components such as a second-generation XMOS USB interface, two ultra-low phase noise Japanese NDK clocks to significantly limit jitter on 44.1kHz / 48kHz and multiple frequencies, and finally a series of resistors and capacitors specially designed for audio use.
SMSL M300 DAC AKM AK4497 XMOS Double Horloge NDK 32bit 768kHz DSD512 Noir
Design, Screen & Connectivity
All components are integrated into a beautiful CNC machined Aluminium housing, both robust and allowing to limit interference that could degrade the audio signal. The front panel is covered with a tempered glass plate of the most beautiful effect and a 1.54" IPS screen, allowing you to display all the information related to the reading of your files (input, filter, sampling rate, read format...). The control is done simply with the two buttons on the front panel, allowing you to turn the device on/off, select an input, change the display color or choose an audio filter.
The back of the device contains all the connections. Toslink Optics, Micro USB (XMOS) and Coaxial are at the input. On the output side, the M300 offers either symmetrical XLR or asymmetrical RCA.
1Balanced XLR output
2Single ended RCA output
3S/PDIF Coaxial input
4Optical Toslink input
5Micro USB input
6Screen
7Sampling rate
8Power ON/OFF
Color selection
9Input selection
Filter selection
SMSL M300 review by Qobuz
" We really liked the fullness of the sound reproduction of the DAC S.M.S.L M300. The contribution of its various digital filters is interesting while preserving the excellent musical quality of this device. "
Test du SMSL M300 par Qobuz
Product typeDAC
Inputs1x Micro USB XMOS
1x Optical Toslink
1x S/PDIF Coaxial
Outputs1x Single ended RCA
1x Balanced XLR
Output levelRCA : 2Vrms
XLR : 4Vrms
THD+N0.0004%
Dynamic rangeRCA : 120dB
XLR : 123dB
SNR116dB
USB compatibilityWindows 7 / 8 / 8.1 / 10
Mac OSX 10.6 or more
Linux
Sampling rate/ Bit depthUSB : Up to 32bit 768kHz / DSD512
Optique / Coaxial : Up to 24bit 192kHz
Consumption1.8W
Standby consumption< 0.1W
Dimensions (WxHxD)70 x 70 x 160mm
Weight500g
ColorRed
Power supply sold separately5V 3A with micro-USB
DAC / ADC ChipAK4497EQ
Max sampling rate768kHz
Max sampling rateDSD512
ColorRed
2 reviews
Reçu le MKII à la place de celui-ci, incluant donc une télécommande et une alimentation dédiée qui a le mérite de libérer la prise micro usb. Le MKII perd en revanche une entrée en fusionnant optique et spdif en une seule jack / optique.
Cette première mouture est donc à choisir en fonction de ces critères : quelle entrée privilégiez-vous ?
Optique + coax (par exemple lecteur réseau + CD) : prenez celui-ci.
Usb (PC, ou NAS) ? Prenez le MKII.
Musicalement, pour ceux qui ont un DAC ou un ampli Hi Fi équipé du déjà excellent DAC AK 4490, cette évolution en conserve toutes les qualités. L’ajout de ses 6 filtres ne modifie pas la restitution de façon décisive.
This review has been posted for SMSL M300 DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Red
Great little cute balanced dac!
This is best dac what i have been encounter... Sound is bottom to all the way highs are so plesaure to hear! Very engage in sound!
The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi...
