The SMSL M8 is a high fidelity USB DAC that integrates an ES9018 K2M ESS converter and an XMOS Asynchronous USB interface.
It is therefore able to support PCM audio files up to 32bits 384kHz as well as DSD64 and DSD128 files.
Its high-quality OLED display is an advantage that provides a not insignificant comfort as regards the source selection and the type of files being decoded.
It is equipped with quality components and incorporates a high-precision clock.
Also, it allows you to configure the sound at your convenience via a selection of 7 different filtering modes.
Versatile, it can be easily integrated into your audio system not only with its formidable efficiency but also with its sleek design.
Characteristics :
- ESS Converter Saber ES9018 K2M
- Interface USB 2.0 XMOS Asynchronous
- Supports PCM audio files up to 32bit 384kHz
- Supports DSD 64 and 128
- High precision clock
- Ultra low jitter
- OLED display
- 7 selectable filtering modes
- THD + N: <0.0004%
- Output Level: 2.15Vrms
- Dynamic range:> 125dB
- Signal Noise Ratio:> 126dB
- Crosstalk:> 120dB
- Inputs: USB 2.0 Type B, Coaxial S / PDIF, Optical Toslink
- Analog stereo RCA output
- USB compatible with Windows, Mac OS, iOS, Android 4.0
- Playerrecommended: Foobar2000 on Windows and Pure Music on Mac OS for high resolution PCM playback and DSD 64/128
- Chassis Aluminum anodized Silver
- Dimensions: 120x90x35mm
- Weight: 600g
- 9V DC power supply and USB-A to USB-B cable included
