SMSL M8A V3 USB DAC ES9038Q2M 32bit 768kHz DSD XMOS XU208
SMSL offers a second modernized version of the M8A built around a chip DAC ES9038Q2M and the second generation of XMOS XCore 200 X208. Its design strictly adheres to current audio quality requirements, while facilitating easy installation with a compact sleek design and a very convenient connectivity panel.
4.5 / 5
By buying this product you get 22 loyalty points
Reference : 12934
229,00 €tax incl.
190,83 € tax excl.
M8A V3 by SMSL
32bit 768kHz DAC ES9038Q2M DSD512 - XCore200 Xu208 (2nd generation) -
M8AV2 SMSL Audio DAC Audiophonics
SMSL offers a second modernized version of the M8A built around a chip DAC ES9038EQM and the second generation of XMOS XCore 200 X208. Its design strictly adheres to current audio quality requirements, while facilitating easy installation with a compact sleek design and a very convenient connectivity panel.
DAC ES9038EQM Audiophonics SMSL
DAC ES9038EQM
Implantation of ES9038EQM DACchip significantly develops the capabilities of M8A since the previous version. The unit now accesses  Hyperstream II technology, which is usually dedicated to professional equipment.
This chip allows a DAC - if designed properly - to provide its user with a conversion of a remarkable smoothness while extending its capabilities to extreme sampling rates such as DSD512 and PCM 768kHz.
XMOS XCore U200 USB 2nd Generation
XMOS Xcore U200 v2
The USB interface XMOS Xcore U200 2nd gen, greatly contributes to the excellent specifications of the device. Especially with the support of the native DSD now complementing DOP transfer.
Every component involved in the process of analog conversion naturally benefits from a circuit specifically designed to enhance audio performance. Thus, it features a  ultra-low jitter clock  with a  low phase noise cristal. There are also low voltage drop (LDO) regulator chosen for their extremely low noise level.
The output stage uses an operational amplifier OPA1612 that ensures a clean and intelligible signal for the other elements of the chain, whether it be a pre-amplifier and furthermore or a simple active speaker.
Intuitive interface with integrated DSP presets
DAC with DSP compact SMSL
With its OLED screen and two only buttons, the interface of M8A is a model of simplicity. A button lets you navigate between the different options while the other allows the user to validate the choice.
The M8A offers plethora of options directly related to decoding techniques in order to refine your listening experience depending on the specificities of your sound system. Thus we find 10 DSP-type presets usually found among the most effective audio profiles. These add to traditional filters offered by high quality conversion chip such as the 9038EQM.
Simple to connect and easy to use
Connectors and Accessories M8A SMSL
Its USB inputs (high resolution XMOS), coaxial and optical allow it to gather all common digital audio sources (TV, computer, smartphone OTG, network player etc ...) on a single audio system.
The M8A comes with a range of accessories that will make most of its features immediately available. The package features a USB A / USB-B cable (computer) and a Micro-USB  / USB-C cable (Smartphone, tablets and OTG devices).
The dedicated power supply (Switching) is already provided, in addition to a USB-A adapter / Jack 5.5 / 2.5mm. These accessories are useful for standalone use or when the specifications of the audio source (especially laptops) are not enough to properly feed the DAC through USB-B alone.
A compact device
Dimensions M8A SMSL
The M8A V2 form-factor remains  extremely optimized, measuring only 90 x 122 mm to 22 mm high and 390 grams. With these very advantageous dimensions, intuitive interface and basic connectivity, the M8A V2 will easily find its place in any audio setup.
TypeDAC
InputsUSB
Optical
Coaxial
OutputsRCA Stereo
Dynamic15dB
THD + N0.0003%
USBXMOS (driver needed under windows)
Compatible 7-8-8.1-10 Windows / Mac OSX10.06
OTGSupported
Bit depth (USB)16/24/32 / 1bit
Freq. sample USB DSD28224/56448/112896/225792 MHz
Freq. USB PCM sample44.1 / 48 / 88.2 / 96 / 176.4 / 192 / 352.8 / 384 / 705.6 / 768 kHz
Freq. sample Coaxial / Optical44.1 / 48 / 88.2 / 96 / 176.4 / 192 kHz
Power SupplyDC 5V
Consumption0.35W
Quiescent - 0.03W
Level RCA output2Vrms
Dimensions120 x 98 x 22 mm
Accessories:male USB-B cable  / male USB-A
male USB-B cable / male Micro-USB
male USB-A cable / male 5.5-2.5  Jack
Switching power supply 5V & power cable
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rate768kHz
Download
4 reviews
ravi
Acheté en remplacement du M8 première version (ES9018) qui m'a lâché après 5 ans de loyaux services, ce petit dac avec son alim externe SMSL P1 redonne un vrai peps et de l'aération à mon installation hifi fixe. Vraiment ravi de cet achat.
This review has been posted for SMSL M8A V3 USB DAC ES9038Q2M 32bit 768kHz DSD XMOS XU208
smsl m8a v3
Bonjour,au vu de la similitude des composants avec khamas tone board,j'ai voulu essayé ce DAC,le comparer au sanskrit 10° anniiv(que j'ai achete sur ce site ily a qqs mois).
Whaou!!quel bon en avant,quel naturel.....Superbe...Merci Audiophonics!
Un rapport qualité prix imbattable
Je trouve Hervé un peu sévère avec se tout petit dac ,j,ai eu l'occasion chez un ami de le comparer à un convertisseur TOTALDAC qui valait 20 fois son prix et la différence d'écoute
je vous l'assure n'était pas abyssale loin de là !
Nous avions fini par en conclure que ce petit smsl pouvait aller jouer dans la cour des grands même à 20 fois moins cher!
Exceptionnel qualité pour ce prix !
Un bon petit DAC
Qu'il est petit! Il ne faut pas compter sur lui pour masquer les câbles qui se promènent derrière. Prévoyez plutôt un truc un peu lourd a placer dessus pour éviter que le poids de la connectique ne fasse lever le nez.
Pour le tarif, ce DAC est recommandable. Beaucoup d'énergie sur toute la bande, et peut être un tout petit peu trop dans le haut, mais rien d'affreux pour du ESS. C'est étonnement bon. Il y a beaucoup de filtres disponibles mais chez moi le FAST MINIMUM sort tellement du lot que je me demande pourquoi les autres sont proposés.
Par contre, on ne gagne pas sur tous les tableaux, même avec une alimentation linéaire, la scène manque de profondeur. Cela serait surement moins ressenti sur un appareil moins précis par ailleurs, mais ici la grande netteté et le placement latéral hyper précis laissent tout le loisir de constater avec évidence ce manque d'aération et de profondeur.
Je nuance ma critique en mentionnant que mon DAC précédent (Audiolab M-DAC)qui était particulièrement performant sur cet aspect de profondeur coutait entre 800 et 900€ et que sur certains points ils était moins bon que ce petit smsl.
SMSL offers a second modernized version of the M8A built around a chip DAC ES9038Q2M and the second generation of XMOS XCore 200 X208. Its design...
