Topping D20 DAC Optical / Coaxial / USB 24Bit / 96Khz PCM1793
Reference : 8460
129,00 €tax incl.
107,50 € tax excl.
Topping D20 USB DAC PCM1793 / OPA2134 24Bit / 96Khz
The D20 is a versatile digital analog converter that accept both optical digital inputs, USB, coaxial.
This DAC does not require any software installation for use with a computer.
"A very good small DAC based on PCM1793 and opa 2134. Very good manufacture with an aluminum case and components of good quality including Nichicon capacitors, a rather" laidback "sound with good basses rather round. small separate power supply in 15v and a basic USB cable One of the revelation 2012/2013.
Onlyfault, a USB input chip a little aging the Ti pcm2704. But at the price where it is proposed and seen the sound benefits and the quality of passive components of good level, it is a lesser evil. A good DAC with proven solutions. "
Features:
  • DAC: DIR9001 + PCM1793
  • Output Voltage 2Vrms
  • THD: 0.0013% at 1kHz
  • Output impedance: 200 ohm
  • USB interface PCM2704
  • Sampling rate: 44.1, 48kHz and 96kHz (44.1 kHz-48 kHz for the USB input) - 16bit-24bit (16 bits for the inputUSB connection)/ Li>
  • Power Outlet (5.5mm / 2.1mm) x 1
  • DC Power Supply 15V1A
  • Entries:
    • coaxial RCA IN (SPDIF) x 1
    • optical IN (SPDIF) x 1
    • USB IN x 1
  • Exits:
    • Audio OUT RCA (left / right) x 1
  • Dimensions: 45 H x 115 L x 200 D
  • Weight: 530g
Electronic Components:
  • Resistance KOA
  • nichicon FW Capacity
  • ERO Capacity
  • EPCOS Capacity
  • TOSHIBA Transistor
  • Burr-Brown OPA2134
  • PCM 2704
Package Contents:
  • 1x D20
  • 1x Adapter 15V1A
  • 1x USB cable
  • User manual
https://www.audiophonics.fr/images2/8460/8460_topping_dac_d20_usb_2.jpg
https://www.audiophonics.fr/images2/8460/8460_topping_dac_d20_usb_3.jpg
https://www.audiophonics.fr/images2/8460/8460_topping_dac_d20_usb_4.jpg
https://www.audiophonics.fr/images2/8460/8460_topping_dac_d20_usb_1.jpg
https://www.audiophonics.fr/images2/8460/8460_topping_dac_d20_usb_5.jpg
