XDUOO MU-601 USB DAC ES9018K2M XMOS XU208 32bit 384kHz DSD256
xDuoo offers with the MU-601 a small USB DAC, both affordable and efficient. If it remains relatively simple, it uses however quality components, like a DAC ES9018K2M or a USB XMOS interface, allowing to read high resolution audio streams and to deliver a precise sound restitution.
Reference : 15788
119,00 €tax incl.
99,17 € tax excl.
xDuoo MU-601
xDuoo MU-601 DAC USB ES9018K2M XMOS XU208 32bit 384kHz DSD256
ES9018K2M DAC
The digital to analog conversion stage of the xDuoo MU-601 uses an ES9018K2M DAC chip. Used in many HiFi audio devices, it ensures a high SNR and a very low THD+N level. Measures that allow a transparent sound restitution.
USB XMOS Interface
The MU-601 adopts an excellent USB XU208 interface, which enables efficient asynchronous signal transmission, reducing jitter. In addition, it supports high resolution files, up to 32bit 384kHz PCM and DSD256.
Two USB modes for maximum compatibility
On the back of the MU-601, a switch allows you to select the USB mode of the device, either USB 1.0 or 2.0. This feature ensures maximum compatibility, regardless of the device associated with the MU-601.
After changing the USB mode, it is necessary to switch the MU-601 off and on again so that it takes into account the new configuration.
Dual clock
The MU-601 integrates two high quality oscillators as clock sources, one operating at 44.1k, the other at 48k and their respective multiples. These clocks allow a very good synchronization of the signals and thus a reduction of the jitter.
A neat power supply
The power supply stage of the MU-601 also benefits from a nice design. It features large Rubycon capacitors for filtering, providing a clean and stable power supply for the audio circuits.
Product typeDAC
Inputs2x USB-C
Outputs1x Coaxial
2x Stereo RCA
DAC chip1x 9018K2M
DSD (Native/DoP) up to DSD256
DXD up to 32bit 384kHz
Output levelCoaxial : 0dBfs
RCA : 2V
SNR115dB
Crosstalk115dB
USB CompatibilityWindows 7 / 8 / 10
Mac OS X
iOS
Android
Linux
Supply voltage12VDC 2A
Housing materialAluminum
Dimensions120 x 96 x 42mm
Weight380g
ColorGray
Package1x xDuoo MU-601
1x USB-C cable to USB-A
1x Power supply
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
xDuoo offers with the MU-601 a small USB DAC, both affordable and efficient. If it remains relatively simple, it uses however quality components,...
