FIIO M15 Digital Audio Player DAP Android Hi-Res 2x AK4499EQ Exynos 7872 XMOS Bluetooth WiFi 32bit 768kHz DSD512
The FiiO M15 is a resolutely high-end portable audio player (DAP), integrating the best of today's components to ensure unbeatable sound reproduction. Whether you are at home or on the go, the M15 will accompany you in your listening and allow you to rediscover your favourite tunes.
By buying this product you get 139 loyalty points
Reference : 14363
1 399,00 €tax incl.
1 165,83 € tax excl.
FiiO M15
FiiO M15 Baladeur DAP Android Hi-Res 2x AK4499EQ Exynos 7872 XMOS Bluetooth WiFi 32bit 768kHz DSD512
Test By Audio Science Review
Overall, the Fiio M15 manages to best just about any dongle or phone you would use instead of it and handily so. So I am going to put it on my Recommended list.
 test by the measurement forum Audio Science Review
Dual AK4499EQ DAC
The AK4499EQ is the flagship of the 3rd generation DAC AKM. With 4 channels per chip, an improved architecture and the use of the LSI manufacturing process, these chips offer incredible performance. The DAC is capable of decoding sample rates up to 32bit 768kHz and DSD512 and offers a signal-to-noise ratio of 140dB and a THD+N of -124dB.
xxx
xxx
XMOS XUF208 USB Interface
When used in USB DAC mode, the M15 takes advantage of the performance of its XMOS XUF208 USB interface. This contributes to the quality of DAP playback and also supports sample rates up to 32bit 768kHz and DSD512.
Qualcomm CSR8675 Bluetooth Receiver/Transmitter
The M15's Bluetooth receiver chip, a Qualcomm CSR8675, the manufacturer's premium model, enables high-quality Bluetooth transmission. It enables stable and fast broadcasting, including support for the aptX, aptX, LDAC and HWA codecs for superior listening quality.
xxx
xxx
Exynos 7872 CPU
Navigation within the M15 interface is perfectly fluid, using an Exynos 7872 processor. This one integrates 2 A73 cores and 4 A53 cores. 3GB of RAM are associated with it with also 64GB of storage and the possibility to add a Micro SD card (up to 2TB). The M15 also allows dual band 2.4/5GHz WiFi transmission.
xxx
Femtosecond NDK Crystals
The M15 incorporates two custom NDK femtosecond oscillators, ensuring a phase noise of only -140dBc/Hz @ 1kHz offset. These oscillators are coupled with a 3rd generation FPGA to further lower the jitter and provide the DAC with the most accurate clock signal.
3rd génération FPGA
This 3rd generation FPGA specially developed by FiiO uses more powerful algorithms and more accurate clocks to reduce jitter as much as possible.
xxx
xxx
High quality components
The entire system benefits from a high-quality design, using only high-end components. These include ultra low noise resistors with a tolerance of 0.1% or dedicated audio capacitors (4 low-loss polymer tantalum capacitors, 4 Panasonic electrodeless film capacitors and 8 film capacitors). The M15 also has a large energy reserve thanks to 28220µF on low-loss polymer capacitors and 5100µF on high-voltage capacitors.
Compete with the best smartphones
The M15 has no trouble competing with or surpassing the best smartphones on the market. It features a thick 8-layer PCB with gold circuitry, optimizing available space and canceling interference between the analog and digital stages, including independent shielding and 2.4GHz wave-absorbing material. Heat dissipation is also optimized thanks to Silicone and Graphene thermal conductors, as well as Copper-Nickel-Zinc alloy heat sinks.
xxx
Balanced architecture
FiiO's DAP uses a symmetrical architecture to ensure incredibly detailed playback without sacrificing dynamics. Within this architecture, two high-precision low noise PDOs OPA221 for the low-pass filter, four PDOs OPA1612 for the IV conversion, and one PDO OPA1622 for the amplification of each channel.
xxx
Servo active technology
For the first time, FiiO integrates Active Servo Power technology into the final amplifier stage, allowing you to tailor the output power according to your preferences. When used with EMI, you can set the M15 to optimize its noise level. On the contrary, if you wish to use 300Ω headphones, you can activate the Big Driver Mode to take advantage of a large power reserve.
xxx
An important energy reserve
The M15 is ready to go with any helmet, being able to deliver a lot of power. Under 32Ω, the DAP can output 490mW asymmetrically and 800mW symmetrically. Under 300Ω, it can deliver 70mW asymmetrical and 275mW symmetrical.
xxx
xxx
An exceptional restitution
The M15 offers a restitution of great transparency and depth thanks to a noise threshold of 2.1µF, a distortion level of 0.0004% and an SNR of 122dB.
Substantial autonomy
With a 7490mAh battery, the M15 has a long battery life of more than 15 hours in playback and up to 1800 hours in standby. In addition, the device supports qC2.0, MTK PE and USB PD fast charging.
xxx
xxx
5th generation design
The M15 represents the 5th generation of the design already used by models such as the Q1 Mark II, the K3 or the K5 Pro. The right and left sides are concave to make it easier to handle.
Analogue volume potentiometer
The ADC reconstruction curve used by the M15 solves problems often associated with analog potentiometers such as a lack of imbalance in the balance between the left and right channels. The volume knob is also equipped with a LED whose light intensity can be adjusted.
xxx
xxx
Corning Gorilla Glass screen
The M15 is equipped with a beautiful 5.15" Corning Gorilla Glass IPS display with a resolution of 1440x720px, a pixel density of 312PPI and capable of displaying 16.7 million colours.
Customizable multifunction button
FiiO's DAP has a button on its side that can be customized according to your needs, for quick access to your favorite features.
xxx
xxx
MQA 8x Decoding
The M15 supports 8x AQA file decoding for exceptional audio quality.
Product typeDAP
CPUExynos 7872 14nm, 6 coeurs, 2GHz (A73 x 2), 1.6GHz (A53 x 4)
RAM3GB
ROM64GB
DAC chip2x AKM AK4499EQ
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512 natif
MQA 8x
Connectics / ConnectivityUSB-C
Bluetooth
Micro SD (Max. 2TB)
1x Headphone/Line/SPDIF Jack 3.5mm output
1x Balanced headphone Jack 2.5mm output
1x Balanced headphone Jack 4.4mm output
USB InterfaceXMOS XUF208
Bluetooth chipCSR8675
Supported Bluetooth codecsHWA, LDAC, aptX HD, aptX, SBC
WiFi2.4GHz / 5GHz
FPGA chipA3P030
Supported wifi transmission protocolAirPlay
DLNA
UpNP
FiiO Link
Amplification2x PA2211
4x OPA1622
4x OPA1612
Clocks2x Femtosecond NDK crystals
Tactile screenIPS Hi-Res 5.15", 16.7M colors, 1440x720px, tactile 10 points, Corning Gorilla Glass, 312PPI
Battery7490mAh 3.8V, Li-polymer
Charging timeQuick charge < 3.5h (12VDC 1.5A)
Autonomy> 15h (single-ended output)
> 9h (balanced output)
Output power490mW @ 32Ω, single-ended, big driver mode
70mW @ 300Ω, single-ended, big driver mode
800mW @ 32Ω, balanced, big driver mode
280mW @ 300Ω, balanced, big driver mode
Frequency response20Hz - 90kHz (-3dB)
SNR≥ 122dB (A-Weighted)
Noise floorHeadphone output: < 2.1µV (A-Weighted)
Balanced output : < 4µV (A-Weighted)
Output impedance< 1.1Ω (charge 32Ω)
THD+N< 0.0004% (1kHz / 10kΩ)
Volume controlAnalog
Recommended headphone impedanceJack 3.5mm Headphone output : 16~150Ω
Sortie symétrique Jack 2.5mm/Jack 4.4mm : 16~600Ω
Equalizer10 bands (±12dB)
8 presets
Customizable EQ
Gain controlLow
High
Over-Ear headphone modeON / OFF
Balance adjustmentL10~R10 (0.5dB par pas)
Line output level2.1V
Channel separation> 107dB
Dimensions134 x 75 x 18mm
Weight307g
InputWiFi
InputMicro SD
OutputJack 2.5mm
OutputBluetooth
OutputJack 3.5mm
OutputJack 4.4mm
OutputWiFi
DAC / ADC ChipAK4499
Max sampling rate768kHz
Max sampling rateDSD512
The FiiO M15 DAP and Audiotechnica ATH-AP2000Ti
The FiiO M15 DAP and Audiotechnica ATH-AP2000Ti headphones deliver great, reach, beautiful sound. It looks like they made for each other.
This review has been posted for FIIO M15 Digital Audio Player DAP Android Hi-Res 2x AK4499EQ Exynos 7872 XMOS Bluetooth WiFi 32bit 768kHz DSD512
The FiiO M15 is a resolutely high-end portable audio player (DAP), integrating the best of today's components to ensure unbeatable sound...
