FIIO M9 Digital Audio Player DAP 2x AK4490EN WiFi Bluetooth aptX-HD LDAC HWA Balanced 32bit 192kHz DSD128 Black
The FiiO M9 is a complete, high-performance and ergonomic digital music player at an affordable price. Featuring high quality circuitry for rich and accurate sound reproduction and a design that is both aesthetically pleasing and practical, it is the perfect companion for enjoying your music on the go and at home.
Reference : 14852
299,00 €tax incl.
249,17 € tax excl.
FiiO M9
Digital Audio Player DAP 2x AK4490EN WiFi Bluetooth aptX-HD LDAC HWA Symétrique 32bit 192kHz DSD128
FiiO M9 Baladeur Numérique DAP 2x AK4490EN WiFi Bluetooth aptX-HD LDAC HWA Symétrique 32bit 192kHz DSD128
Multi-purpose
The M9 has been designed to provide all of the features that users may desire and that are rarely found as comprehensively in most other DAPs on the market. For example, it supports Bluetooth transmission and the associated HWA, aptX, aptX-HD and LDAC protocols, including USB DAC mode. It is also compatible with WiFi and its audio circuits are not to be outdone in order to ensure the best possible sound reproduction. All integrated in a beautiful chassis.
The FiiO M9 supports Bluetooth 4.2 and all available transmission codecs, including high resolution, such as aptX-HD 24bit, LDAC or HWA. These will allow you to enjoy a high quality Bluetooth listening experience.
Bluetooth Amplification
In Bluetooth receive mode, the M9 turns into a high-quality Bluetooth amplifier, providing better frequency response, lower distortion, background noise and crosstalk than conventional Bluetooth solutions. In addition, it is possible to output the signal received in Bluetooth via the Coaxial output to an external decoder.
Dual AK4490EN DAC
FiiO's player conversion stage uses two DAC AKM AK4490EN DAC chips to achieve a high signal-to-noise ratio, excellent dynamic range and low distortion for high-precision playback.
Dedicated FPGA and DSD128
These DACs are associated with a high-performance A3P030 FPGA, ensuring accurate reading by stabilizing the digital clock signal. The FPGA also decodes DSD64/128 audio streams, which the M9 supports in ISO, DFF and DSF formats.
8 Layers PCB
For the first time, FiiO uses in its M9 a 8 layers HDI (High Density Interconnect) PCB with a thickness of only 0.08mm. This makes the PCB more complex, but also allows to integrate more components in a limited space and thus to have a compact device.
Balanced and Single-ended circuit
The audio circuitry, particularly well thought out, integrates balanced and unbalanced outputs. An AOP TIP OPA1612 is used as a low-pass filter, where an AOP TI OPA1622 functions as a current buffer. Two AOP OPA1622 allow them to deliver a power of 77mW under 300Ω (balanced output).
WiFi & Streaming
No more need for cables, the M9 allows you to transfer your music directly to WiFi. If you want to listen to files stored on your computer, the DLNA is also present. The DAP is also compatible with many audio streaming applications.
Autonomy
Under normal use, the autonomy of the M9 is about 10 hours. In standby, its battery will last for 45 days.
Balanced output
The M9 is compatible with the vast majority of headphones on the market. It has both an unbalanced output on 3.5mm jack and a balanced output on 2.5mm jack. It also supports CTIA controls for the remote controls integrated in the headphones and earphones.
Note: For Apple headphones, only the Play/Pause functions of the remote controls are supported.
LED Indicator
The front panel of the FiiO M9 integrates an RGB LED indicator behind the brand logo, indicating the type of file being played or whether the device needs to be recharged.
USB DAC Function
The M9 can be used as an asynchronous USB DAC with a Windows or Mac OS computer to take advantage of its conversion stage. The M9 can then also function as a Bluetooth transmitter for your computer to send an audio stream to a Bluetooth headphone.
USB Audio & Coaxial Output
The M9 has a USB audio output with DoP/D2P support. It is also one of the few DAPs that can receive an audio stream via Bluetooth and then output to a Coaxial SPDIF output.
Custom OS
The M9 is powered by an Android operating system fully customized by the brand. It allows a fast and intuitive navigation thanks to a user experience thought out in every detail. It is also possible to install third-party applications such as Qobuz, Spotify, Deezer, Tidal, Roon or Bandcamp.
Design
The M9's aluminum chassis gives it a refined and ergonomic design, allowing for a comfortable grip. The volume control knob allows precise control of the sound level and all buttons are easily accessible.
LG IPS Touchscreen
The front of the M9 is dressed with a beautiful 3.2" IPS touch screen from LG, capable of displaying 16 million colors and supporting 5 point multi-touch. It will allow you to easily navigate through the various menus of the DAP.
Type-C USB
The FiiO M9 uses a USB-C connector allowing it not only to be used as a USB DAC but also to output digital audio streams to other devices. It is also this USB-C connector that allows you to load the DAP or manage its stored files when connected to a computer.
Storage
The M9 comes with 2GB of storage space, so you can already store a lot of audio files. This can be extended up to 2TB using a Micro SD card (not included). Ideal, especially if you want to enjoy high-resolution files.
Hi-Res Audio
The M9 is Hi-Res Audio certified by the Japan Audio Society. This label is awarded to devices capable of delivering a sound quality superior to that of CD, and therefore supporting, at least, files encoded in 24bit.
Product typeDigital audio player (DAP)
Connectors / ConnectivityBluetooth
WiFi
1x Two-way USB-C
1x Micro SD slot (up to 2TB support)
1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 2.5mm headphone output
Line Output / SPDIF OutputShared on Jack 3.5mm
OSAndroid custom
CPUExynos 7270 14nm
Dual Core
1GHz
RAM768MB
ROM4GB (2GB available for the user)
DAC2x AK4490EN
FPGAA3P030
LPFOPA1612
BUF2x OPA1622
Bluetooth chipSamsung S5N5C10B01-6330
BatteryLi-Polymere 2350mAh
Charging time< 2h (5VDC 2A)
AutonomySleep mode: 45 jours
Jack 3.5mm output > 10h (Volume 46, Screen OFF, EQ OFF, 27Ω load, MP3 16bit 44.1kHz)
Jack 2.5mm output > 9h (Volume 48, Screen OFF, EQ OFF, 27Ω load, 16bit 44.1kHz)
Bluetooth output (SBC) > 30h (Volume 60, Screen OFF, load BTR1+FH1, MP3 16bit 44.1Hz)
ScreenMulti-touch touchsreen
3.2"
Number of colors : 16M
IPS LG
480 x 800px
Pixel density : 292ppi
Bluetooth version4.2
Supported Bluetooth codecsSBC, aptX, aptX HD, LDAC, HWA
WiFi2.4Ghz
Supported WiFi protocolsDLNA
AirPlay
Recommended headphone impedance16-300Ω
EQ10 bands (±6dB)
9 Presets
Customizable profile
Gain controlLow / High
Balance±5dB
Supported sampling rates (USB)PCM up to 32bit 192kHz
DSD up to DSD128
DoP/D2P
Firmware upgradeVia zip file or OTA
THD+Nline output: < 0.002% (1kHz, 10Ω)
Jack 3.5mm output : < 0.002% (1kHz, 32Ω)
Jack 2.5mm output : < 0.002% (1kHz, 32Ω)
SNRLine output : ≥ 117dB (A-Weighted)
Jack 3.5mm output : ≥ 118dB (A-Weighted)
Jack 2.5mm output : ≥ 113dB (A-Weighted)
Frequency response5Hz - 80kHz (-3dB)
Noise floorLine output : < 5µV
Jack 3.5mm output : < 5µV
Jack 2.5mm output : < 10µV
Channel separationLine output : > 105dB
Jack 3.5mm output : > 72dB
Jack 2.5mm output : > 98dB
Line level2V
Jack 3.5mm headphone power (single-ended)≥ 125mW @ 16Ω, THD+N < 1%
≥ 170mW @ 32Ω, THD+N < 1%
≥ 19mW @ 300Ω, THD+N < 1%
Jack 2.5mm headphone power (balanced)≥ 125mW @ 16Ω, THD+N < 1%
≥ 195mW @ 32Ω, THD+N < 1%, Balanced Turbo OFF
≥ 220mW @ 32Ω, THD+N < 1%, Balanced Turbo ON
≥ 24mW @ 300Ω, THD+N < 1%, Balanced Turbo OFF
≥ 77mW @ 300Ω, THD+N < 1%, Balanced Turbo ON
Output impedanceJack 3.5mm output : < 2Ω
Jack 2.5mm output : < 2Ω
Max output voltageJack 3.5mm output : 6.5Vp-p
Jack 2.5mm output : 7.07Vp-p
Supported file formatsDSD64/128 (.iso, .dsf, .dff)
APE (Fast) : 24bit 192kHz
APE (Normal) : 24bit 192kHz
APE (High) : 24bit 192kHz
APE (Extra High) : 24bit 48kHz
APE (Insane) : 24bit 48kHz
FLAC : 24bit 192kHz
WAV : 64bit 192kHz
AIFF : 24bit 192kHz
AIF : 24bit 192kHz
WMA Lossless : 24bit 96kHz
Apple Lossless : 24bit 192kHz
MP3
OFF
WMA
ACC
Load voltage / current5V 2A
Dimensions60 x 106 x 13.3mm
Weight133g
Package
1x FiiO M9
1x TPU case
1x Tempered glass screen protection
Distortion Curve 1
Test condition: Sinusoidal signal -5dB, 3.5mm jack headphone output (load 32Ω)
Distortion Curve 2
Test condition: Sinusoidal signal -5dB, 3.5mm jack line output (load 10kΩ)
Distortion Curve 3
Test condition: Sinusoidal signal -5dB, balanced 2.5mm TRRS jack headphone output (load 32Ω)
Frequency response curve 1
Blue curve: Left channel
Red curve: Straight channel
Frequency response curve 2
Frequency response curve 3
Input
  • Bluetooth
  • USB
  • WiFi
Output
  • Bluetooth
  • Jack 2.5mm
  • Jack 3.5mm
  • USB
DAC / ADC Chip
  • AK4490EQ
Max sampling rate
  • 192kHz
  • DSD128
Color
  • Black
FiiO support review
I am writing this review before even receiving the item. Every question I asked to support@fiio.com to receive technical clarifications prior to my purchase, has been fully and very timely answered. Very professional, and reason to buy FiiO products .
Congratulations to FiiO support team.
This review has been posted for FIIO M9 Digital Audio Player DAP 2x AK4490EN WiFi Bluetooth aptX-HD LDAC HWA Balanced 32bit 192kHz DSD128 Black
The FiiO M9 is a complete, high-performance and ergonomic digital music player at an affordable price. Featuring high quality circuitry for rich...
