By buying this product you get 39 loyalty points
Discover the most innovative DAP on the market, the Fiio X5 3rd Gen ! The FiiO X5 3rd Gen is the ultimate in versatility in the range of portable digital players of the brand that has already proved many times its know-how in the field of Digital Audio Player.
Based on TWO AKM AK4490 converters combined with a RK3188 processor, it is extremely efficient and can achieve record sampling rates of32Bit / 768kHz.
With a touchscreen (16.7 million colors) IPS TFT (3.97 ") of a great definition, it is easily imposed in the category of DAP whose interface FiiO Music is very pleasant to use and particularly intuitive.
Il can also act as <strong> DAC USBhigh-quality audio to enjoy your digital sources on your home audio systems, with sampling rates up to 24 Bit / 192kHzin this DAC mode.
It is a complete HiFi player capable of playing almost all PCM audio files up to 32bit 768kHz (APE / FLAC / ALAC / WMA / WAV / MP3) as well as DSD natively and ISO SACD files.
It hastransmissionBluetooth 4.0 Apt-X Low Latencyand theDLNA / WIFI 2.4GHzas well as wired via Micro USB 2.0.
Its amplification stage is composed of very low distortion AOP OPA1642 and OPA1612 (for the filtering stage LPF).f = "https://www.audiophonics.fr/fr/amplifier-casque-sedentaire-c-645.html" target = "_ blank">Headphone Amplificationapplied gives a great dynamics and a pleasant precision in the bottom of the spectrum.
The 3rd X5 uses two "Crystal oscillators"One for the DSD and 44.1 / 88.2 / 176.4 / 352.8kHz, and the other for the 48/96/192 / 384kHz rates. This guarantees for all sampling rates a very low Jitter, Clock accuracy still improved, more stable operation, and virtually no artificial conversion of sampling frequency.
Finally this audiophile player works under 2 modes:Pure MusicorAndroid 5.1. In the latter mode, the DAP is compatible with audio streaming applications such asQobuz, Spotify, Deezer, etc ... Under the Pure Music mode the Fiio X5 3rd uses your internal storage or your cards Micro SD to play the available music.
Technical characteristics :
Main Features :
Output | Jack 3.5mm |
Output | Jack 2.5mm |
Output | Coaxial SPDIF |
DAC / ADC Chip | AK4490 |
Max sampling rate | DSD128 |
Max sampling rate | 768kHz |
Color | Titanium |
