FiiO X7 HiFi DAP DAC DSD ISO SACD 32bit/384kHz ES9018S 32G
4.0 / 5
Reference : 10346
699,00 €tax incl.
582,50 € tax excl.
DAP, the FiiO X7 is the spearhead of the range of portable digital players of the brand that has already proved its expertise in the field with its predecessors.
Based on an ESS ES9018S Saber converter coupled with a 1.4GHz RK3188 processor, it is extremely efficient.
Equipped with a touchscreen (16 million colors) IPS 480x800p / 233ppi (3.97 ") of a very high definition, it is easily imposed in the category of DAP whose interface FiiO Music is very pleasant to use and particularly intuitive.
hecan also act as a high-quality USB DAC to enjoy your audio sources on your home Audio systems.
heis compact, lightweight and equipped with a high power supply for a general improvement in sound performance.
It is a complete HiFi player capable of playing virtually all PCM audio files up to 32bit 384kHz (APE / FLAC / ALAC / WMA / WAV / MP3) as well as native DSD and ISO SACD files.
It features Bluetooth V4.0 + EDR and Dlna / WIFI 2.4GHz transmission systems as well as wired via Micro USB 2.0.
Its amplification stage is composed of AOP AD8397 and OPA1612 with very low distortion (for the filter stage (LPF).
The applied headphone amplifier stage offers great dynamics and pleasant precision at the bottom of the spectrum.
Finally this audiophile walker running under Android will probably be compatible with audio streaming applications like Qobuz
Nomadic Test of the FIIO X7.
DSDISO SACD
Features:
  • Processor Rockchip RK3188 1.4GHz
  • DAC Saber ESS ES9018S
  • Lossless, FLAC, ALAC, DXD 352.8kHz, DSD64, DSD128 (.iso, .dsf, .dff)
  • Supported compression files: MP2, MP3, AAC, WMA, OGG
  • AOP Burr-Brown OPA1612, Analog Device AD8397
  • High-precision clock
  • RAM: 1GB
  • Memory (ROM): 32GB (up to 128GB via microSD not included)
  • Wireless transmission Bluetooth V4.0 2.4GHz + EDR, WIFI 802.11 b / g / n 2.4GHz
  • Impedance Recommended headphones: 16 to 300 Ohm
  • Analog output / headphone output: 3.5m jackm
  • LINE / Coax output: 3.5mm jack
  • Micro USB 2.0 port
  • Output Impedance: <0.2 Ah (32 Ohm)
  • 10-band digital equalizer (+/- 6dB) integrated
  • Volume control: 120 levels per PGA2311
  • Gain: 0-6 dB
  • THD line output: <0.007% (1 kHz)
  • THD + N headphone output: <0.0008% (1kHz)
  • Frequency response: 20Hz - 20KHz (+/- 0.1)
  • Crosstalk : > 110dB at 1kHz
  • Signal Noise Ratio:> 115dB
  • Dynamic range:> 115dB
  • Line Output Level:> 1.47Vrms
  • Output voltage max:> 5.2 Vp-p
  • Output Current Max: 250mA
  • Power supply: 5V DC 2A recommended
  • Capacity of the battery: 3.7V 3500 mAh
  • Autonomy: 9 h
  • Charging time: 4 h
  • Touch Screen 3.97 "/ 400x800p 233ppi IPS 16 million colors
  • Case 100% Aluminum machined CNC anodized Titanium
  • Output power 1:> 200 mW under 16Ω THD <1%
  • Output power 2:> 100 mW at 32Ω
  • Output power 3:> 10 mW at 300Ω
  • Weight: 220g
  • Dimensions: 130x64x16.6mm
  • Comes with cover, screen protector, micro USB cable and coaxial cable 3.5mm Jack
[Img-13602-left-thickbox_default]
[Img-13603-left-thickbox_default]
[Img-13604-left-thickbox_default]
[Img-13605-left-thickbox_default]
[Img-13606-left-thickbox_default]
[Img-13607-left-thickbox_default]
[Img-13608-left-thickbox_default]
[Img-13609-left-thickbox_default]
[Img-13610-left-thickbox_default]
[Img-13611-left-thickbox_default]
Illustration on Dock desktop not included.
Excellent produit
Son très bon mariage impécable avec mes EM32, encore quelques bugs et on attend de nouveau modules d'amplification et nouveau firmware. Vraiment très content de mon achat. Rien à dire sur Audiophonics nickel sur la commande.
This review has been posted for FiiO X7 HiFi DAP DAC DSD ISO SACD 32bit/384kHz ES9018S 32G
