The nomadic FIIO X7 Mark II portable music player is now equipped with the 32GB ESS SABRE DAC ES9028 PRO, OPA926 AOP analog amplifiers. It thus gets even closer to the reproduction quality of a high-fidelity salon source in an aluminum case with its anti-reflective touch screen of 480x400 pixels.
Real evolution of Fiio X7 of origin, it progresses with the interface Android 5.1 for an even more fluid navigation. Its internal capacity goes from 32 to 64GB expandable by two Micro SDcard slots up to 256GB each, or 576GB total storage (19000 pieces of lossless music on average).
True High Definition Player, this high-end DAP offers three separate clocks of high precision (45.1584Mhz for the DSD and the 44.1 Khz, 49.125Mhz for the 48khz and 100Mhz for the 384Khz). These higher clock frequencies than the old model guarantee increased accuracy and extremely low jitter. The X7 Mark II also uses an optimized version of Android 5.1 "pure music mode" avoiding manipulations of Android Upsampling.
hecan also be used as a high-quality 192Khz 24k DAC USB to enjoy your audio sources on your main Hi-Fi system. Conversely, it can also be used as a digital USB interface to SPDIF / optical with a Toslink mini 3.5 / mini jack.
ThisNative DSD and ISO SACD files can play virtually all PCM audio files up to 32bit 384kHz (APE / FLAC / ALAC / WMA / WAV / MP3).
To perfect the sound quality of thisDAP, the FIIO X7 Mark II is delivered with the AM3A amplifier module.
This module has two analog ADF Studio JFET AD8620 coupled to two OPA926 exclusively modified for FIIO.
This module also provides a balanced balanced output for high-end headphones on TTRS 2.5mm jacks, increasing the signal-to-noise ratio to 119dB. Of course the optional modules AM0, AM1, AM2, AM3, AM5 are compatible. This DSP 32 bit 384Khz is controllable as a living room reader with optional remote control FIIO RM1, compatible with the DOCK DK1 multifunction and FIIO K5.
Thanks to its Android OS 5.1 by accessing the Goggle Play Store, the FIIO X7 Mark II is compatible with Qobuz, Spotify ou Deezer.
Input | WiFi |
Input | Micro SD |
Input | Bluetooth |
Output | Coaxial SPDIF |
Output | Bluetooth |
Output | Jack 3.5mm |
Output | Jack 2.5mm |
DAC / ADC Chip | ES9028PRO |
Max sampling rate | DSD128 |
Max sampling rate | 384kHz |
Color | Titanium |
