Installé dans une DS7 crossback comme bibliothèque musical.
Connecté en bluetooth, fonctionne très bien.
DAP Digital HiFi Music Player DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Black
With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player supports high sampling rates (Hi-Res) and Bluetooth aptX for more convenient use. Hidizs has integrated many features into its DAP for a pleasant user experience and a rich and detailed listening experience.
Crystal clear sound
Designed to deliver exceptional Hi-Res audio performance by accurately capturing and reproducing the depth of each note, the AP80 features an ES9218P DAC with an SNR of 126dB and a THD+N of -113dB.
HiBy OS
OS HiBy 3.0 is a music playback system recognized worldwide. This OS offers a premium musical experience, many settings and above all allows a very nice reproduction.
Mage Sound 8-Ball Tuning
The MSEB is a combination of several algorithms based on parametric equalizers and different adjustments to adapt the sound to your listening.
Un DAP Unique
Thanks to its many customization options, the AP80 is a truly unique DAP. Each user has the possibility to set the DAP according to his personal taste with for example more than 1000 colors available or the possibility to add the sound wallpaper.
Hidizs AP80 | Sony NW-A40 | |
OS | Hiby 3.0 Linux Version | Linux |
FM | Yes | No |
Step counter | Yes | No |
Sampling rate | 32bit 348kHz | 24bit 192kHz |
DSD Support | DSD 64/128 | DSD 64 |
aptX | Yes | No |
Screen size | 2.45" 480x360px Touchscreen | 3.1" Touchscreen |
DAC | ESS ES9218P | - |
Dimensions | 58 x 49 x 13.5mm | 55 x 97.5 x 10.9mm |
Connectic | Jack 3.5mm | Jack 3.5mm |
Extensible storage | Max 1TB | Max 256GB |
Battery capacity | 800mAh | N/A |
Quick charge | USB Type-C | USB Type-C |
Bidirectionnal Bluetooth aptX
Using Bluetooth 4.1 and aptX technology, the AP80 allows high quality wireless transmission, similar to CD.
HiBy Link
For a more convenient use, it is possible to use the HiBy Link application to control the playback of your music directly from your smartphone. This method allows to obtain an optimal audio quality since it supports the Hi-Res Bit Perfect.
FM Function
Unlike most other DAPs, the Hidizs AP80 features an FM radio function that allows you to listen to your favorite radios in Hi-Res.
Step counter
With its on-board pedometer, the AP80 is able to count the number of steps you take when you run or walk. Ideal for sports to music.
Small size, high power
The design of this DAP has been designed to be extremely portable so that you can take your music with you anywhere and always in high quality. And if it is small, the AP80 is also powerful and its size has no impact on its performance.
2.45" Samsung Touchscreen
The Hidizs Walkman does not stop there and offers a superb 2.45" touch screen, allowing you to control the device with a simple touch.
New wheel design
The AP80 features a modern design, and incorporates a new volume knob with 3 physical buttons on the side, to easily control the DAP.
A significant autonomy
The walkman carries a large 880mAh battery under its shell, allowing it to be switched on for 15 hours in reading or 35 days in standby.
Bidirectional USB connection
The Hidizs AP80 integrates a DAC ES9218P with a bidirectional USB interface. This makes it possible to use the AP80 either as an ultra-high quality USB audio dongle for your smartphone, or as a digital source for other devices.
Hi-Res supported formats
Supporting the vast majority of Hi-Res formats, the AP80 will allow you to listen to your FLAC, APE, WMA, WAV, WAV, ALAC, DSF, DFF and SACD-ISO files. It also supports native 64/128 DSD and PCM sampling rates up to 32bit 384kHz.
Up to 1TB of storage
For storing your files, the AP80 can accommodate a Micro SD card up to 1TB. This way, you can store all your Hi-Res files for continuous listening.
Note: The AP80 has no internal storage and the Micro SD card is sold separately.
Clock
The AP80 displays a clock on its main screen. So you can travel listening to your favorite songs, while keeping an eye on the time.
Hardware specifications | |
CPU | Ingenic X1000 |
DAC | ES9818P |
Control | Touchscreen + Volume wheel |
Internal stockage | No |
Storage extension type | Micro SD card (sold separately) |
Max storage capacity | 1TB |
Connectivity | |
FM | FM Radio |
Bluetooth | Bluetooth V4.1, aptX |
USB Interface | USB-C, bi-directionnal DAC USB |
Input | USB-C |
Output | Jack 3.5mm |
Display | |
UI | HiBy OS - Linux version |
Screen size | 2.45" |
Screen type | IPS |
Resolution | 480x360px |
Technical specifications | |
Sampling rate | PCM 384kHz 32bit / DSD128 |
Output power | 2 x 75mW @ 32 Ohm |
Frequency response | +/-3dB 20Hz - 40h |
SNR | 120dB |
Dynamic range | > 105dB |
Channels separation | 105dB |
THD+N | 0.003% |
Output impedance | < 1 Ohm |
Headphone impedance | 8-300 Ohm |
Lossless format supported | .dsf, .dff : DSD64/128 .iso : DSD64 APE FAST/High/Normal : Max 24bit 192kHz APE Extra High : Max 24bit 96kHz APE Insane : Max 24bit 96kHz AIFF : Max 32bit 384kHz FLAC : Max 24bit 384kHz WAV : Max 32 384kHz WMA Lossless : Max 24bit 96kHz |
Charging interface | USB-C 5VDC 2A |
Battery | Li-Polymer 800mAh |
Charging time | < 1.5h |
Autonomy | 15h |
GENERAl | |
Housing material | Inox / Aluminium alloy |
Gain control | Low / High |
Equalizer | 10 band equalizer (+/- 12dB), 8 presets |
Filters | Slow descent Sharp drop |
Color | Black |
Package Contents | |
USB-cable C to USB-A | x1 |
USB cable-C to micro-USB | x1 |
Screen Protector Film | x1 |
Case (silicone) | x1 |
Manual | x1 |
AP80 | x1 |
Input | Bluetooth |
Input | Micro SD |
DAC / ADC Chip | ES9218P |
Max sampling rate | DSD128 |
Max sampling rate | 384kHz |
Color | Black |
Average votes 5.0 / 5 6 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Benoit L.
Gilles B.
Minh Tuan N.
Pierre E.
jeanfrancois h.
