HIDIZS AP80 Portable Digital HiFi ES9218P DAC 32Bit / 384kHz DSD aptX Bluetooth Red
With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player supports high sampling rates (Hi-Res) and Bluetooth aptX for more convenient use. Hidizs has integrated many features into its DAP for a pleasant user experience and a rich and detailed listening experience.
Reference : 13528
135,00 €tax incl.
112,50 € tax excl.
Hidizs AP80
DAP Digital HiFi Music Player DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Red
Hidizs AP80 Baladeur Numérique HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX
A clear sound, an incredible richness of sound
Crystal clear sound
Designed to deliver exceptional Hi-Res audio performance by accurately capturing and reproducing the depth of each note, the AP80 features an ES9218P DAC with an SNR of 126dB and a THD+N of -113dB.
HiBy OS
OS HiBy 3.0 is a music playback system recognized worldwide. This OS offers a premium musical experience, many settings and above all allows a very nice reproduction.
Mage Sound 8-Ball Tuning
The MSEB is a combination of several algorithms based on parametric equalizers and different adjustments to adapt the sound to your listening.
Un DAP Unique
Thanks to its many customization options, the AP80 is a truly unique DAP. Each user has the possibility to set the DAP according to his personal taste with for example more than 1000 colors available or the possibility to add the sound wallpaper.
Comparative table
Hidizs AP80Sony NW-A40
OSHiby 3.0 Linux VersionLinux
FMYesNo
Step counterYesNo
Sampling rate32bit 348kHz24bit 192kHz
DSD SupportDSD 64/128DSD 64
aptXYesNo
Screen size2.45" 480x360px Touchscreen3.1" Touchscreen
DACESS ES9218P-
Dimensions58 x 49 x 13.5mm55 x 97.5 x 10.9mm
ConnecticJack 3.5mmJack 3.5mm
Extensible storageMax 1TBMax 256GB
Battery capacity800mAhN/A
Quick chargeUSB Type-CUSB Type-C
A DAP to follow you everywhere
Bidirectionnal Bluetooth aptX
Using Bluetooth 4.1 and aptX technology, the AP80 allows high quality wireless transmission, similar to CD.
HiBy Link
For a more convenient use, it is possible to use the HiBy Link application to control the playback of your music directly from your smartphone. This method allows to obtain an optimal audio quality since it supports the Hi-Res Bit Perfect.
FM Function
Unlike most other DAPs, the Hidizs AP80 features an FM radio function that allows you to listen to your favorite radios in Hi-Res.
Step counter
With its on-board pedometer, the AP80 is able to count the number of steps you take when you run or walk. Ideal for sports to music.
A walkman that fits in the palm of your hand
Small size, high power
The design of this DAP has been designed to be extremely portable so that you can take your music with you anywhere and always in high quality. And if it is small, the AP80 is also powerful and its size has no impact on its performance.
2.45" Samsung Touchscreen
The Hidizs Walkman does not stop there and offers a superb 2.45" touch screen, allowing you to control the device with a simple touch.
New wheel design
The AP80 features a modern design, and incorporates a new volume knob with 3 physical buttons on the side, to easily control the DAP.
A significant autonomy
The walkman carries a large 880mAh battery under its shell, allowing it to be switched on for 15 hours in reading or 35 days in standby.
De nombreuses fonctionnalités
Bidirectional USB connection
The Hidizs AP80 integrates a DAC ES9218P with a bidirectional USB interface. This makes it possible to use the AP80 either as an ultra-high quality USB audio dongle for your smartphone, or as a digital source for other devices.
Hi-Res supported formats
Supporting the vast majority of Hi-Res formats, the AP80 will allow you to listen to your FLAC, APE, WMA, WAV, WAV, ALAC, DSF, DFF and SACD-ISO files. It also supports native 64/128 DSD and PCM sampling rates up to 32bit 384kHz.
Up to 1TB of storage
For storing your files, the AP80 can accommodate a Micro SD card up to 1TB. This way, you can store all your Hi-Res files for continuous listening.
Note: The AP80 has no internal storage and the Micro SD card is sold separately.
Clock
The AP80 displays a clock on its main screen. So you can travel listening to your favorite songs, while keeping an eye on the time.
" The AP80 is probably the best budget DAP I’ve ever touched and heard. "
Hardware specifications
CPUIngenic X1000
DACES9818P
ControlTouchscreen + Volume wheel
Internal stockageNo
Storage extension typeMicro SD card (sold separately)
Max storage capacity1TB
Connectivity
FMFM Radio
BluetoothBluetooth V4.1, aptX
USB InterfaceUSB-C, bi-directionnal DAC USB
InputUSB-C
OutputJack 3.5mm
Display
UIHiBy OS - Linux version
Screen size2.45"
Screen typeIPS
Resolution480x360px
Technical specifications
Sampling ratePCM 384kHz 32bit / DSD128
Output power2 x 75mW @ 32 Ohm
Frequency response+/-3dB 20Hz - 40h
SNR120dB
Dynamic range> 105dB
Channels separation105dB
THD+N0.003%
Output impedance< 1 Ohm
Headphone impedance8-300 Ohm
Lossless format supported.dsf, .dff : DSD64/128
.iso : DSD64
APE FAST/High/Normal : Max 24bit 192kHz
APE Extra High : Max 24bit 96kHz
APE Insane : Max 24bit 96kHz
AIFF : Max 32bit 384kHz
FLAC : Max 24bit 384kHz
WAV : Max 32 384kHz
WMA Lossless : Max 24bit 96kHz
Charging interfaceUSB-C 5VDC 2A
BatteryLi-Polymer 800mAh
Charging time< 1.5h
Autonomy15h
GENERAl
Housing materialInox / Aluminium alloy
Gain controlLow / High
Equalizer10 band equalizer (+/- 12dB), 8 presets
FiltersSlow descent
Sharp drop
ColorRed
Package Contents
USB-cable C to USB-Ax1
USB cable-C to micro-USBx1
Screen Protector Filmx1
Case (silicone)x1
Manualx1
AP80x1
InputMicro SD
OutputJack 3.5mm
DAC / ADC ChipES9218P
Max sampling rateDSD128
Max sampling rate384kHz
ColorOther
ColorRed
2 reviews
Dynamic, detailed and smooth
The AP80 is phenomenal value for the price. It has a detailed and dynamic sound, which is also smooth and easy on the ears. It has all the essential features you need for listening to top quality music on the go. I chose the red colour as a nostalgic nod to my old Sony Walkman (even if they can't match this price/performance). Highly recommended!
This review has been posted for HIDIZS AP80 Portable Digital HiFi ES9218P DAC 32Bit / 384kHz DSD aptX Bluetooth Red
Résurgence du concept Cowon D2 ?
Surprise au déballage, le lecteur est beaucoup plus petit et joli que sur le descriptif de vente. Bien construit avec des matériaux nobles : acier et verre, belle finition, en rouge, je l' apprécie .
Au plan des bonnes surprises, j' ajoute le tactile qui est un régal, très réactif mais ce n' est pas un atout pour autant car sur une si petite surface (gros doigts s' abstenir) on se demande par ou le tenir surtout en fonction radio.
Maintenant, venons en à l' inacceptable, exporter un produit sophistiqué avec un (manuel) condensé type mini dépliant uniquement en Anglais ou Chinois sans la moindre traduction mis à disposition sur Internet devrait être interdit comme pratique maintenant.
Grand consommateur de radio par baladeur numérique, je me suis fait piégé par le descriptif dithyrambique de ce baladeur "écouter la radio FM en qualité HI-RES ". D' habitude, les baladeurs qualitatifs ne proposent pas d' option Radio et comme c' est rédhibitoire pour moi, je me détourne de ces offres.
Sur ce point fiasco total, la qualité du son en radio est juste moyenne et inutilisable tant le tuner est instable, capte tous les parasites et surtout le moindre frottement du câble du casque. Je reprendrai donc mon baladeur radio Sangean qui fait beaucoup mieux pour trois fois moins cher, il ne fait que cela mais il le fait bien.
En fonction lecture fichiers, la qualité est plutôt bonne mais si vos oreilles sont habituées au très bon son, ne vous attendez pas à pousser un AH ! de contentement à son premier usage compte tenu de ce que l' on nous promettait avec ce lecteur !
Le transfert de fichiers est pratique, bon tri, des mini photos de jaquettes bien rendues grâce à la très bonne définition de l' écran et tactile au top. Pas testé le bluetooth et le podomètre gadgets dont je ne me sers jamais.
Si on ne nous avait pas tant promis sur les hautes capacités de ce baladeur (descriptif de vente), il y aurait de quoi conclure : pas si mal, mais personnellement je dis qu' il ,est en dessous de ce qui était annoncé. Ce baladeur n' a pas trouvé sa clientèle en France, plus au catalogue de vente des sites Internet majoritaires.
On est loin de ce que fournissait Cowon voilà dix ans avec son D2: Radio FM, Lectures fichiers audio et vidéo fourni avec un stylet pour gérer le tactile de petit format et un manuel très complet en Français bien sur, (il fonctionne toujours aussi bien).
With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance....
