IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black
iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS ES9038Pro chip, supporting high resolution audio streams, up to PCM 32bit 768kHz, DSD512 and MQA 16x, while ensuring an impressively clear and rich reproduction. The received and decoded audio signal is then routed to the integrated and interchangeable AMP1 MK3 amplifier module
By buying this product you get 96 loyalty points
Reference : 15713
969,00 €tax incl.
807,50 € tax excl.
iBasso DX240
iBasso DX240 Baladeur Numérique HiFi DAP DAC ES9038Po Symétrique Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Noir
iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage embeds an excellent ESS ES9038Pro chip, supporting high resolution audio streams, up to PCM 32bit 768kHz, DSD512 and MQA 16x, while ensuring an impressively clear and rich reproduction. The received and decoded audio signal is then routed to the integrated and interchangeable AMP1 MK3 amplifier module.
A true computer that fits in the palm of your hand, the DX240 is equipped with powerful and efficient components. It uses a Snapdragon 660 SoC, associated with a dual Mango OS and Open Android 9.0 operating system. The clock signals are managed by two independent NDK femtosecond oscillators and synchronized by an FPGA optimized by the brand.
In terms of connectivity, the DX240 is also well supplied. Its outputs are indeed multiple since the iBasso DAP provides a single-ended 3.5mm jack output, a balanced TRRS 2.5mm jack output and a 3.5mm jack line output. It also has a bi-directional Bluetooth 5.0 connectivity allowing to connect it to a source such as a smartphone as well as to a headset or Bluetooth earphones. Its WiFi 2.4GHZ/5GHz connectivity allows it to access files stored on your local network.
Embedding a large 4400mAh battery, the device charges easily and quickly via a USB-C port, for up to 11 hours of playback time.
Finally, its intuitive and modern design offers convenient access to all control buttons. Its large 5" Full HD screen provides perfect readability and an excellent user experience.
Product typeDigital audio player (DAP)
InputMicro SD slot (up to 2TB, Micro SD card not included)
Outputs1x Balanced TRRS Jack 2.5mm
1x Single-ended Jack 3.5mm
1x Jack 3.5mm line output
ConnectivityBluetooth 5.0 bi-directionnal
WiFi dual-band 2.4GHz/5GHz
DAC ChipESS ES9038Pro
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
MQA 16x
ScreenFull HD 1080p 5"
SoCSnapdragon 660
RAM4GB
ROM (Storage)64GB
Battery4400mAh
Autonomy11h playback
harging time2.5h
Interchangeable amplifierSupplied with  AMP1 MK3 amplifier module
Balanced Jack 2.5mm output characteristics
Max output level6.2Vrms
Output power878mW @ 32Ω
128mW @ 300Ω
Frequency response10Hz - 45kHz
SNR125dB
Dynamic range125dB
THD+N-114dB
Output impedance0.57Ω
Single-ended Jack 3.5mm characteristics
Max output level3.1Vrms
Output power281mW @ 32Ω
32mW @ 300Ω
SNR123dB
Dynamic range123dB
THD+N-110dB
Output impedance0.38Ω
Dimensions126 x 70.5 x 18.7mm
Weight240g
Package1x iBasso DX240
1x USB cable
InputWiFi
InputMicro SD
OutputCoaxial SPDIF
OutputBluetooth
OutputJack 3.5mm
OutputJack 2.5mm
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rateMQA
Max sampling rate768kHz
2 reviews
RAVIRA VOS OREILLES
Aprés un DX80 (pb de batterie heureusement non récurent sur le DX240) je retrouve les qualités audios de ces baladeurs audiophiles
Fabrication soignée, écran superbe (trés sensible) et bonne autonomie.
Performances à la hauteur, son un peu "métallique" pendant la période de rodage des composants, plus chaud par la suite (en conservant l'alimentation d'origine)
Scéne sonore détaillée et large, basses comme il faut, sans excés
La molette de réglage du son et on/off qui pourrait paraître un peu prohéminente n'est pas du tout un handicap (bien protégée)
Le syteme d'exploitation est trés réactif, bref que du bonheur...
Quelques petits défauts sans conséquences ; protection transparente fournie un peu bas de gamme (preference pour le silicone noir du DX80) mais efficace, l'interface "Mango" (navigation simplifée) est un peu moche à mon goût, les codecs Bluetooth sont basiques pour une utilisation eventuelle avec écouteurs "true wireless"
en résumé :
qualité de fabrication 5
design (question de goût) 5
qualité audio 5
fonctionnalités 4
note globale 5
This review has been posted for IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black
Superbe produit
J'ai eu plusieurs DAP ibasso (DX-50,, DX-90, DX-150 ) et comme je m'y attendais un peu ce modèle surpasse mon precedent DX-150.
La qualité de fabrication est excellente, la réactivité et la qualité de l'écran est superbe et bien entendu pour la restitution de la musique que je croyais pas que l'on puisse faire mieux que mon DX-150.
Produit que je conseille... pour la fiabilité le temps le dira..
 (3)
iBasso is back with a high-end DAP, mixing brilliantly pure sound performances and modern and ergonomic design. Its digital/analog conversion stage...
