IBASSO DX320 Digital Audio Payer DAP Balanced 2x BD34301EKV Bluetooth 5.0 WiFi 5G MQA 16x Blue
The iBasso DX320 is a high-end digital music player with a careful design that offers the best sound performance for an outstanding music experience. Powerful and feature-rich, the DX320 is the perfect companion for listening at home or on the go.
By buying this product you get 154 loyalty points
Reference : 16451
1 549,00 €tax incl.
1 290,83 € tax excl.
iBasso DX320 amp11 mk2 blue
iBasso DX320 Baladeur Numérique DAP Symétrique
FPGA Master
At the heart of the DX320 is an FPGA-Master designed specifically for this model. The role of the FPGA-Master is to recover the audio data sent by the SoC in order to maintain a clean and stable signal. Combined with two Accusilicon clocks (45.1584M and 49.152M), it generates and perfectly synchronises the clock signals. In short, it ensures a drastic reduction in jitter to provide an extremely clean digital audio signal.
iBasso DX320 FPGA MASTER
Qualcomm Snapdragon 660 processor
The integrated 8-core Qualcomm Snapdragon 660 processor, etched in 14nm, offers incredible power to efficiently process audio signals while allowing smooth navigation within the device's interface. This SoC is combined with 6GB of RAM and 128GB of storage (ROM) (expandable via Micro SD card not included).
iBasso DX300 Baladeur Numérique DAP Symétrique 4x CS43198 FPGA Bluetooth 5.0 WiFi
Dual battery
The DX320's power stage incorporates two independent batteries. The first powers the digital stage, while the second powers the headphone amplifier. This separation of the power supplies limits possible interference between the digital and analogue circuits in order to reduce the level of distortion as much as possible.
Double DAC ROHM BD34301EKV
No less than two RHOM BD34301EKV DACs are used in the digital/analogue conversion stage of the iBasso DX320, for a total of 4 conversion channels. These combined channels allow the DAP to have a totally symmetrical conversion circuit while favouring its sound performance.
Technical specificationss
Type of productDigital music player (DAP)
Input1x Slot Micro SD
Outputs1x 2.5mm balanced jack
1x 4.4mm balanced jack
1x 3.5mm unbalanced jack
1x 3.5mm coaxial jack
Other connectors1x USB-C 3.1 SuperSpeed
Connectivity802.11 b/g/n/ac (2.4GHz/5GHz) 2x2MIMO 5G WiFi
Bluetooth 5.0
DAC chips2x RHOM BD34301EKV
FPGA
RAM6Go
ROM (Storage)128Go
Touch screen6.5" IPS Full Screen
2340 x 1080 pixels
Battery4000mAh 3.8V + 2000mAh 3.8V
Charging time2.5h
Autonomy10h
Supported audio formatsMQA 16x, APE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST, CUE, ISO, M3U, M3U8
measures Balanced outputs 4.4mm jack / 2.5mm jack
Maximum output level7.1Vrms
Power output1200mW @ 32Ω
168mW @ 300Ω
Frequency response10Hz - 40kHz ±0.3dB
SNR125dB
Dynamic range-125dB
THD+N-112dB (no load, 2.8Vrms)
-110dB (300Ω)
-103dB (32Ω)
Separation of channels-120dB
Impedance0.38Ω
Measures unbalanced output 3.5mm jack
Maximum output level3.5Vrms
Power output380mW @ 32Ω
40mW @ 300Ω
SNR122dB
Dynamic range-122dB
THD+N-110dB (hors charge, 2Vrms)
-110dB (300Ω)
-99dB (32Ω)
Separation of channels-114dB
Impedance0.34Ω
measures Balanced line output 4.4mm jack / 2.5mm jack
SNR125dB
Dynamic range-125dB
THD+N-110dB (hors charge, 2.8Vrms)
Measures unbalanced line output 3.5mm jack
SNR122dB
Dynamic range-122dB
THD+N-108dB (hors charge, 2Vrms)
Separation of channels-110dB
general
Power supplyVia USB-C
Chassis materialAluminium
ColorBlue
Dimensions162 x 77 x 17mm
Weight205g
Package1x iBasso DX320+AMP11 MK2
1x USB-C cable
1x Coaxial cable
1x Protective case
1x Screen protector
InputMicro SD
InputWiFi
OutputJack 4.4mm
OutputJack 3.5mm
OutputJack 2.5mm
OutputCoaxial SPDIF
DAC / ADC ChipROHM BD34301EKV
Max sampling rateDSD128
Max sampling rate384kHz
ColorBlue
The iBasso DX320 is a high-end digital music player with a careful design that offers the best sound performance for an outstanding music...
