IBASSO DX340 Digital Audio Player DAP
New
With the DX340, iBasso offers us a top-of-the-range digital music player incorporating the latest technological innovations in terms of FPGA and digital/analogue conversion, enabling conversion of a signal up to 32bit 768kHz PCM and DSD512 via a discrete network of 16 8bit PWM DACs. This innovative package is housed in a luxurious 316 stainless steel chassis and boasts a magnificent 6-inch AMOLED display offering striking contrasts, making the DX340 as much a pleasure for the ears as for the eyes.
By buying this product you get 169 loyalty points
Reference : 20517
1 690,00 €tax incl.
1 408,33 € tax excl.
iBasso DX340 Digital Audio Player DAP Bluetooth 5.0 WiFi 32bit 768kHz DSD512
iBasso DX340 : Front view
iBasso DX340: FPGA Master 3.0
The DX340 incorporates the latest version of the FPGA developed by iBasso. The Master 3.0 FPGA brings together all the algorithmic achievements of the brand in recent years in a single point. It plays a major role in reproducing and maintaining signal integrity, using signals from two Accusilicon clocks to obtain a single, perfectly synchronous clock signal.
With 7.5 times more LUTs than its predecessor, the FPGA Master 3.0 is equipped with a harmonic adjustment algorithm that makes it possible to adjust both even and odd harmonics.
This small revolution in terms of possible algorithms as well as signal reproduction and maintenance has paved the way for iBasso to develop a brand new, completely discrete DAC.
iBasso DX340 : FPGA operation
iBasso DX340: 128bit PWM DAC
Thanks to the enhanced capabilities of the Master 3.0 FPGA, the latter is able to generate a PWM signal which is immediately transmitted to a set of 16 8bit PWM DACs in cascade for analogue/digital conversion.
iBasso DX340 : PWM DAC operation
This set of 16 DACs is divided into 4 groups, the equivalent of one 32-bit DAC per group, to independently convert the two polarities of the left and right channels. The result is a precise decoding process that delivers exceptional performance, particularly in terms of distortion, with a total harmonic distortion plus noise rate of -119 dB.
iBasso DX340 : Dual battery
iBasso DX340: Dual battery architecture
The DX340 features iBasso's innovative dual battery structure, which ensures that both the digital and AMP sections are powered by an independent battery for optimum performance. An independent battery supply ensures a stable power supply for the AMP section, while effectively isolating electromagnetic interference from the digital section.
iBasso has further enhanced its dual-battery system by improving the user experience. For added convenience, the DX340 features a single battery indicator, and when connected to a USB charger providing adequate power, the device automatically switches to external power mode to save the battery.
iBasso DX340: Switchable amplification stage
The DX340 also incorporates the swappable amplifier module design of its predecessors. Although the DX340 comes with the AMP15 module as standard, it is also compatible with the AMP12, AMP13 and AMP14 modules.
As for the AMP15 module that comes as standard with the DX340, this uses a total of 8 BUF634s to deliver a high level of power. This new module also supports an external 12V DC power supply, enabling a ‘Super gain’ mode to be unlocked in order to achieve an output power of 2150mW+2150mW under 32Ω.
iBasso DX340 : Switchable amplification stage
iBasso DX340 : Qualcomm Snapdragon 665 SoC
iBasso DX340: Qualcomm Snapdragon 665 SoC
To guarantee smooth performance, the DX340 is equipped with a Snapdragon 665 SoC chip, complemented by 8GB of RAM and 256GB of UFS 2.1 storage, ensuring exemplary fluidity. Furthermore, if you need to, you can add up to 2TB of memory thanks to the micro SD slot, ensuring you never run out of space.
iBasso DX340: AMOLED Screen
The DX340 is equipped with a magnificent 6-inch 1080*2160px AMOLED screen. AMOLED technology enables each pixel to emit its own light independently of its neighbours, providing striking contrasts to give you a rich, colourful screen, so you can make the most of browsing on your DAP.
iBasso DX340 : AMOLED screen
iBasso DX340 : Stainless steel chassis
iBasso DX340: Stainless steel chassis
The chassis of the DX340 is made from 316 stainless steel, which is far more stable than an aluminium alloy and offers excellent corrosion resistance. The chassis is CNC machined before being polished and brushed, offering a uniquely classy finish that aluminium cannot offer.
iBasso DX340: 32bit 768kHz / DSD512 USB interface
Finally, the DX340 is equipped with a USB interface capable of supporting a sampling rate of up to 32bit PCM and DSD512, giving you the option of using it as a USB DAC to take full advantage of the advances made possible by the FPGA Master 3.0.
iBasso DX340 : USB interface
Product typeDigital audio player (DAP)
Touch screenAMOLED 6" 1080*2160px
Audio formatsAPE, FLAC, WAV, WMA, ACC, ALAC, AIFF, OGG, MP3, DFF, DSF, DXD, DST
Supported sampling ratesPCM 32bit 768kHz
DSD512
ConnectorsUSB-C 3.1
Outputs1x Jack 4.4mm balanced
1x Jack 3.5mm Single-ended
1x Coaxial Jack 3.5mm
WiFi802.11a/b/g/n/ac (2.4GHz/5GHz)
Bluetooth5.0
RAM8Go
Storage256Go + Slot micro-SD jusqu'a 2TB
BatteryDigital section: Li-Po battery 4000mAh 3.8V
AMP Section: Li-Po battery 2100mAh 3.8V
Charging time2.5h
Autonomy11h
Housing materialStainless steel 316
Headphone output characteristics balanced 4.4 mm jack
Maximum output level12V DC: 8.3Vrms
Battery: 6.23Vrms
Output power12V DC: 2150mW+2150mW @ 32Ω THD<1%
Battery: 1200mW+1200mW @ 32Ω THD<1%
Frequency response10Hz-22kHz (-0.7dB)
10Hz-40kHz (-2.2dB)
Signal-to-noise ratio (SNR)123dB
Dynamic range123dB
Total harmonic distortion more noise (THD+N)-119dB (A-wt, 600Ω)
-117dB (A-wt, 300Ω)
-106dB (A-wt, 32Ω)
Crosstalk-140dB
Headphone output characteristics single-ended 3.5 mm jack
Maximum output level12V DC: 4.2Vrms
Battery: 3.16Vrms
Output power12V DC: 550mW+550mW @ 32Ω THD<1%
Battery: 312mW+312mW @ 32Ω THD<1%
10Hz-40kHz (-2.2dB)
Dynamic range123dB
Total harmonic distortion more noise (THD+N)-117dB (A-wt, 600Ω)
-117dB (A-wt, 300Ω)
-104dB (A-wt, 32Ω)
Crosstalk-138dB
Line output characteristics balanced 4.4 mm jack
Maximum output level2Vrms
10Hz-40kHz (-2.2dB)
Dynamic range123dB
Crosstalk-145dB
Line output characteristics single-ended 3.5 mm jack
Maximum output level1Vrms
10Hz-40kHz (-2.2dB)
Signal-to-noise ratio (SNR)118dB
Dynamic range118dB
Total harmonic distortion more noise (THD+N)-110dB
Crosstalk-135dB
Dimensions150 x 77.5 x 19mm
Weight486g
ColorSilver
Package1x iBasso DX340
1x 12V AC mains adapter
Leather protective cover
1x USB-C cable
1x Coaxial cable
1x Burn-in cable
OutputJack 3.5mm
OutputJack 4.4mm
OutputCoaxial SPDIF
DAC / ADC ChipPWM
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
IBASSO DX340 Digital Audio Player DAP Bluetooth 5.0 WiFi 32bit 768kHz DSD512
With the DX340, iBasso offers us a top-of-the-range digital music player incorporating the latest technological innovations in terms of FPGA and...
