OPUS 2 Digital Audio Player DAC ES9018K2M x2 32bit/384kHz DSD WiFi Balanced
By buying this product you get 159 loyalty points
Reference : 11288
1 599,00 €tax incl.
1 332,50 € tax excl.
Here is the new DAP from Opus, OPUS # 2! The newest solution for audiophiles that have high demands on the sound quality and audio performance of their HiFi player. The OPUS 2 will allow you to enjoy your favorite music via streaming services and enjoy the benefits of WiFi and Bluetooth.
The OPUS # 2 has exceptional performance for playing DSD files as well as Hi-Res files up to 32bit / 384kHz. Its dual DAC (2x ESS ES9018K2M) provides a clear and brilliant sound in all circumstances.
This DAP has recovered all the advantages of the previous models and has been added all the necessary characteristics in order to be a modern portable audio player. It is designed to become the ultimate mobile HiFi solution, even for the most demanding Hi-Res enthusiasts. All this thanks to the expertise and professionalism of the OPUS engineers.
OPUS 2 DAP HiFi Music Player DAC ES9018K2M
Main Features :
  • Metal body: fully aluminum
  • Display: 4 "TFT Touch (480x800) / IPS PANEL
  • Supported Audio Formats: WAV / FLAC / ALAC / AIFF / WMA / MP3 / OGG /(DSF, DSF)
  • Stereo / DSD128 (1bit 5.6MHz) Stereo / DSD128 (1bit 2.8MHz) Stereo / DSD128 (1bit 5.6MHz) Stereo
  • Output Level: Non-Balanced 2.3Vrms / Symmetric 2.5Vrms
  • DAC: 2x SABRE ES9018K2M
  • Decoding: Support up to 32bit / 384kHz
  • Clock (Jitter): 50ps
  • Outputs: 3.5mm jack / 3.5mm optics / Balanced output 2.5mm, 4 PIN
  • Process and memory: ARM Cortex-A9 1.4GHz Quad-Core / DDR3 memory 1GB
  • Li-Polymer battery: 4000mAh / 3.7V (Battery life up to 9.5h, charge of 4h)
  • Storage Memory: 128GB (Can extend up to 200GB via MicroSD)
  • Supports: Windows 7, 8 (32 / 64bit), MAC OSX 10.9 and higher
  • WiFi: 802.11 b / g / n (2.4GHz)
  • Bluetooth: V4.0 (AD2P, AVRCP)
Audio Features:
  • Frequency response: +/- 0.02dB (20Hz - 20kHz, non symmetrical and symmetrical) / +/- 0.3dB (10Hz - 70kHz, non symmetrical and symmetrical)
  • Signal Noise Ratio: Not Symmetric (115dB @ 1kHz) / Symmetrical (116dB @ 1kHz)
  • Crosstalk: Non-symmetrical (130dB @ 1kHz) / Symmetrical (135dB @ 1kHz)
  • THD + N: 0.0009% @ 1kHz
  • Output impedance: Balanced output (1 Ohm) / Jack output (2 Ohm)
Dimensions / Packaging:
  • Dimensions: 76x124x18.3mm
  • Weight: 252g
  • Comes with: Leather case / Micro USB cable 5 PIN / Guid(English) / Screen Protector
[Img-19369-left-thickbox_default]
OPUS 2 DAP Baladeur HiFi DAC ES9018K2M
(Compatible with OPUS Symmetrical cable, not supplied)
OPUS 2 DAP Baladeur HiFi DAC ES9018K2M x2 32bit/384kHz DSD WiFi
