SHANLING M1 PLUS DAP Digital Music Player Black
Shanling's M1 Plus is a technical and aesthetic evolution of the M1S high-fidelity digital music player. This Plus version benefits from an improved digital/analogue conversion stage now based on an ESS ES9069Q chip, a new amplification stage and a Bluetooth receiver updated to version 5.2. Its appearance has also been modernised to make it as ergonomic as possible, a real distinguishing feature of the M1. As a result, the M1 Plus is the ideal companion, whether you're on the move or at home, for listening sessions of incredible quality.
3.5 / 5
Reference : 19707
199,90 €tax incl.
166,58 € tax excl.
Shipping date: 24-04-2025.
Shanling M1 Plus DAP Digital Music Player DAC ES9069Q Bluetooth 5.2 LDAC 32bit 768kHz DSD512 Black
Shanling M1 Plus : Black and silver
Shanling M1 Plus : A DAP that fits in the palm of your hand
The first thing that stands out about the Shanling M1 Plus is its compact size. Designed to take you wherever you go without weighing you down, the DAP measures just 86x61x17mm. In terms of weight, the M1 Plus weighs just 116g. So it's easy to forget, so you can enjoy your music to the full.
Shanling has made no concessions to ergonomics, however, and has integrated a magnificent 3.2" 480x320px high-definition touch screen. This gives you easy access to your music and all the available settings. The screen is housed behind curved tempered glass and the components are protected by a superb 100% aluminium CNC-machined case.
Shanling M1 Plus : in use
Shanling M1 Plus : Fast, intuitive navigation
Like its predecessor, the Shanling M1 Plus is based on the Mtouch operating system, providing access to a wide range of useful functions. It's powered by an Ingenic X2000 processor, ensuring smooth browsing in all circumstances.
Shanling M1 Plus :DAC chip
Shanling M1 Plus : Technology at the service of sound
In terms of sound, the M1 Plus incorporates an ESS ES9069Q DAC. These provide seamless, high-quality digital/analogue conversion up to PCM 32 bit / 768kHz and DSD512. This converter is combined with a high-performance amplification section with two SGM8262 amplifier chips delivering output power of 195mW @ 32 Ohm (Single-ended 3.5mm jack) and 660mW @ 32 Ohm (Balanced 4.4mm jack). This combination enables this small DAP to offer an SNR of 122dB and a distortion rate of 0.0007%.
Shanling M1 Plus : Boundless connectivity
While the Shanling M1 Plus naturally has a 3.5mm jack for conventional connection to your headphones, it also offers Bluetooth 5.2 connectivity for even greater convenience. Bluetooth connectivity with Sony LDAC and Qualcomm aptX technologies. The first of these technologies, LDAC, enables Bluetooth users to enjoy Hi-Res Audio files at up to 24bit 96kHz 4.5Mbps, where conventional Bluetooth would only allow 16bit 44.1Hz compressed audio. The second technology, aptX, enables transmission with less latency and greater stability, to deliver a clean signal.
Furthermore, the M1 Plus features bi-directional Bluetooth 5.2. So, while it can transmit to a speaker or headphones, it can also be used as a receiver, to take advantage of its amplification and DAC from a third-party source.
Furthermore, the M1 Plus can connect to a WiFi network to use AirPlay and DLNA technologies. A 4.4mm balanced jack is also available for exceptional quality headphone listening.
Shanling M1 Plus : Bi-directional USB-C
In the same vein, this player also features a bi-directional USB-C port. Just like Bluetooth, this port is capable of receiving or sending audio data. Ideal for taking advantage of the device's audio performance.
Product typeDigital music player (DAP)
DAC ChipsESS ES9069Q
AOP Chips2x SGM8262
ProcessorIngenic X2000
InputsBluetooth 5.2
1x USB-C
1x Slot Micro SD (up to 2TB)
OutputsBluetooth 5.2
Wifi
1x Jack 3.5mm
1x Jack 4.4mm balanced
1x USB-C
SyncLinkVia the Eddict Player application
Touch screen3.2" 320x480px
Battery2100mAh
Autonomy12.5h
Supported Bluetooth codecsSBC, AAC, aptX, aptx HD, LDAC
Supported Wifi protocolsAirplay DLNA, OTA updates
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Output powerSingle-ended output : 195mW @ 32Ω
Balanced output : 660mW @ 32Ω
Total harmonic distortion (THD+N)0.0007%
Cross channelsSingle-ended output : 74dB
Balanced output : 100dB
Signal-to-noise ratio (SNR)122dB
Output impedanceSingle-ended output : 0.6Ω
Balanced output : 1.2Ω
Dimensions86 x 61 x 17 mm
Weight116g
Package1x Shanling M1 Plus
1x USB-A to USB-C cable
1x Screen protection
InputMicro SD
OutputJack 4.4mm
OutputWiFi
OutputJack 3.5mm
OutputBluetooth
OutputUSB
DAC / ADC ChipES9069Q
Max sampling rate768kHz
Max sampling rateDSD512
2 reviews
INCROYABLE POUR LE PRIX
Mon avis perso sur ce petit lecteur tout simplement incroyable.
Ergonomie au top, réactivité bon et le son très bon, petite précision j'ai des très bon écouteur genre campfire audio.
Ps; j'ai un astell kern s35 quad dac que j'ai payé 899 euro, je préfère le son plus dynamique du shanling .
This review has been posted for SHANLING M1 PLUS DAP Digital Music Player DAC ES9069Q Bluetooth 5.2 LDAC 32bit 768kHz DSD512 Black
Déçu...
J'ai déjà son "petit" frère le M1s.
Je pensais évoluer vers un baladeur légèrement plus performant et encore plus intuitif en terme de navigation, et bien pas du tout.
Je n'ai entendu aucune différence sonore, pas moins bien mais pas non plus mieux.
En ce qui concerne la navigation le M1s est plus logique, vous permettant de revenir en arrière lorsque vous êtes sur un morceau de musique en faisant glisser votre doigt vers la droite, ce qui n'est pas le cas du M1 plus.
La définition des écritures est également mieux détourer sur le M1s.
Ce n'est certainement pas un mauvais produit mais je ne comprends pas ce que shanling a voulu faire en sortant ce baladeur.
Seul la prise en main sera peut-être plus intéressante pour certains d'entre vous au vu de son gabarit.
Shanling's M1 Plus is a technical and aesthetic evolution of the M1S high-fidelity digital music player. This Plus version benefits from an...
