SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256
The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open Android OS operating system and two ESS ES9219C digital-to-analog conversion and amplification chips.
By buying this product you get 34 loyalty points
Reference : 15198
349,00 €tax incl.
290,83 € tax excl.
Shanling M3X
Baladeur Numérique DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256
The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm Snapdragon 430 processor, an Open Android OS operating system and two ESS ES9219C digital-to-analog conversion and amplification chips. Practical, it supports Bluetooth remote broadcasting, but also offers both unbalanced and balanced output. Particularly compact with its 3:2 screen format, it will simply slip into a pocket to accompany you on all your travels.
Dual ES9219C DAC and amplifier
The M3X is the first DAP to use the new ESS ES9219C combined digital-to-analog conversion and amplification chip. These offer excellent sound quality, while supporting high resolution files, up to PCM 32bit 384kHz, DSD and MQA. They also ensure low power consumption for longer battery life.
FPGA & Clocks
The Shanling M3W uses two KDS active clocks and an FPGA to process the clock signals and promote perfect synchronization for minimal jitter. The result is accurate decoding of PCM and DSD streams for equally accurate playback.
All day long use
With an optimized audio circuit and the possibility of using only one DAC chip, the M3X offers a large autonomy, allowing you to listen all day long. Its 3200mAh battery allows a 23 hours autonomy on 3.5mm jack output in Single DAC mode or 20 hours in Dual DAC mode, 19 hours on 4.4mm balanced jack output or 46 hours in Bluetooth.
MQA Support
The DAC chips used in the M3X provide native hardware support for MQA (Master Quality Authenticated), allowing you to enjoy superior sound quality.
Snapdragon 430 & Open Android
The M3X combines a powerful Qualcomm Snapdragon 430 processor, 2GB of RAM and the Open Android operating system for a fast and smooth experience. The Open Android OS also provides great flexibility, allowing you to enjoy your favorite streaming applications, for example. The AGLO technology ensures a perfect processing of audio data.
Balanced / Single-ended dual output
The M3X offers both an unbalanced 3.5mm jack output and a balanced 4.4mm jack output to match your headphones. The latter output allows you to enjoy a higher audio quality, but also a higher output power.
Bi-directional Bluetooth & USB DAC
Shanling M3X can connect via Bluetooth to your headphones or speakers, but also to your phone for convenient wireless use. It supports Bluetooth codecs such as aptX, LDAC or LHDC for rich and faithful sound reproduction.
The M3X can also be connected to a computer in USB DAC mode but also as a USB interface.
Product typeDigital audio player (DAP)
InputsBluetooth
Micro SD slot (SD Card not included)
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
Bluetooth
OSOpen Android 7.1
Bluetooth version4.2
Supported Bluetooth codecsTransmission: LDAC, LHDC, aptX HD, aptX, SBC
Reception: LDAC, SBC
ScreenSharp
4.2"
768x1280px
Sampling ratesPCM up to 32bit 384kHz
DSD up to DSD256
MQA
GainHigh
Low
RAM2GB
Internal storage (ROM)32GB
DAC Chips2x ESS ES9219C
Battery3200mAh
Autonomy23h @ Jack 3.5mm, Single DAC
20h @ Jack 3.5mm, Dual DAC
19h @ Balanced Jack 4.4mm
Supported file formatsDSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, ACC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8, OPUS, ISO (except DST)
Jack 3.5mm Output
Channel separation75dB @ 32Ω
Dynamic range121dB
Noise floor> 114dB (1.8µV)
Power outputSingle DAC : 80mW @ 32Ω
Dual DAC : 101mW @ 32Ω
Balanced Jack 4.4mm Output
Frequency response20Hz - 40kHz (-0.5dB)
Channel separation115dB @ 32Ω
Dynamic range121dB
Noise floor> 112dB (2.4µV)
Power output240mW @ 32Ω
Dimensions109 x 72 x 15.9mm
Weight168g
InputMicro SD
OutputBluetooth
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9219C
Max sampling rateDSD256
Max sampling rate384kHz
2 reviews
Tres bon lecteur
Coupler à un campfire audio dorado 2020, juste un commentaire, excellent. Pour ce prix rien à redire.
This review has been posted for SHANLING M3X Digital Audio Player DAP 2x ES9219C Bluetooth MQA 32bit 384kHz DSD256
mediocre produit !
ce produit n'est pas dans l'exellence pour le prix vendu !
plans sonore plat, aucune precision, mon Cowon plenue V est nettement et facilement au dessus quand a la qualité sonore !
la partie android est quand a elle souq alimenté par une ram rachetique de 2 GO, et audroid quand a lui utilise en moyenne
960 mo !
si l'on a comme beaucoup d'usager du materiel audio avec des fiches en 3.5 et 2.5 l'on se trouve dans l'obligation d'acheter un adaptateur
4.4 vers 3. ou 2.5 .... ce qui augemente l'enconbrement et les possible problemes de connectiques !!
donc retour a Audiphonic pour tout ces élements !
The Shanling M3X is a high quality portable music player with a well thought-out and optimized design. It is based on a powerful Qualcomm...
