SHANLING M6 (21) 64GB HiFi Digital Audio Player DAP DAC 2x ES9038Q2M 32bit 768kHz DSD256 Titanium
Equipped with two ESS ES9038Q2M DACs, the Shanling M6 (21) is a high performance model, supporting high sampling rates, up to PCM 32bit 768kHz and DSD256. Versatile, it is also compatible with Bluetooth aptX HD and LDAC, as well as WiFi and can also be used as a USB DAC.
By buying this product you get 58 loyalty points
Reference : 16724
589,00 €tax incl.
490,83 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Shanling M6 (21) 64GB
Shanling M6 (21) 64GB DAP Baladeur Numérique HiFi Compact DAC 2x ES9038Q2M 32bit 768kHz DSD256
Equipped with two ESS ES9038Q2M DACs, the Shanling M6 (21) 64GB is a high performance model, supporting high sampling rates, up to PCM 32bit 768kHz and DSD256. Versatile, it is also compatible with Bluetooth aptX HD and LDAC, as well as WiFi and can also be used as a USB DAC. Taking advantage of an Android operating system, it allows you to install many applications, especially to access your favorite streaming services. The DAP also integrates two balanced headphone outputs in 2.5mm and 4.4mm jack format as well as an unbalanced 3.5mm jack output to adapt to the vast majority of headphones on the market.
A high resolution DAP
Designed and engineered for audiophiles, the M6 (21) adopts a dual ESS ES9038Q2M DAC to independently process the audio streams of each channel. It also supports high-resolution files up to PCM 32bit 768kHz and DSD256, as well as MQA. Each DAC is associated with a low noise KDS clock and is filtered by an FPGA chip specifically programmed by Shanling for the M6 (21).
Shanling M6 (21) DAP Baladeur Numérique HiFi Compact DAC 2x ES9038Q2M 32bit 768kHz DSD256
Balanced & Single-ended outputs
The Shanling M6 (21) amplification stage is not to be outdone since it benefits from two independent amplifiers to feed the balanced outputs while ensuring a very low noise level. A third amplifier feeds the single-ended output in order to take full advantage of the dual DAC. The M6 (21) offers 3 headphone outputs: 2 balanced outputs in 2.5mm and 4.4mm jack format and a single-ended output in 3.5mm jack. The developed power is 350mW under 32Ω on the balanced outputs and 160mW under 32Ω for the single-ended output.
WiFi & Bluetooth
The Shanling M6 (21) is equipped with a WiFi controller, allowing you to transfer your music wirelessly or even to play files stored on your network directly, in DLNA. This also allows the M6 (21) to have access to many music streaming services, like Qobuz, Deezer or Spotify.
The M6 (21) also includes a Bluetooth chip for receiving and transmitting audio data to Bluetooth headphones or earphones. This Bluetooth chip supports AAC, aptX HD, LDAC and HWA codecs for maximum compatibility.
Touch screen
Dressed in an aluminum chassis, the M6 (21) is light and robust on which rests a large touch screen of 11cm diagonal. This one allows an intuitive navigation in the menus of the DAP and within your audio files. These files can be stored on the 64GB internal memory of the player or on an external Micro SD card (not included). The DAP is powered by a Lithium-Polymer battery capable of providing an autonomy of up to 12 hours in single-ended or 9 hours in balanced.
Product typeDigital Audio Player (DAP)
DAC Chip2x ESS ES9038Q2M
Balanced output amplifiers2x AD8397
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
1x Balanced Jack 2.5mm
ConnectivityWiFi
Bluetooth 4.1
Supported Bluetooth codecsAAC, SBC (reception only), aptX HD, LDAC, HWA
Touch screenDiagonal : 11cm
Resolution : 720 x 1280px
OSAndroid
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD256
Compatible file formatsDSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8, MQA
Power outputBalanced output : 350mW @ 32Ω
Single-ended output : 160mW @ 32Ω
SNRBalanced output : 119dB
Single-ended output : 118dB
THDBalanced output : 0.001%
Single-ended output : 0.001%
Output impedanceBalanced output : < 2Ω
Single-ended output : < 1Ω
Channel separationSingle-ended output : 75dB @ 32Ω
Dynamic rangeBalanced output : 118dB
StorageInternal storage: 32Go
Micro SD slot (up to 2To, not included)
BatteryLithium-Ion 4000mAh
AutonomyBalanced output : 9 heures
Single-ended output : 12 heures
Dimensions71 x 135 x 17mm
Weight228g
Housing materialAluminum
InputWiFi
InputMicro SD
OutputJack 3.5mm
OutputJack 4.4mm
OutputJack 2.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate768kHz
Max sampling rateDSD256
ColorTitanium
Equipped with two ESS ES9038Q2M DACs, the Shanling M6 (21) is a high performance model, supporting high sampling rates, up to PCM 32bit 768kHz and...
