By buying this product you get 58 loyalty points
HiFi Digital Audio Player DAP DAC 2x ES9038Q2M 32bit 768kHz DSD256
Equipped with two ESS ES9038Q2M DACs, the Shanling M6 (21) 64GB is a high performance model, supporting high sampling rates, up to PCM 32bit 768kHz and DSD256. Versatile, it is also compatible with Bluetooth aptX HD and LDAC, as well as WiFi and can also be used as a USB DAC. Taking advantage of an Android operating system, it allows you to install many applications, especially to access your favorite streaming services. The DAP also integrates two balanced headphone outputs in 2.5mm and 4.4mm jack format as well as an unbalanced 3.5mm jack output to adapt to the vast majority of headphones on the market.
Designed and engineered for audiophiles, the M6 (21) adopts a dual ESS ES9038Q2M DAC to independently process the audio streams of each channel. It also supports high-resolution files up to PCM 32bit 768kHz and DSD256, as well as MQA. Each DAC is associated with a low noise KDS clock and is filtered by an FPGA chip specifically programmed by Shanling for the M6 (21).
The Shanling M6 (21) amplification stage is not to be outdone since it benefits from two independent amplifiers to feed the balanced outputs while ensuring a very low noise level. A third amplifier feeds the single-ended output in order to take full advantage of the dual DAC. The M6 (21) offers 3 headphone outputs: 2 balanced outputs in 2.5mm and 4.4mm jack format and a single-ended output in 3.5mm jack. The developed power is 350mW under 32Ω on the balanced outputs and 160mW under 32Ω for the single-ended output.
The Shanling M6 (21) is equipped with a WiFi controller, allowing you to transfer your music wirelessly or even to play files stored on your network directly, in DLNA. This also allows the M6 (21) to have access to many music streaming services, like Qobuz, Deezer or Spotify.
The M6 (21) also includes a Bluetooth chip for receiving and transmitting audio data to Bluetooth headphones or earphones. This Bluetooth chip supports AAC, aptX HD, LDAC and HWA codecs for maximum compatibility.
Dressed in an aluminum chassis, the M6 (21) is light and robust on which rests a large touch screen of 11cm diagonal. This one allows an intuitive navigation in the menus of the DAP and within your audio files. These files can be stored on the 64GB internal memory of the player or on an external Micro SD card (not included). The DAP is powered by a Lithium-Polymer battery capable of providing an autonomy of up to 12 hours in single-ended or 9 hours in balanced.
Product type | Digital Audio Player (DAP) |
DAC Chip | 2x ESS ES9038Q2M |
Balanced output amplifiers | 2x AD8397 |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm 1x Balanced Jack 2.5mm |
Connectivity | WiFi Bluetooth 4.1 |
Supported Bluetooth codecs | AAC, SBC (reception only), aptX HD, LDAC, HWA |
Touch screen | Diagonal : 11cm Resolution : 720 x 1280px |
OS | Android |
Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD256 |
Compatible file formats | DSF, DFF, ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DTS, MP3, WMA, AAC, OGG, ALAC, MP2, M4C, AC3, M3U, M3U8, MQA |
Power output | Balanced output : 350mW @ 32Ω Single-ended output : 160mW @ 32Ω |
SNR | Balanced output : 119dB Single-ended output : 118dB |
THD | Balanced output : 0.001% Single-ended output : 0.001% |
Output impedance | Balanced output : < 2Ω Single-ended output : < 1Ω |
Channel separation | Single-ended output : 75dB @ 32Ω |
Dynamic range | Balanced output : 118dB |
Storage | Internal storage: 32Go Micro SD slot (up to 2To, not included) |
Battery | Lithium-Ion 4000mAh |
Autonomy | Balanced output : 9 heures Single-ended output : 12 heures |
Dimensions | 71 x 135 x 17mm |
Weight | 228g |
Housing material | Aluminum |
Color | Black |
Input | WiFi |
Input | USB |
Input | Micro SD |
Input | Bluetooth |
Output | Jack 2.5mm |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9038Q2M |
Max sampling rate | DSD256 |
Max sampling rate | 768kHz |
Color | Titanium |
