SHANLING M6 ULTRA Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Green
The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above all marking the return of AKM DACs! Thus, the M6 Ultra is the first DAP of the brand to integrate the latest generation of AKM DACs, with four AK4493SEQ chips within a unique balanced architecture. The amplifier design has been adjusted for this Quad-DAC design, allowing for higher output power.
By buying this product you get 91 loyalty points
Reference : 16774
919,00 €tax incl.
765,83 € tax excl.
Shanling M6 Ultra
Shanling M6 Ultra Baladeur Numérique DAP 4x AK4493SEQ Bluetooth aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA
For the rest, the M6 Ultra adopts the design implemented by Shanling for their digital music players. It is powered by a Snapdragon 665 processor, Android 10 and the Android Global Losless Output (AGLO) technology developed by the brand for optimal performance.
A dazzling screen
First visible element, the magnificent touch screen of the M6 Ultra, a Sharp LCD panel of 5" and a resolution 1920*1080px (Full HD) and a definitio of 441ppi. This one offers a superb rendering of the colors and wide angles of vision, allowing a use as comfortable as pleasant.
Quad-DAC design
The M6 Ultra is the first Shanling notebook to adopt the new generation of AKM DACs, using no less than four AK4493SEQ chips in a unique Quad-DAC design. This design is inspired by Shanling CD players, in particular, with a view to maximizing the potential of the DACs in a balanced circuit. They also support sampling rates up to PCM 32bit 768kHz, DSD512 and MQA files.
OP + BUF Improved architecture
Adopting the brand new Linearin LTA8092 high voltage AOP and the now proven BUF634A buffer, combined with AKM DACs, the Shanling M6 Ultra offers a slightly warmer and smoother reproduction, carrying on the signature sound that has made the brand successful.
OPA1612
The DAC section of the M6 Ultra also embeds four TI OPA1612 AOs, separating the balanced audio signal between the four DACs. This architecture allows for a completely independent balanced output.
OPA2211 Low-pass filter
The low-pass filter of the M6 Ultra uses two TI OPA2211 PDOs, chosen for their low noise and high bandwidth.
KDS Oscillators & 3rd Generation FPGA
Two Japanese KDS active oscillators and Shanling's improved algorithm enable better accuracy, with greatly reduced jitter and improved performance for digital signal transmission.
A new amplifier for more power
The newly designed amplifier of the M6 Ultra allows it to reach a much higher power than the previous models. It is therefore capable of accompanying a greater number of headphones, including models with a high impedance and therefore more demanding.
Balanced & single-ended outputs
Whether you have headphones or earphones with a 3.5mm or 4.4mm jack, the M6 Ultra will adapt. Indeed, it provides two outputs: the first, balanced, is in 4.4mm jack format and the second, single-ended, in 3.5mm jack format.
An oversized battery
With the M6 Ultra, autonomy is no longer a problem. Its large 5650mAh battery provides 13.5 hours of single-ended playback, 9 hours of balanced playback and 58.5 hours of Bluetooth transmission. Moreover, it integrates the fast charge technology QC3.0 18W.
Two-way Bluetooth 5.0
Easily connect your M6 Ultra to any Bluetooth wireless headphones or speakers and enjoy exceptional sound quality with support for the high-resolution wireless transmission codecs aptX, aptX HD and LDAC. The M6 Ultra can also function as a receiver and thus be connected via Bluetooth to a source.
Connexion haute vitesse & streaming
En plus de sa connectivité Bluetooth, le M6 Ultra est équipé d'un module réseau WCN3980, supportant le WiFi 2.4G/5G et la technologie MIMO, assurant une connexion rapide et stable. Une connexion qui vous permettra d'accéder à la musique stockée sur votre réseau, sur un ordinateur ou un NAS par exemple, en utilisant les protocoles DLNA ou AirPlay. Par ailleurs, cette fonction vous permettra également de profiter de vos services de streaming et webradios préférés.
A fast processor
Inside the M6 Ultra is a powerful eight-core Snapdragon 665 processor associated with 4GB of LPDDR4X RAM, offering very good computing performance for a smooth and pleasant use of the DAP. It also has 64GB of internal storage, which can be expanded by using a Micro SD card (not included).
Android 10 system
The Android 10 platform gives you access to a variety of applications to suit your needs. And with AGLO, the onboard technology for Android Global Lossless Output, your music is processed in its highest quality, without degradation caused by Android's sample rate converter.
Full MQA support
Working as a total decoder, the M6 Ultra is capable of playing high-quality 16x MQA streams via the Tidal streaming app. Master Quality Authenticated (MQA) technology allows you to enjoy sound reproduction as close as possible to the original studio recording.
Product typeDigital audio player (DAP)
Touchscreen5" 1080*1920px
OSOpen Android 10
InputsBluetooth 5.0
Internal storage
1x Micro SD slot
OutputsBluetooth 5.0
1x Jack 4.4mm balanced headphone output
1x Jack 3.5mm single-ended headphone output
WiFi ConnectivityWiFi 2.4G/5G
MIMO
Supported audio formatsDSD (.iso, .dsf, .dff), DST ISO, ISO, DXD, APE, FLAC, WAV, AIFF, ALF, DTS, MP3, WMA, AAC, OGG, MQA, ALAC, MP2, M4A, AC3, M3U, M3U8
Supported sampling ratesPCM up to 32bit 768kHz
DSD up to DSD512
Gain setting3 levels
RAM4Go
Internal storage64Go
DAC4x AKM AK4493SEQ
Digital filters7 preset filters
Bluetooth version5.0
Supported Bluetooth codecsTransmission : SBC, aptX, aptX HD, LDAC
Reception : SBC, LDAC
Single-ended output Performances
Output powerLow gain : 16mW @ 32Ω
Medium gain : 92mW @ 32Ω
High gain : 240mW @ 32Ω
Frequency response20Hz - 40kHz (-0.2dB)
THD+N0.0005%
Channel separation75dB @ 32Ω
Dynamic range122dB
SNR122dB
Noise> 116dB (< 1.6µV) (low gain)
Output impedance< 1Ω
Balanced output Performances
Output powerLow gain : 61mW @ 32Ω
Medium gain : 360mW @ 32Ω
High gain : 720 mW @ 32Ω
THD+N0.0005%
Channel separation115dB @ 32Ω
Dynamic range125dB
SNR125dB
Noise> 114dB (< 2.1µV)
Dimensions127 x 77 x 18mm
Weight263g
ColorGreen
Package1x Shanling M6 Ultra
1x USB-C to USB-A cable
2x Protection screen
InputWiFi
InputMicro SD
OutputJack 4.4mm
OutputWiFi
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipAK4493SEQ
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ColorSilver
ColorRed
Excellent mais déroutant.
Pour commencer j'ai failli le renvoyer, au moins 4 fois. Trop doux, trop ouvert pour mon écoute et mes casques, et puis en équilibrant le gain, en choisissant de meilleurs casques et intras, en utilisant le Replay gain, je pense que tout ses défauts sont de belles qualités. Persévérer vaut le coup je pense. Doux analytique équilibré, belle scène, et vraiment différent d'autre dap plus acide.
This review has been posted for SHANLING M6 ULTRA Digital Audio Player DAP 4x AK4493SEQ Bluetooth 5.0 aptX HD LDAC WiFi 32bit 768kHz DSD512 MQA Green
The long-awaited new version of the Shanling M6 Walkman, the M6 Ultra, is finally here, bringing not only an upgraded Android platform, but above...
