By buying this product you get 149 loyalty points
Shanling's M8T is a classy digital audio player with the distinctive feature of tube amplification, so you'll always have at hand the ability to enjoy the characteristic sound of this technology. Digital/analog conversion is handled by a pair of AKM AK4499EX/AK4191 chip combos, ensuring unparalleled authenticity while supporting signals up to PCM 32bit 768kHz and DSD1024. Furthermore, Shanling offers here a new version of its AGLO (Android Global Lossless Output) solution, ported and optimized for Android 13, ensuring compatibility with the majority of streaming applications.
Shanling's M8T follows in the same aesthetic vein as the M9. It benefits from a CNC-machined aluminum body from a single block, offering a sophisticated, jointless design. This high-quality chassis is complemented by Sharp's 6-inch touchscreen with full HD resolution of 2160px x 1080px, offering vibrant color rendering.
The M8T's conversion stage is based on a set of 2 combos of the famous AKM AK4499EX and AK4191 chips. This architecture, decoupling digital/analog conversion and Delta Sigma modulation, offers exceptionally precise rendering, and enables conversion of signals with sampling rates up to PCM 32bit 768kHz and DSD1024.
Wishing for a sound reproduction characteristic of tube amplification. The M8T is distinguished by its amplification using JAN6418 power tubes. Almost unique on the DAP market, the M8T delivers a warm sound, so you can always have tube amplification in your pocket.
Although tube amplification is the M8T's most unique feature, you can select an option to enjoy transistor-only amplification, giving you a more neutral, dynamic sound. Furthermore, with tube amplification, you can also choose between Triode mode for a warmer sound, and Ultra-linear mode for a smoother, more compact rendering.
To ensure signal stability, the M8T uses two KDS crystal oscillators, 90.3168MHz and 98.304MHz, coupled to the latest-generation FPGA developed in-house by Shanling.
To ensure long-term compatibility with the vast majority of streaming applications, Shanling is offering an updated version of its AGLO (Android Global Lossless Output) solution for Android 13, enabling you to enjoy lossless signal processing while preserving user comfort.
Furthermore, the M8T is compatible with streaming applications such as Apple Music, Tidal, Qobuz and Spotify, as well as DLNA and Airplay network protocols, allowing you to control it remotely via the Eddict Player app available on Android and iOS.
With an amplification power of 500mW at 32Ω single-ended and 1125mW at 32Ω balanced, and its three-level gain control, the M8T is compatible with the vast majority of headphones available on the market, including the most demanding such as planar magnetic headphones.
Thanks to its massive 8350mAh battery, the M8T is capable of delivering the power demanded by its audiophile circuitry for up to 15.5 hours of uninterrupted single-ended or 13 hours of balanced listening. Furthermore, the M8T supports Quick-Charge 3.0 and Power Delivery 2.0, enabling fast charging at 18W.
The M8T is no slouch when it comes to wireless connectivity, offering bidirectional Bluetooth compatible with LDAC, SBC and AAC protocols, as well as 2.4G/5G WiFi connectivity thanks to Qualcomm's WCN3980 module.
To enable you to use the M8T as a USB DAC, it has been fitted with an XMOS XU316 USB interface, supporting files up to PCM 768kHz and DSD512.
Last but not least, the M8T is equipped with a powerful 8-core Snapdragon 665 processor from Qualcomm. This 11nm finely etched processor is accompanied by an Andreno 610 graphics GPU meticulously optimized for Android 13, guaranteeing optimum performance at all times.
Product type | Digital audio player (DAP) |
Touch screen | Sharp 6-inch 1080x2160 display |
OS | Open Android 13 |
Inputs | Bluetooth 5.0 Internal memory 1x Slot Micro SD (Micro SD card sold separately) 1x USB-C (XMOS XU316) |
Output | Bluetooth 5.0 1x Balanced heaphone output Jack 4.4mm 1x Single-ended heaphone output Jack 3.5mm |
WiFi connectivity | WiFi 2.4G/5G |
Supported sample rates | PCM up to 32bit 768kHz DSD up to DSD1024 |
RAM | 6Go |
Internal storage | 128Go |
DAC | 2x AK4499EX |
AOP | ADI ADA45253 OPA1612 ADI AD8397 |
Bluetooth version | 5.0 |
Supported bluetooth codecs | Transmission: LDAC / SBC / AAC Reception: LDAC / SBC / AAC |
Single-ended JACK 3.5mm output specifications (Transistor) | |
Power | Low gain: 1V @ 32Ω (31mW) Medium gain: 2V @ 32Ω (125mW) High gain: 4V @ 32Ω (500mW) |
Frequency response | 20Hz - 40kHz (0.2dB) |
Total harmonic distortion more noise (THD+N) | 0.0007% |
Channel separation | 75dB @32Ω |
Dynamic range | 124dB |
Signal-to-noise ratio (SNR) | 124dB |
Noise floor | > 117dB (Low gain) |
Output impedance | < 1Ω |
Single-ended JACK 3.5mm output specifications (Tubes) | |
Power | 3.7V @32Ω (420mW) |
Signal-to-noise ratio (SNR) | 120dB |
Balanced JACK 4.4mm output specifications (Transistor) | |
Power | Low gain: 2V @ 32Ω (125mW) Medium gain: 4V @ 32Ω (500mW) High gain: 6V @ 32Ω (1125mW) |
Frequency response | 20Hz - 40kHz (-0.2dB) |
Total harmonic distortion more noise (THD+N) | 0.0005% |
Channel separation | 115dB @32Ω |
Dynamic range | 127dB |
Signal-to-noise ratio (SNR) | 127dB |
Noise floor | > 114dB (Low gain) |
Balanced JACK 4.4mm output specifications (Tubes) | |
Power | 5.5V @32Ω (950mW) |
Signal-to-noise ratio (SNR) | 123dB |
Dimensions | 147 x 82 x 22mm |
Weight | 383g |
Color | Noir |
Package | 1x Shanling M8T 1x USB-C cable 2x Screen protector |
Input | Bluetooth |
Input | WiFi |
Input | USB |
Input | Micro SD |
Output | Jack 4.4mm |
Output | Jack 3.5mm |
Output | Bluetooth |
DAC / ADC Chip | AK4499EX |
Max sampling rate | 768kHz |
Max sampling rate | DSD1024 |
Color | Black |
