SHANLING ONIX OVERTURE XM5 Digital Audio Player
Shanling's Onix Overture XM5 is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact, the Overture XM5 incorporates a latest-generation ES9039PRO DAC chip combined with a 16-core XMOS XU316 USB processor, for optimum decoding of high-resolution audio signals up to PCM 32 bit 768kHz and DSD512.
By buying this product you get 79 loyalty points
Reference : 19480
799,00 €tax incl.
665,83 € tax excl.
Shipping date: 29-04-2025.
Shanling Onix Overture XM5 Digital Audio Player DAP ES9039PRO 2x TPA6120 32bit 768kHz DSD512
SHANLING ONIX Overture XM5 : Front view
Shanling
is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact, the Overture XM5 incorporates a latest-generation ES9039PRO DAC chip combined with a 16-core XMOS XU316 USB processor, for optimum decoding of high-resolution audio signals up to PCM 32 bit 768kHz and DSD512. With the help of a powerful amplifier section consisting of two TPA6120 chips, the Overture XM5 also boasts a powerful output of up to 1070mW at 32Ω, which, coupled with its gain control, means it can drive the vast majority of headphones and earphones on the market, maintaining a clear, low-distortion output in all circumstances.
ES9039S Pro DAC chip
Shanling Onix Overture XM5 : Cutting-edge DAC chips
The Shanling Onix Overture XM5 is equipped with the latest generation of ESS Sabre ES9039S Pro DAC chips. This is the latest 32-bit DAC chip from ESS Sabre Technologies. It provides exceptional decoding of high-resolution audio signals. Combined with the 16-core XMOS XU316 USB processor, decoding of high-resolution 32bit 768kHz PCM and native DSD512 audio is fully supported. With such a high-end configuration, the Overture XM5 has a signal-to-noise ratio (SNR) of up to 121dB, and a distortion plus noise ratio (THD+N) of just 0.0006%.
Shanling Onix Overture XM5 : Dual amplification chip
The Shanling Onix Overture XM5 is equipped with two TPA6120 amplifier chips, providing a high output power of 1070mW. Coupled with three different gain settings, this DAP will easily drive the most demanding headphones and earphones, ensuring a clean, accurate signal in all circumstances.
Shanling Onix Overture XM5 : FPGA architecture
The Onix Overture XM5 has been designed using an FPGA architecture developed in-house by the brand. This architecture enables high-fidelity PCM and DSD audio signal processing, so you can listen to high-resolution music with the same clarity as the sound engineer intended.
FPGA architecture
Shanling Onix Overture XM5 : Wifi and Bluetooth connectivity
The Onix Overture XM5 also features Bluetooth and Wi-Fi connectivity. Allowing Airplay, DLNA and Online Tidal streaming via Wi-Fi connectivity and support for LDAC, AptX, AptX HD, SBC and AAC codecs via Bluetooth 5.2 connectivity. Furthermore, this DAP features SyncLink via Shanling's Eddict player app on Android or Apple devices.
Eddict Player application interface
Shanling Onix Overture XM5 : Excellent build quality
The Shanling ONIX Overture XM5 features solid, high-end build quality. The player features a CNC-machined aluminium alloy chassis, four physical media control buttons, a gold-plated volume dial and a 3-inch OLED touchscreen.
Product typeDigital Audio Player (DAP)
DAC ChipESS ES9039PRO
Amplification chips2x TPA6120
Outputs1x Single-ended Jack 3.5mm
1x Balanced Jack 4.4mm
ConnectivityWifi
Bluetooth 5.2
Supported Bluetooth codecsLDAC, aptX HD, aptX, SBC, AAC
Wifi protocols supportedDLNA, Airplay, Online Tidal Streaming
Touch screenOLED 3" 720p
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
Compatible file formatsDSD (iso, dsf, dff, DST not supported), ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DST, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS
Power outputBalanced outputs : 1069mW @ 32Ω
Single-end outputs : 310mW @ 32Ω
Signal-to-noise ratio (SNR)Balanced outputs : 121dB
Single-end outputs : 120dB
Total harmonic distortion (THD)Balanced outputs : 0.0006%
Single-end outputs : 0.0014%
Output impedanceBalanced outputs :6.6Ω
Single-end outputs : 4.7Ω
Channel separationBalanced outputs :100dB
Single-end outputs : 80dB
Dynamic rangeBalanced outputs : 121dB
StorageMicro SD slot (up to 2TB, not included)
Battery7000mAh
AutonomyBalanced outputs : 12 hours
Single-end outputs : 14 hours
Dimensions115 x 70 x 19mm
Weight275g
Housing materialAluminum
Package1x Shanling Onix Overture XM5
1x USB-A to USB-C cable
InputWiFi
InputMicro SD
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipES9039MPro / ES9039MSPro
Max sampling rateDSD512
Max sampling rate768kHz
SHANLING ONIX OVERTURE XM5 Digital Audio Player DAP ES9039PRO 2x TPA6120 32bit 768kHz DSD512
Shanling's Onix Overture XM5 is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact,...
