By buying this product you get 79 loyalty points
Shanling's Onix Overture XM5 is a high-end DAP designed with state-of-the-art components to deliver the best possible performance. In fact, the Overture XM5 incorporates a latest-generation ES9039PRO DAC chip combined with a 16-core XMOS XU316 USB processor, for optimum decoding of high-resolution audio signals up to PCM 32 bit 768kHz and DSD512. With the help of a powerful amplifier section consisting of two TPA6120 chips, the Overture XM5 also boasts a powerful output of up to 1070mW at 32Ω, which, coupled with its gain control, means it can drive the vast majority of headphones and earphones on the market, maintaining a clear, low-distortion output in all circumstances.
The Shanling Onix Overture XM5 is equipped with the latest generation of ESS Sabre ES9039S Pro DAC chips. This is the latest 32-bit DAC chip from ESS Sabre Technologies. It provides exceptional decoding of high-resolution audio signals. Combined with the 16-core XMOS XU316 USB processor, decoding of high-resolution 32bit 768kHz PCM and native DSD512 audio is fully supported. With such a high-end configuration, the Overture XM5 has a signal-to-noise ratio (SNR) of up to 121dB, and a distortion plus noise ratio (THD+N) of just 0.0006%.
The Shanling Onix Overture XM5 is equipped with two TPA6120 amplifier chips, providing a high output power of 1070mW. Coupled with three different gain settings, this DAP will easily drive the most demanding headphones and earphones, ensuring a clean, accurate signal in all circumstances.
The Onix Overture XM5 has been designed using an FPGA architecture developed in-house by the brand. This architecture enables high-fidelity PCM and DSD audio signal processing, so you can listen to high-resolution music with the same clarity as the sound engineer intended.
The Onix Overture XM5 also features Bluetooth and Wi-Fi connectivity. Allowing Airplay, DLNA and Online Tidal streaming via Wi-Fi connectivity and support for LDAC, AptX, AptX HD, SBC and AAC codecs via Bluetooth 5.2 connectivity. Furthermore, this DAP features SyncLink via Shanling's Eddict player app on Android or Apple devices.
The Shanling ONIX Overture XM5 features solid, high-end build quality. The player features a CNC-machined aluminium alloy chassis, four physical media control buttons, a gold-plated volume dial and a 3-inch OLED touchscreen.
Product type | Digital Audio Player (DAP) |
DAC Chip | ESS ES9039PRO |
Amplification chips | 2x TPA6120 |
Outputs | 1x Single-ended Jack 3.5mm 1x Balanced Jack 4.4mm |
Connectivity | Wifi Bluetooth 5.2 |
Supported Bluetooth codecs | LDAC, aptX HD, aptX, SBC, AAC |
Wifi protocols supported | DLNA, Airplay, Online Tidal Streaming |
Touch screen | OLED 3" 720p |
Supported sampling rates | PCM up to 32bit 768kHz Native DSD up to DSD512 |
Compatible file formats | DSD (iso, dsf, dff, DST not supported), ISO, DXD, APE, FLAC, WAV, AIFF, AIF, DST, MP3, WMA, AAC, OGG, ALAC, MP2, M4A, AC3, M3U, M3U8, OPUS |
Power output | Balanced outputs : 1069mW @ 32Ω Single-end outputs : 310mW @ 32Ω |
Signal-to-noise ratio (SNR) | Balanced outputs : 121dB Single-end outputs : 120dB |
Total harmonic distortion (THD) | Balanced outputs : 0.0006% Single-end outputs : 0.0014% |
Output impedance | Balanced outputs :6.6Ω Single-end outputs : 4.7Ω |
Channel separation | Balanced outputs :100dB Single-end outputs : 80dB |
Dynamic range | Balanced outputs : 121dB Single-end outputs : 120dB |
Storage | Micro SD slot (up to 2TB, not included) |
Battery | 7000mAh |
Autonomy | Balanced outputs : 12 hours Single-end outputs : 14 hours |
Dimensions | 115 x 70 x 19mm |
Weight | 275g |
Housing material | Aluminum |
Color | Black |
Package | 1x Shanling Onix Overture XM5 1x USB-A to USB-C cable |
Input | WiFi |
Input | Micro SD |
Output | Jack 3.5mm |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9039MPro / ES9039MSPro |
Max sampling rate | DSD512 |
Max sampling rate | 768kHz |
Color | Black |
