SHANLING Q1 Compact Digital Audio Player DAP ES9218P Bluetooth 32bit 384kHz DSD128 Green
Shanling offers with its Q1 an extremely compact and high-performance player, perfect for high quality listening on the move or at home!
4.0 / 5
Reference : 14548
109,00 €tax incl.
90,83 € tax excl.
This reference in green has been discontinued, but it is still available in red: SHANLING Q1 Compact Digital Audio Player Red.
Shanling Q1
Shanling Q1 Baladeur DAP Compact ES9218P Bluetooth 32bit 384kHz DSD128 Vert
Resolutely HiFi
Developed to offer the best sound quality and support for high-resolution files, the Q1 incorporates an ESS Sabre ES9218P chip that is both DAC and headphone amplifier. Delivering more power than the vast majority of smartphones, the DAP can be used with many demanding headsets as well as high-sensitivity EMIs while maintaining excellent audio performance.
Retro Design
Inspired by the designs of the 1940s and 1950s, the Q1 benefits from an aesthetic that is unique in the personal music player market. With soft, rounded corners, pastel colors and chrome elements, the Q1 moves away from the coolness of the many DAP designs on the market.
Modern OS
The Q1 incorporates Shanling's in-house operating system, MTouch OS, offering excellent tactile ergonomics for smooth navigation and quick access to the many features. Developed in-house, the system is constantly evolving, with new features being added on a regular basis to meet the needs of users around the world.
Bluetooth
As compact as it is, the Shanling Q1 also benefits from full and powerful Bluetooth connectivity. It supports high-quality LDAC, aptX and AAX codecs and is compatible with most Bluetooth headsets and speakers.
The Q1 can be connected to other devices to be used as a wireless HiFi amplifier. This allows you to enjoy any streaming service, your audio files or even your movies while enjoying the sound quality of the Q1.
Shanling's DAP can also be connected via USB to a computer to provide a high-performance Bluetooth connection that supports high-quality audio codecs.
Hi-Res Audio
The Shanling Q1 complies with Hi-Res Audio certification and supports high sample rates up to 32bit 384kHz PCM and DSD128. So you can enjoy your high quality audio files without downsampling or conversion.
Expandable memory
To adapt to the music library of each person, the Q1 is equipped with a Micro SD port. So you can adapt the storage capacity of your player to your needs.
Micro SD card sold separately.
DAC / USB Amplifier
While the Shanling Q1 will be the ideal companion for traveling with you, it is equally suitable for use at home or in the office. In the latter case, simply connect the DAP to your computer to enjoy an enhanced sound card that supports Hi-Res files up to 24bit 192kHz.
USB Output
For even better audio quality, the Q1 can be connected via USB to a dedicated HiFi DAC. The DAP then works as a source, with the conversion being done by your DAC. This USB-C output also allows the Q1 to be used with many current headphones and earphones.
Compact size
To make you forget yourself on the go, the Q1 has a compact size and fits easily into a pocket. It features a 2.7" screen and its dimensions are only 75 x 62 x 16.5mm.
Physical Controls
While the touch screen of the Q1 allows intuitive and efficient navigation, it is also possible to control the playback of your music using its 3 physical buttons and its volume wheel.
High degree of autonomy
The DAP's autonomy can go up to 21 hours in continuous reading. Enough to enjoy uninterrupted listening during a long haul flight or a full working day. The Q1 can be easily recharged through its universal USB-C port.
Small but sturdy
The Q1 is extremely compact, but benefits from a high quality construction ensuring excellent durability. Its unibody body is made of Zinc and the screen is protected by a layer of 7H tempered glass. In addition, the unit comes with a silicone shell.
Product typeDigital Audio Player (DAP)
Touch Screen2.7" 360*400px
OSMTouch OS by Shanling
DAC ChipESS Sabre ES9218P
AutonomyUp to 21h (according to usage)
Up to 20 days on standby
Charging time2h (according to usage)
Battery capacity1100mAh
StorageMicro SD card up to  2TB (not included)
Supported audio formatsAPE, FLAC, ALAC, WMA, AAC, OGG, MP3, OPUS, WAV, AIFF, DSF, DIFF
OutputJack 3.5mm
Output power80mW @ 32Ω
Output impedance< 0.2Ω
Channel separation76dB
Recommended headphone impedance8-300Ω
Frequency response20Hz - 40kHz
Distortion0.004% (A-Weighting) @ 1kHz, 485mV
SNR118dB (A-Weighting)
Ground noise< 3.2µV @ High gain (A-Weighting)
< 1.5µV @ Low gain (A-Weighting)
Dynamic range> 105dB
DSD up to DSD128
Bluetooth4.2
Bi-directional
Supported Bluetooth codecsBi-directional : LDAC, AAC, SBC
Transmission only : aptX
USB DAC mode sampling ratesPCM 24bit 192kHz
ColorGreen
Package1x Shanling Q1
1x USB Cable
1x Silicone Protective Case
InputMicro SD
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipES9218P
Max sampling rate384kHz
Max sampling rateDSD128
ColorGreen
3 reviews
impossible de retirer la SD un fois insérée
C'est n'importe quoi de sortir un appareil comme ça au 21eme siècle.
Une fois la carte insérée, c'est simplement impossible de la ressortir!
Sinon, pas d'images d'album dans les listes de mon coté (juste un logo M4A), alors qu'elles sont présentées en lecture - donc rechercher un titre d'un album, c'est compliqué ...
ergonomie à revoir de manière générale (idle, boutons sur le coté = fausse bonne idée, navigation liste ...)
This review has been posted for SHANLING Q1 Compact Digital Audio Player DAP ES9218P Bluetooth 32bit 384kHz DSD128 Green
Beau produit
Je ne voyais pas le baladeur aussi gros (pour donner une idée, comme si on avait un gros chronomètre digital dans la main). Très beau produit surtout sans la coque en caoutchouc mais attention aux rayures (enfin c'est le ressenti que j'ai). Niveau son, je l'ai couplé à un casque Bose QC35II, en bluetooth il fait le job avec une carte mémoire de 64Go. J'ai également essayé avec mon Huawei Nova 5T, pareil, je ne trouve pas vraiment de différence dans la qualité du son. La navigation n'est pas si intuitive que ça au début. Par contre touches mécaniques sur le côté très sensibles, pensez à verrouiller l'appareil. Je suis satisfait pour la durée de la batterie. Pas de mode d'emploi dans la boîte.
Je cherchais initialement un émetteur bluetooth Aptx-HD / LDAC pour envoyer de la musique de mon ordinateur fixe à mon Sony WH1000XM3 sans hachures. Les prix étant déjà élevés, j'ai finalement opté un cran au dessus pour un petit lecteur audiophile avec fonction DAC en comparant le Shanling Q1 avec le Fiio M5. (La puissance de sortie a été un critère)
Le Q1 tient dans la main sans être trop petit, il est livré avec une protection silicone de même couleur et une protection d'écran additionnelle. Un système pour y mettre une dragonne aurait été un plus.
L'appareil est très qualitatif, mais il peut arriver d'appuyer par erreur sur les boutons avance retour / pause en le manipulant.
Son très bon seul ou en récupérant le son d'un autre appareil en bluetooth. (il faut dire que c'est mon premier appareil audiophile).
Avec un ordinateur, on l'installe très rapidement et il fait parfaitement son travail en tant que DAC externe.
Bref, très satisfait :)
