SHANLING Q1 Compact Digital Audio Player DAP ES9218P Bluetooth 32bit 384kHz DSD128 Red
Shanling offers with its Q1 an extremely compact and high-performance player, perfect for high quality listening on the move or at home!
Reference : 14425
109,00 €tax incl.
90,83 € tax excl.
Shanling Q1
Shanling Q1 Baladeur DAP Compact ES9218P Bluetooth 32bit 384kHz DSD128
Resolutely HiFi
Developed to offer the best sound quality and support for high-resolution files, the Q1 incorporates an ESS Sabre ES9218P chip that is both DAC and headphone amplifier. Delivering more power than the vast majority of smartphones, the DAP can be used with many demanding headsets as well as high-sensitivity EMIs while maintaining excellent audio performance.
Retro Design
Inspired by the designs of the 1940s and 1950s, the Q1 benefits from an aesthetic that is unique in the personal music player market. With soft, rounded corners, pastel colors and chrome elements, the Q1 moves away from the coolness of the many DAP designs on the market.
Modern OS
The Q1 incorporates Shanling's in-house operating system, MTouch OS, offering excellent tactile ergonomics for smooth navigation and quick access to the many features. Developed in-house, the system is constantly evolving, with new features being added on a regular basis to meet the needs of users around the world.
Bluetooth
As compact as it is, the Shanling Q1 also benefits from full and powerful Bluetooth connectivity. It supports high-quality LDAC, aptX and AAX codecs and is compatible with most Bluetooth headsets and speakers.
The Q1 can be connected to other devices to be used as a wireless HiFi amplifier. This allows you to enjoy any streaming service, your audio files or even your movies while enjoying the sound quality of the Q1.
Shanling's DAP can also be connected via USB to a computer to provide a high-performance Bluetooth connection that supports high-quality audio codecs.
Hi-Res Audio
The Shanling Q1 complies with Hi-Res Audio certification and supports high sample rates up to 32bit 384kHz PCM and DSD128. So you can enjoy your high quality audio files without downsampling or conversion.
Expandable memory
To adapt to the music library of each person, the Q1 is equipped with a Micro SD port. So you can adapt the storage capacity of your player to your needs.
Micro SD card sold separately.
DAC / USB Amplifier
While the Shanling Q1 will be the ideal companion for traveling with you, it is equally suitable for use at home or in the office. In the latter case, simply connect the DAP to your computer to enjoy an enhanced sound card that supports Hi-Res files up to 24bit 192kHz.
USB Output
For even better audio quality, the Q1 can be connected via USB to a dedicated HiFi DAC. The DAP then works as a source, with the conversion being done by your DAC. This USB-C output also allows the Q1 to be used with many current headphones and earphones.
Compact size
To make you forget yourself on the go, the Q1 has a compact size and fits easily into a pocket. It features a 2.7" screen and its dimensions are only 75 x 62 x 16.5mm.
Physical Controls
While the touch screen of the Q1 allows intuitive and efficient navigation, it is also possible to control the playback of your music using its 3 physical buttons and its volume wheel.
High degree of autonomy
The DAP's autonomy can go up to 21 hours in continuous reading. Enough to enjoy uninterrupted listening during a long haul flight or a full working day. The Q1 can be easily recharged through its universal USB-C port.
Small but sturdy
The Q1 is extremely compact, but benefits from a high quality construction ensuring excellent durability. Its unibody body is made of Zinc and the screen is protected by a layer of 7H tempered glass. In addition, the unit comes with a silicone shell.
Product typeDigital Audio Player (DAP)
Touch Screen2.7" 360*400px
OSMTouch OS by Shanling
DAC ChipESS Sabre ES9218P
AutonomyUp to 21h (according to usage)
Up to 20 days on standby
Charging time2h (according to usage)
Battery capacity1100mAh
StorageMicro SD card up to  2TB (not included)
Supported audio formatsAPE, FLAC, ALAC, WMA, AAC, OGG, MP3, OPUS, WAV, AIFF, DSF, DIFF
OutputJack 3.5mm
Output power80mW @ 32Ω
Output impedance< 0.2Ω
Channel separation76dB
Recommended headphone impedance8-300Ω
Frequency response20Hz - 40kHz
Distortion0.004% (A-Weighting) @ 1kHz, 485mV
SNR118dB (A-Weighting)
Ground noise< 3.2µV @ High gain (A-Weighting)
< 1.5µV @ Low gain (A-Weighting)
Dynamic range> 105dB
DSD up to DSD128
Bluetooth4.2
Bi-directional
Supported Bluetooth codecsBi-directional : LDAC, AAC, SBC
Transmission only : aptX
USB DAC mode sampling ratesPCM 24bit 192kHz
ColorRed
Package1x Shanling Q1
1x USB Cable
1x Silicone Protective Case
Input
  • Bluetooth
  • Micro SD
Output
  • Bluetooth
  • Jack 3.5mm
DAC / ADC Chip
  • ES9218P
Max sampling rate
  • 384kHz
  • DSD128
Color
  • Red
Petit galet sympa qui en a sous le pied !
Pfiou, le dernier baladeur que j'ai acheté et réellement utilisé doit remonter au Rio Karma, c'est dire... Mais la disparition des jacks sur les téléphones et mon intérêt nouvellement renouvelé pour les écouteurs et casques filaires m'ont orienté vers ce Q1, qui présente des spécifications et fonctionnalités alléchantes.
Le premier contact est très positif, la finition d'ensemble est vraiment qualitative, une fois en main l'objet est lourd, dense, et inspire confiance. Les formes douces font qu'il tombe parfaitement dans la paume, et tous les boutons sont bien accessibles. Le contenu de la boîte est chiche, et va a l'essentiel. Bon point pour l'étui en silicone et les protections d'écran livrées avec. Pas de chargeur USB, mais le câble USB-A/C est qualitatif.
Au premier allumage l'écran lumineux quoiqu'à la résolution relativement basse nous accueille. Pour moi le format est parfait, pas trop petit, même si on se dit que Shanling aurait pu rogner les imposantes bordures pour proposer quelques millimètres de plus en diagonale. D'emblée le système nous propose de choisir la langue. Allons droit au but, à moins d'être anglophobe convaincu, n'utilisez pas la version FR, la traduction est vraiment mauvaise, au point de rendre certaines fonctionnalités incompréhensibles dans les menus. Il est possible aussi de verrouiller les boutons et/ou la molette pour éviter des manipulations accidentelles dans le fond de la poche, bon point. Attention d'ailleurs, autant la molette de volume ne s'active pas trop par accident, autant les boutons latéraux sont très sensibles et ne nécessitent pas beaucoup de pression pour s'activer.
Quelques fonctionnalités restent un peu obscures et vont quand même nécessiter pour les néophytes le passage dans un manuel numérique dispo sur le site Shanling, puisqu'il n'y en a pas dans la boîte. Cela dit encore une fois, la fiche technique a de quoi donner le tournis : DAC USB, bluetooth bidirectionnel, wifi...
Il est temps d'insérer la µSD avec ma bibliothèque musicale. Après un premier scan qui a duré bien 3 ou 4 minutes (environ 10000 pistes), je peux enfin lancer quelques pistes. L'interface est claire, et se pilote essentiellement par des gestes pour appeler les différents menus, il faut s'y faire même si n'importe quelle personne un peu habituée à un smartphone moderne s'en sortira rapidement. Le système est assez réactif, on peut naviguer aussi bien par dossier que par métadonnées, j'aurais juste aimé pouvoir utiliser la molette dans certaines situations, notamment pour faire défiler les longues listes. De même, il n'y a pas d'outil de recherche par nom/dossier ou par tag, dommage. Quelques petites notes accessoires, le Q1 n'est pas compatible wifi 5Ghz, et il faut parfois insister pour qu'il détecte un périphérique bluetooth en mode appairage. A noter aussi que la saisie de la clé wifi est assez fastidieuse, car elle doit être faite sur un clavier numérique T9 à l'ancienne (vu la taille de l'écran aussi...), et que si la clé de votre routeur est plus longue que ce que l'écran peut afficher, il faut taper à l'aveugle car on ne peut pas faire défiler le texte... De toute manière, le wifi ne servant qu'à faire les mises à jour de l'OS et éventuellement quelques transferts de fichiers, la fonction est très dispensable. Le bluetooth en revanche a l'air assez puissant et stable une fois la connexion établie (avec un Sony WH-1000XM3 et des Jabra 75T).
Première lecture de piste, l'interface de lecture est claire et permet d'accéder à toutes les infos concernant la piste en lecture. Un égaliseur graphique complet est dispo et entièrement paramétrable, et de nombreuses options de gain/filtres/etc. sont dispo pour les utilisateurs les plus hardcore.
D'accord c'est très beau tout ça, mais le son alors ? Je ne vais pas m'étendre car je n'ai pas encore vraiment le recul, ni les connaissances techniques nécessaires pour fournir un avis vraiment éclairé sur la question. Ce que je peux en dire c'est qu'avec des écouteurs KZ ZS10 Pro et Moondrop Starfield, la sortie son est très propre (pas de souffle), claire et puissante, et fait bien ressortir la "personnalité" de chaque casque. L'expérience est de mon point de vue très satisfaisante par rapport aux smartphones bien souvent médiocres ou aux casques bluetooth (et là comme le DAC est dans le casque, aucune différence). J'ai pour l'essentiel des MP3 à haut bitrate, je ne vais pas dire que je redécouvre ma discothèque, mais le gain en qualité avec des écouteurs filaires est très net par rapport aux smartphones que j'ai pu utiliser ces dernières années (que ce soit par prise jack ou dongle USB-C). C'était l'objectif, le contrat est rempli.
Au final pour le prix, l'objet fait très belle impression pour sa qualité globale (matérielle et acoustique) et coche quasi toutes les cases niveau fonctionnalités. Le format est un bon compromis niveau compacité/prise en main, j'ai longtemps hésité avec le M0, mais je pense que ce dernier est vraiment trop petit pour être confortable à l'usage. C'est au final un petit baladeur rudement sympa, que je n'aurais aucun mal à conseiller pour qui souhaite pouvoir utiliser ou réutiliser des écouteurs/casques filaires nomades (et pourquoi pas un peu de salon aussi) dans de bonnes conditions, même si j'ai conscience qu'en 2021, ça ne concerne plus forcément beaucoup de monde dans le cadre d'un usage vraiment mobile.
Par ailleurs, chapeau à Audiophonics pour une expédition nickel et dans les délais annoncés.
This review has been posted for SHANLING Q1 Compact Digital Audio Player DAP ES9218P Bluetooth 32bit 384kHz DSD128 Red
