XDUOO X10T Digital Audio Player DSD AES EBU 24bit 192Khz WM8805
Reference : 12272
219,00 €tax incl.
182,50 € tax excl.
- xDuoo X10T A dap without dac! -
Xduoo X10T
xDuoo brings here an original and high-end solution in the world of DAP. The xDuoo X10T digital music player offers only digital outputs with a low jitter rate of 50ps. It thus offers the free choice of the nomad battery on DAC to add. It is the ideal companion for the nomadic DACitle = "Xduoo X10T" href = "http://www.audiophonics.com/en/dac-sans-volume/xduoo-xd-05-ampli-casque-dac-32bit-ak4490-android-ios-dsd-sur -battery-silver-p-10734.html "target =" _ blank ">xDuoo XD-05.
Digital outputs for all situations
The xDuoo X10T can be used as a Swiss DAP knife for sound professionals with a spellie AES EBU on gold-plated mini-XLR 3PIN. It has, of course, SPDIF coaxial and optical classics on mini 3.5mm mini-Toslink connector.
A great capacity for all music
Xduoo X10T
The xDuoo incorporates two ports for micro SD card cards adding a total of 256GB of storage (not supplied). Whether you are a fan of Italian opera or anthology rock and jazz concerts, you can listen to the long hours of listening.
A simple and intuitive interface
Xduoo X10T
The DAP Xduoo X10T features an interface of the simplest speed that participates in makingu High fidelity of this walkman. Accompanied by oversized and accessible keys, it has never been easier to listen to music while walking.the = "color: # 000000; font-family: Arial; font-size: 12px; font-style: normal; font-weight: normal;">
Xduoo X10T
Sampling rate24bits 192kHz
Digital Output Sensitivity0.5V pp (75Ω Coaxial) / 19dB Toslink / 3.25V AES EBU XLR
THD0.00087%
Compatible file types
DSDDSD64 Over PCM (DOP)
APE24bits 192kHz
FLAC24bits 192kHz
WAV24bits 192kHz
Apple Lossless24bits 192kHz
WMA, MPE, AAC, ALAC, OGG-
Miscellaneous
Storage memory2 128GB microSD drives (cards not included)
Battery capacity1500mAH 4.2V
Dimensions105.5 x 45 x 14mm
Weight100g
Un petit pavé dans la marre ...
... des sources numériques.
Après lecture de quelques retours d'expériences (ex. sur Headfonia : X10T Vs AK SE100) j'ai décidé d'en essayer un sur mon système numérique (actif, débafflé et entièrement sur batteries Optima).
Et bien, effectivement, et c'est un bon signe, après le premier morceau testé j'ai laissé jouer et écouté l'intégralité du disque tellement c'était agréable.
Ce transport numérique me délivre plus d'informations, d'ambiances des salles (que mon transport CD ou que la sortie numérique de mon Fiio X5), tout en conservant le côté naturel, l'étendue des octaves, la dynamique...
J'ai fait ces écoutes sur la sortie S/Pdif (avec un câble : jack VIABLUE T6s/câble 75ohm argenté PTFE/ rca Argent) pour comparer ce qui est comparable.
Ce petit pavé a accepté mes 2 cartes SD de 256 Go, ce qui fait quand même 1/2 Terra de stockag, soit environ 700 Cds en WAV, revers de la médaille l'écran est assez riquiqui et les touches sont moins pratiques qu'une roue pour se balader dans les fichiers.
Il est pas pratique, mais il a quand même 5 étoiles pour le plaisir qu'il procure...
Jean-Pierre Bachelier / Artisanat Acoustique
This review has been posted for XDUOO X10T Digital Audio Player DSD AES EBU 24bit 192Khz WM8805
