FIIO X5 2nd Gen HiFi DAP DAC DSD SACD ISO 24/192kHz
By buying this product you get 37 loyalty points
Reference : 10076
379,00 €tax incl.
315,83 € tax excl.
New generation of the FiiO X5, the X5 2nd gen is a dreadfully effective DAP that can also act as a high-quality USB DAC to enjoy your audio sources on your home Audio systems.
This X5 2nd Gen comes with a lot of 5 stickers design stickerto dress it completely according to your tastes (see photos).
It is more compact, lighter and has a power supply 40% higher than its predecessor for a general improvement in sound performance.
C 'is a complete HiFi player capable of playing almost all PCM audio files up to 24bit 192kHz (APE / FLAC / ALAC / WMA / WAV / MP3) as well as DSD natively and ISO SACD files.
It incorporates a PCM1792 converter associated with an amplification stage composed of very low distortion AOP OPA1652 and OPA1612 (for the filter stage (LPF)).
Let has been revised and corrected for better dynamics and precision at the bottom of the spectrum: it is now equipped with two BUF634U buffers delivering up to 250mA of output current, an improvement of 67% compared to to the old generation.
xt-align: center; ">DSDISO SACD
Features:
  • Dual Core CPU Processor JZ4760B 600MHz
  • DAC: Burr-Brown PCM1792
  • AOP Burr-Brown OPA1652, OPA1612
  • SiTime MEMS x2 High Precision Clock
  • Impedance Recommended headphones: 16 to 150 ohms
  • Analog output / headphone output: 3.5mm jack
  • LINE / Coax output: 3.5mm jack
  • Micro USB port
  • Output Impedance: 0.22 Ω
  • 10-band digital equalizer (+/- 6dB) integrated
  • Volume control: 120 levels per PGA2311
  • Balance adjustment: 10dB
  • Gain: 0-6 dB
  • THD line output: <0.001% (1 kHz)
  • THD + N headphone output: <0.001% (1kHz)
  • Frequency response: 20Hz - 20KHz (+/- 0.1)
  • Crosstalk : > 115 dB at 1kHz
  • Signal Noise Ratio:> 114dB
  • Dynamic range:> 110dB
  • Line Output Level:> 1.53Vrms
  • Power supply: 5V DC 2A recommended
  • Battery capacity: 3300 mAh
  • Autonomy: 10 h
  • Charging time: 4 h
  • External Memory: 256GB max (128GB x 2)
  • SD card not included
  • Supported Audio Formats: DSD128 native, ISO SACD, APE, FLAC, ALAC, WMA, AAC, OGG, MP3 ...
  • Screen 2.4 "/ 400x360p IPS
  • Case 100% Aluminum machined CNC anodized Titanium
  • Output power 1:> 245 mW at 32Ω THD <1%
  • Output power 2:> 436 mW at 16Ω </ Li>
  • Output power 3:> 27 mW at 300Ω </ Li>
  • Weight: 165g
  • Dimensions: 109x63.5x15.3mm
  • Comes with cover, screen protector, 3.5mm jack coaxial cable, and a set of 5 self-adhesive stickers
    [Img-11734-left-thickbox_default]
    [Img-11735-left-thickbox_default]
    [Img-11736-left-thickbox_default]
    [Img-18457-left-thickbox_default]
