SHANLING M3S Digital audio Player High fidelity Dual DAC AK4490 Black
The DAP Shanling M3s with a dual DAC 32bit has a true High fidelity expertise with a low impedance of output, compatible with a wide range of headphones and intras, this DAP offers a real musical quality whatever the type of music.
By buying this product you get 27 loyalty points
Reference : 12290
279,00 €tax incl.
232,50 € tax excl.
- Shanling M3s 32bit 384khz AK4490 X2 DAC -
shanling m3s
DAP nomadic and audiophile sedentary
The Shanling M3S Hi-RES Walkman with its dual DAC AK4490 design and true symmetrical stages with AOP MUSE8920 and AD8397 X2 offers high-quality sound in a compact format. Capable of competing with streamers and DACs, this DAP will fulfill all your expectations both in public transport and at home. It is obviously usable in USB transport to a compatible DAC or vice versa in DAC USB to a Hifi chain.
Bluetooth 4.1 APTX and HibyLink
The DAP Shanling M3s isHibyLink. It allows you to control the M3S playback application via an Android smartphone or tablet. So the Shanling M3S becomes a high quality USB driver compatible with your DAC or Hifi. You can change songs, raise or lower the volume, edit playlists on your smartphone or tablet. The DAP M3S can of course send Bluetooth 4.1 apt-X on a wireless receiver or any compatible speakers.
DACDual DAC AK4490 32bits 384kHz
Distortion rate per harmonic0.0015%
Bandwidth20 to 20kHz +/- 0.015dB
Output Power130mW (32 Ohms), 230mW balanced balanced output (32 Ohms)
Signal Ratio115dB A-weighted
Output impedance0.6 Ohm unbalanced output, 0.3 Ohm balanced balanced outputANCED
Separation of channels102dB (balanced mode)
Internal ClockDouble KDS high precision 22.5Mhz and 24.5Mhz clock with reduced phase distortion
ViewingScreen Retina thickness glass 2.5D
Compatibility & Connectivity
USB Type C CompatibilityPCM 44.1kHz - 384kHz 16-32bits, DSD64 to DSD128
File CompatibilityDSF, DFF, ISO, WAV, WMA, FLAC, ACC, ALAC, APE
USB DAC CompatibilityWindows 7, 8, 8.1, 10 (requires a drive), Mac OS 10 and Linux
Bluetooth4.1 aptX
Hibylink Wireless ControlCompatible
USB CompatibleWindows 7, 8, 8.1, 10 (requires a drive), Mac OS 10 and Linux
Connectors
Headphone outputJack 2.5mm TTRS Symmetrical Balanced
Headphones output3.5mm Stereo Jack
StorageMicro SD max. 256GB (not included)
USB Type-C portYes - USB DAC compatible and USB transport
Miscellaneous
FoodThrough the USB port Type-C 5V DC 2A
CaseAluminum CNC Black
Dimensions113 x 53 x 14.5mm (WxDxH)
Weight135g
Accessories1x USB Cable Type-C
Color
  • Black
The DAP Shanling M3s with a dual DAC 32bit has a true High fidelity expertise with a low impedance of output, compatible with a wide range of...
