XDUOO X20 DAP Digital Hifi Music Player DAC ES9018K2M 32bit 384kHz DSD256 Bluetooth aptX
xDuoo comes back with a new DAP, the X20. It offers particularly comprehensive functionality and quality-based component design for excellent audio reproduction. On the program, DAC ES9018K2M, Bluetooth bi-directional, Hiby Link or symmetrical output ...
By buying this product you get 23 loyalty points
Reference : 12728
239,00 €tax incl.
199,17 € tax excl.
xDuoo X20
DAP Digital Hifi Music Player DAC ES9018K2M 32bit 384kHz Bluetooth
xduoo x20 baladeur numérique hifi
xDuoo comes back with a new DAP, the X20. It offers highly comprehensive functionalities and quality-based component design for excellent audio reproduction. On the program, DAC ES9018K2M, Bluetooth bi-directional, Hiby Link or symmetrical output ...
xDuoo x20
DAC ES9018K2M and Dual Clock
The x20 from xDuoo has a very good DAC ESS ES9018K2M. That ensure a clean and efficient signal conversion. Both active clocks with independent low-noise phase. These significantly reduced the jitter. We thus gain in precision and the distortion decreases.
Compatible with many formats
The X20 is compatible with most popular formats, namely APE, FLAC, WAV, AIFF, ALAC, AAC, MP3, OGG, WMA, but also with high quality formats. Thus, DAP supports native DSD256 with ISO, DFF and DSF formats. So you can enjoy all your audio files, even in very high quality.
Balanced output
This digital player makes the choice to offer 3 outputs. We note especially the presence of a symmetrical output on Jack 2.5mm. This allows you to enjoy comfortable power to power all types of headphones or headphones, but also improved sound quality: wider and more accurate sound image, more detail, more delicate, more faithful.
OPA1612 and Clean Power Supply
The xDuoo X20 also features AOP OPA1612 ultra low noise. This one allows to obtain a more detailed restitution. In the same vein, this player has a power stage to provide a clean signal using a LDO regulator . This clean signal helps to limit the distortion for a clearer sound.
xDuoo x20 AOP OPA1612
xDuoo x20 Bluetooth
Bi-directionnal bluetooth
The X20 offers a Bluetooth 4.1 feature, supporting aptX technology , ensuring a more reliable and stable transmission for better rendering sound. Small peculiarity for this DAP, it is about bi-directional Bluetooth. Thus, if it can be used to send the signal on your headphones or speakers, it can also receive a signal allowing you to use its DAC function.
Hiby Link compatible
Hiby Link is a feature of the excellent Hiby player for Android and iOS. This feature will allow you, after pairing the X20 with Hiby via Bluetooth, to directly control your player from your smartphone. So, no need to take your DAP out of your pocket, all controls are from a single device.
xDuoo x20 Hiby Link
xDuoo x20 car play mode
Car Play Mode
In order to enjoy high quality sound right into your car, you can connect the X20 to the audio system of your vehicle. Once detected, the X20 will turn on automatically when you start the car and audio system and will turn off automatically when you turn off the ignition, without waiting to fully discharge.
Player but also DAC
The USB-C port is not only for the purpose of data transmission and reloading of the DAP. Connected to a computer it will allow you to use the X20 as an external USB DAC to enjoy superior audio on your computer.
xDuoo x20 DAC
Ua sound for each type of listeninge
The player offers a series of predefined equalizers but also a custom equalizer on 10 frequencies. Thus, you can adapt the sound to your listening, your musical styles but also to your earphones / IEM.
Robust housing, modern design
The housing of the device has been CNC machined by high precision machines, forming a single piece of metal. Metal which also benefits from a sanding treatment bringing a more pleasant texture. With its weight of only 138g, the DAP will be able to accompany you in all your displacements.
Headphone output specifications (Jack 3.5mm)
Power210mW (32Ω / THD+N < 0.0015%)
Frequency response20Hz - 20kHz (+-0.15dB)
SNR>= 114dB
Resolution> 72dB
Distorsion + Noise0.0015% @ 1kHz (32Ω @ 1kHz)
Balanced headphone output specifications (Jack 2.5mm)
Power300mW (32Ω / THD+N < 0.0015%)
SNR>= 116dB
Resolution> 112dB
Line output specfications
Output level1.7Vrms (KΩ @ 1kHz)
SNR>= 114dB
Resolution> 108dB (10KΩ @ 1kHz)
Distorsion + Noise0.0012% @ 1kHz (10KΩ)
BluetoothBluetooth 4.1 aptX bi-directionnal
DACES9018K2M
Memoryvia Micro SD (max 256Go)
BatteryLithium polymer 2400mAh
AutonomyJack 3.5mm : 8 hours
Jack 2.5mm : about 7 hours
Charging connectorType C USB
Charging time< 3 hours (DC 5V 2A)
< 6 hours (DC 5V 500mA)
Dimensions110 x 56 x 16.6mm
Weight138g
Input
  • Bluetooth
  • Micro SD
Output
  • Bluetooth
  • Jack 2.5mm
  • Jack 3.5mm
Color
  • Black
DAC / ADC Chip
  • ES9018K2M
Max sampling rate
  • 384kHz
  • DSD256
C'est un fidèle Ami de musique
Ce petit DAP est très facile à vivre.
La musique qu'il délivre est puissante, linéaire, plutôt neutre, et soyeuse. Il a le registre grave magnifique et tendu qui semble être la signature de la marque et il place une scène sonore dense sous un éclairage aux teintes chaudes, lisses mais texturées. Très belle musique: incarnée. Il permet des écoutes longues et sans fatigue, dénuées d'artefacts numériques.
Chez XDUOO on semble proche des mondes de la musique pro: on reste neutre, concentré et on ne cherche pas à enjoliver les choses.
Le son est surpuissant quand il le faut ...et acoustique et neutre quand cela l'exige.
Il mérite un très bon casque.
Son utilisation est aisée, son association avec ses camarades de jeu est fluides. Il télécharge sur OS sans soucis et se manipule au doigt et à l'oeil par petites touches car il n'a pas d'écran tactile.
Il est magnifiquement sobre construit pour durer avec une batterie suffisamment puissante.
J'aime beaucoup cet appareil et il est devenu un fidèle ami de balades.
This review has been posted for XDUOO X20 DAP Digital Hifi Music Player DAC ES9018K2M 32bit 384kHz DSD256 Bluetooth aptX
xDuoo comes back with a new DAP, the X20. It offers particularly comprehensive functionality and quality-based component design for excellent audio...
