DAYTON AUDIO DNR Precision Ceramic Resistor 10W 6 Ohm
Reference : 13118
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 26-03-2025.
dayton audio filter DNR Resistance 6.0 Ohm 10W 6
Precision ceramic Resistance DNR-10W 6.0 6ohm
Resistors Dayton Audio Audio Grade DNR series are mainly used to set up  Zobel Networks and attenuation circuit type L-PAD (voltage division).
This resistance is designed with nickel - chromium elements and has a high thermal conduction core to significantly reduce background noise.
A tolerance of 2%, conductive oxygen-free copper and gold-plated low inductance connectors make a choice component for a filter / crossover accuracy when integrating the speakers.
This component is built specifically for audio use and specifications correspond to a set of audiophile completely load. It will thus integrate the most ambitious sound projects.
Characteristics
Resistance6 Ohms
TypeWirewound resistor
Power10W
Section wire2%
Resistance (Ohm)6
Tolerance (%)2
Power (W)10.0
Très bien
Les valeurs correspondent
This review has been posted for DAYTON AUDIO DNR Precision Ceramic Resistor 10W 6 Ohm
