DC-DC Converter 8 / 35V to 5V 15W 3A USB-A Female
This DC / DC converter can receive an input voltage of 8-35V and output a voltage of 5V 3A 15W. It has a USB-A female connector pre-soldered.
Reference : 12679
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 25-04-2025.
DC-DC Converter
8/35V to 5V 15W 3A USB-A Female
convertisseur DC-DC
This DC / DC converter can receive an input voltage of 8-35V and output a voltage of 5V 3A 15W. It has a pre-soldered female USB-A connector at the output.
Compact and cast in a moisture-resistant epoxy resin, it will allow you to obtain a clean and stabilized source of energy.
It is particularly suitable for mounting in a car, to enjoy a USB connector.
Input voltageDC 8V-35V
Output voltage5V 15W 3A
Output connectorUSB-A Femelle
USB connector holes spacing29mm
Dimensions46 x 32 x 18mm
Weight62g
Output voltage (V)5.0
Input voltage (V)17.0
Input voltage (V)35.0
Input voltage (V)10.0
Input voltage (V)26.0
Input voltage (V)19.0
Input voltage (V)33.0
Input voltage (V)12.0
Input voltage (V)28.0
Input voltage (V)21.0
Input voltage (V)34.0
Input voltage (V)14.0
Input voltage (V)30.0
Input voltage (V)23.0
Input voltage (V)16.0
Input voltage (V)32.0
Input voltage (V)9.0
Input voltage (V)25.0
Input voltage (V)18.0
Input voltage (V)11.0
Input voltage (V)27.0
Input voltage (V)20.0
Input voltage (V)13.0
Input voltage (V)29.0
Input voltage (V)22.0
Input voltage (V)15.0
Input voltage (V)31.0
Input voltage (V)8.0
Input voltage (V)24.0
Bien reçu le convertisseur, mais il m'a donné des sueurs: il a fallu essayer quatre prises mâles UBS différentes pour en trouver une qui "matche" avec la prise femelle du convertisseur; je commençais à penser que le convertisseur ne fonctionnait pas...
Pourriez vous s.v.p. m'indiquer si ce produit convient pour charger une power bank usb à partir d'un petit panneau solaire ? Merci !
This review has been posted for DC-DC Converter 8 / 35V to 5V 15W 3A USB-A Female
