DC-DC Converter and voltage elevator 300W
The Sure 500W Boost is a DC-DC converter and voltage booster designed to be integrated into a vehicle. It has a 12V DC input perfectly adapted to this type of use and will allow you to obtain a voltage of 24V, 30V, 36V, 40V or 48V DC as well as a power up to 500W. A DIP switch allows you to select this output voltage according to your needs. An adjustable resistor allows the selected voltage to be refined more precisely.
The module also incorporates a status LED and a fan to cool the heating components. The input circuit has a fuse in case of overload.
Caution: Before changing the output voltage, make sure that the camera is turned off.
A load of less than 30Ω is required at the output of the converter. Otherwise, a voltage rise is present at the output during module startup.
Without load, it is necessary to connect the product to be powered 3 seconds after the inverter is switched on.
General characteristics | |
Module type | DC-DC Converter Voltage elevator |
Input voltage | 11-27V |
Adjustable output voltage | 24V, 30V, 36V, 40V, 48V |
Output power | 500W |
Dimensions | 121.9 x 91.4mm |
Fixation holes spacing | 111.8 x 81.3mm |
Electric characteristics | ||||
Parameters | Condition | Min. | Typ. | Max. |
Supply voltage | - | 11V | 12V | 27V |
Output power | - | - | 500W | - |
Oscillation frequency | - | - | 55kHz | - |
Quiescent current | Vin = 12V | - | 20mA | - |
Operating temperature | - | 0°C | 20°C | 80°C |
Max temperature before shutdown | - | - | 150°C | - |
Output voltage (V) | 36.0 |
Output voltage (V) | 30.0 |
Output voltage (V) | 48.0 |
Output voltage (V) | 24.0 |
Output voltage (V) | 40.0 |
Input voltage (V) | 12.0 |
