8V-52V DC to 5V DC USB-A / Micro USB
This particularly practical DC-DC converter accepts a wide voltage range from 8V Dc to 52V DC at the input. This current is then converted to 5V DC and the converter has both a Micro USB connector and a USB-A to allow you to do your wiring. The components are placed in a waterproof plastic case.
Specifications | ||
Product type | DC-DC Converter | |
Input voltage | 8V-52V DC | |
Output voltage | 5V DC | |
Max output current | 3A | |
Efficiency | 90% | |
Output connectors | 1x Micro USB 1x USB-A | |
Dimensions | 46 x 32 x 18mm | |
Weight | 70g |
Output voltage (V) | 5.0 |
Input voltage (V) | 14.0 |
Input voltage (V) | 29.0 |
Input voltage (V) | 44.0 |
Input voltage (V) | 22.0 |
Input voltage (V) | 37.0 |
Input voltage (V) | 16.0 |
Input voltage (V) | 31.0 |
Input voltage (V) | 46.0 |
Input voltage (V) | 9.0 |
Input voltage (V) | 24.0 |
Input voltage (V) | 39.0 |
Input voltage (V) | 18.0 |
Input voltage (V) | 34.0 |
Input voltage (V) | 48.0 |
Input voltage (V) | 11.0 |
Input voltage (V) | 26.0 |
Input voltage (V) | 41.0 |
Input voltage (V) | 19.0 |
Input voltage (V) | 33.0 |
Input voltage (V) | 50.0 |
Input voltage (V) | 13.0 |
Input voltage (V) | 28.0 |
Input voltage (V) | 43.0 |
Input voltage (V) | 52.0 |
Input voltage (V) | 21.0 |
Input voltage (V) | 36.0 |
Input voltage (V) | 15.0 |
Input voltage (V) | 30.0 |
Input voltage (V) | 45.0 |
Input voltage (V) | 8.0 |
Input voltage (V) | 23.0 |
Input voltage (V) | 38.0 |
Input voltage (V) | 17.0 |
Input voltage (V) | 32.0 |
Input voltage (V) | 47.0 |
Input voltage (V) | 10.0 |
Input voltage (V) | 25.0 |
Input voltage (V) | 40.0 |
Input voltage (V) | 49.0 |
Input voltage (V) | 12.0 |
Input voltage (V) | 27.0 |
Input voltage (V) | 42.0 |
Input voltage (V) | 51.0 |
Input voltage (V) | 20.0 |
