UBEC Regulator / Voltage Converter Module 8-25VDC to 5/12VDC
This regulator and DC-DC converter module allows to convert an input voltage in the range 8-25VDC into 5VDC 3A or 12VDC 2A.
Reference : 17011
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 15-04-2025.
UBEC Regulator / DC-DC Converter
UBEC Module Régulateur / Adaptateur Convertisseur de Tension 8-25VDC vers 5-12VDC
This regulator and DC-DC converter module allows to convert an input voltage in the range 8-25VDC into 5VDC 3A or 12VDC 2A. To obtain this last output voltage, it is necessary to solder the two points indicated on the following picture:
Product typeRegulator / DC-DC converter module
Input voltage8-25VDC
Output voltage5V 3A (default) or 12V 2A
Dimensions (W*D*H)16.5*9.3*3.4mm
Output voltage (V)5.0
Output voltage (V)12.0
Input voltage (V)8.0
Input voltage (V)25.0
