Voltage Adapter Converter 12VDC to 19VDC 8A 150W
Convert 12V DC to 19V DC with this compact 150W step-up converter that will give you a stable power source.
Reference : 13065
22,90 €tax incl.
19,08 € tax excl.
Convert from 12V DC to 19V DC with this compact 150W step-up converter that will give you a stable power source for your appliances or other equipment.
Advantages:
  • Robust and waterproof housing, ideal for various uses including vehicles, motor homes, mobile sound systems, security systems, hospital equipment, telecommunications, etc.
  • Over 92% current conversion efficiency
  • Integrated overload, overvoltage, undervoltage, overheating and short-circuit protection
  • Automatic recovery function
  • Provides stable and safe performance in a compact, ultra-lightweight, impact-resistant aluminum design.
Characteristics:
  • Diameter of fixing holes : Ø 6.6 mm
  • Pre-tinned terminations
  • Input voltage: 12V DC
  • Output voltage: 19V DC
  • Input voltage range: 9 ~ 16V DC
  • Output current: 8A (max)
  • Operating temperature : 30°C ~ +80°C
  • Cable length: 150mm
  • Material: die-cast aluminium housing, epoxy sealed filling
  • Dimensions: 74 x 74 x32mm
  • Weight: 300g
Output voltage (V)19.0
Input voltage (V)12.0
Très bon produit !
Produit efficace et fiable qui tient parfaitement la puissance indiquée. Ne chauffe pratiquement pas !
This review has been posted for Voltage Adapter Converter 12VDC to 19VDC 8A 150W
