Voltage Booster / Voltage Converter Adapter USB 5V to 9 / 12V DC 600mA
This USB voltage converter cable can boost USB 5V power supply to DC9V or DC12V, the current is max 600mA.
You can connect the USB port to a computer or mobile phone charger socket.
Reference : 17651
8,90 €tax incl.
7,42 € tax excl.
Shipping date: 24-04-2025.
Élévateur de Tension / Adaptateur Convertisseur de Tension USB 5V vers 9 / 12V DC 600mA
You can connect the USB port to a computer or mobile phone charger socket. The cable has a switch to set the output to 9V or 12V, the output port is DC 5.5x2.1mm jack.
A 5.5x2.1mm to 3.5x1.35mm adapter is also included.
Technical Characteristics
Product typeVoltage Booster / Voltage Converter Adapter
Imput Voltage5V USB
Output Voltage9V 600mA
12V 500mA
Connectors Jack DC 5.5x2.1mm
+ Jack DC 5.5x2.1mm to DC 3.5x1.35mm adapter
Cable lenght80cm
Housing Dimensions (L*H*L)5*1,3*2,4cm
Weight30g
Output voltage (V)9.0
Output voltage (V)12.0
Input voltage (V)5.0
This USB voltage converter cable can boost USB 5V power supply to DC9V or DC12V, the current is max 600mA . You can connect the USB port to a...
