WONDOM PS-SP12148 500W BOOST DC-DC Step Up Converter 500W Car Audio
The Sure 500W Boost is a DC-DC converter and voltage booster designed to be integrated into a vehicle. It has a perfect 12V DC input effect suitable for this type of use and will allow you to get an output voltage of 24V, 30V, 36V, 40V or 48V DC as well as a power up to 500W.
Reference : 13185
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 25-04-2025.
WONDOM 500W Boost
DC-DC Converter and voltage elevator 300W
Sure 500W Boost Convertisseur DC-DC et élévateur de tension 300W
The Sure 500W Boost is a DC-DC converter and voltage booster designed to be integrated into a vehicle. It has a 12V DC input perfectly adapted to this type of use and will allow you to obtain a voltage of 24V, 30V, 36V, 40V or 48V DC as well as a power up to 500W. A DIP switch allows you to select this output voltage according to your needs. An adjustable resistor allows the selected voltage to be refined more precisely.
Sure 500W Boost Sélection tension de sortie
The module also incorporates a status LED and a fan to cool the heating components. The input circuit has a fuse in case of overload.
Caution: Before changing the output voltage, make sure that the camera is turned off.
Dimensions
boost-dc-dc-converter-car-audio-sure-inp
A load of less than 30Ω is required at the output of the converter. Otherwise, a voltage rise is present at the output during module startup.
Without load, it is necessary to connect the product to be powered 3 seconds after the inverter is switched on.
General characteristics
Module typeDC-DC Converter
Voltage elevator
Input voltage11-27V
Adjustable output voltage24V, 30V, 36V, 40V, 48V
Output power500W
Dimensions121.9 x 91.4mm
Fixation holes spacing111.8 x 81.3mm
Electric characteristics
ParametersConditionMin.Typ.Max.
Supply voltage-11V12V27V
Output power--500W-
Oscillation frequency--55kHz-
Quiescent currentVin = 12V-20mA-
Operating temperature-0°C20°C80°C
Max temperature before shutdown--150°C-
Output voltage (V)48.0
Output voltage (V)24.0
Output voltage (V)40.0
Output voltage (V)36.0
Output voltage (V)30.0
Input voltage (V)12.0
The Sure 500W Boost is a DC-DC converter and voltage booster designed to be integrated into a vehicle. It has a perfect 12V DC input effect...
